coolant light on - Mercedes Benz SLK Forum
 5Likes
  • 1 Post By slk-carter
  • 1 Post By Roberto_Rodrigues
#1 Old 03-22-2017
Vehicle: slk200
coolant light on
Hi
Recently purchased my first slk200 2001 , my coolant light keeps coming on , coolant level ok , fan working , temp reads normal
Any ideas , known issues ?
Thanks in advance
Paul
slk-carter is offline
#2 Old 03-22-2017
Quoted: 6554 Post(s)
Paul,
First please update your vehicle (year?: 2001) in your profile as it helps the members answer your questions which usually are based on that information if you haven’t. This takes about 30 seconds to do.
Follow exactly to update: ‘Usercp’ at the top of page, then ‘edit your details’ on the left side, ‘additional information’ near the bottom, edit your ‘vehicle’. Info in your garage does not update your profile.
Join the gang! Your 1st thread should be your introduction so we can welcome you properly so post an introduction in the ‘New members introduce yourself here’ section, if you haven’t already. https://www.slkworld.com/new-members-...yourself-here/
#3 Old 03-22-2017
the coolant light and the windshield washer fluid light are the same light/sensor
how is the washer fluid level? low? that is the issue
#4 Old 03-22-2017
Vehicle: slk200
Both levels are ok !
#5 Old 03-22-2017
Then is might be thermostat related
others will reply soon
please update model year of your car 2001 in your profile
and post a quick intro thread per forum requirements
here is a search of our site with coolant light on
https://www.google.com/#q=site:slkwo...ant+light+on&*
#6 Old 03-22-2017
Roberto_Rodrigues's Avatar
Vehicle: SLK 230 Kompressor (r170) 1999
Other Toys: clk 200 Kompressor (w208), Kawa ZX-10, Heinkel Tourist 103, previous car MB C220 (w202)
Quoted: 114 Post(s)
Then is it your thermostat despite the normal temp reading...
In my r170 start exact like you...
after a while ...2/3 months later ... have found the washer tank broken...
it's common in r170, you have to make a little change when you get it out, and it will stop with "broken washer tank" dieses, i did it in my, still with old one, and no more annoing light on.
will publish the fotos so you can see/understand what's is going on.
maybe, not your case, but a lots of them are the same problem as i did
R
Roberto_Rodrigues is offline
#7 Old 03-22-2017
Quoted: 114 Post(s)
After removing washer tank, it was like this:
#8 Old 03-22-2017
Quoted: 114 Post(s)
like this was on a sunday.. no place to get one, new or used, have to repair it.
1- first, enlarge the cracks
2- fill it
3- with a telescopic mirror, see if its perfect inside
4- put all on place again, this compound that i use, works under water too, and it's ready to use, after 10/15 mnts
#9 Old 03-22-2017
Quoted: 114 Post(s)
and before fiting it in the car: prevent this for hapening again:
put the water heater on a vice (with some wood, for not damage it) and twist the whole assembly, so the bottom of the heater, does not site, so close to the plastic wall (near the pump) i twisted mine so it now seats +/- in the center of the wassher tank.
instructions for removing this pelican parts
and after put it in the car and fill with water, wait a few minutes, to see if it has another crack, my have one that was not visible, marked in red on picture.
have bought a new tank, but still waiting for this one to crack again, it has almost a year by now, no more annoing water lights on the dash, after this.
hope that it helps
R
Idiot101 likes this.
#10 Old 03-22-2017
Quoted: 114 Post(s)
Attached is a foto of the compond that i use, don't know the name of it in english, but its made by henkel, site: Home - Henkel AG & Co. KGaA and it's very good to repair dash cracks so common in r170's dash, after many years... like the one on the foto, that one, goes bellow steriling wheel, and crack where is the screw to hold it.
after a while, it can be cut, sanded, painted, i really like this product
102 MB likes this.
LED lamps in dome light (Facelift R170 only!) savcom General Modifications R170 10 03-17-2019 06:01 AM
RHD SLK230K R170 Coolant light and Secret Fuse Box Location Deano_liv SLK R170 General Discussion 16 07-04-2014 10:53 AM
Car stopping, Coolant leaking - All of a Sudden amh3891 SLK R170 General Discussion 9 07-03-2014 08:40 AM
Brake lamp Fuse Blowing/ASR Light devontone SLK R170 General Discussion 1 05-04-2013 11:26 AM
