Interior motion sensors - Mercedes Benz SLK Forum
#1 Old 04-08-2013
Vehicle: 2003 slk r170 2.0 kompresser
I have recently replaced a non working siren module as the backup batteries had leaked all over the circuit board.
I got another, fitted it, lock the doors , when i open the doors the siren wails and indicators flash as it should.
Problem is the motion sensors don't activate the alarm, the manual says you can turn them off by the combined ata/ims switch and that the light should flash when you turn key to position one and press the button but no light illuminates on the switch.
Its as though the ims are not connected even though they are.
Anyone else have this problem ?
Thanks, Jake
jakemate is offline
#2 Old 04-08-2013
Quoted: 6569 Post(s)
What are you driving?
‘Usercp’ at the top left of page, then ‘edit your details’ on the left side, ‘additional information’ near the bottom, edit your ‘location’ and ‘vehicle’
Want to post a picture? Start a new thread, make a post, click on the ‘paper clip’ or go to ‘advanced’ and then ‘manage attachments’ then ‘choose file’ then ‘upload’ and ‘submit’!
Moderator/Founding Member
#3 Old 04-08-2013
Hi there, it's a 2003 r170 2.0 kompresser uk model.
Satellite slave, tinkerer and meddler
jakemate is offline
#4 Old 04-08-2013
Please update your profile and post an introduction. see my welcome blurb above and moving this conversation to the r170 general discussion section.
#5 Old 04-08-2013
Thank you, I've just done as instructed. I posted an intro earlier.
Sorry
jakemate is offline
#6 Old 04-08-2013
Not a problem. Glad you are here. flag says uk but you might also want to update your location for our members in your neck of the woods
you did already
#7 Old 04-09-2013
Vehicle: 2002 SLK230
I have exactly the same problem but my anti tow away does not work either. Discovered this when I tried to turn it off on a ferry and like you did not get the correct sequence of flashing lights. I am going to ask the garage at the next service to see if they have been turned off which I understand is possible.
BlueMachine2.3 is offline
#8 Old 04-10-2013
PaulRUK3's Avatar
Vehicle: R171 SLK350 (2004) Black, 7G-Tronic, Airscarf, Parktronic, Red Heated Seats, AMG Bodykit, STUNNING!
Other Toys: C320 (W203 2000) Auto, Sadly Departed R170 SLK320 (sob)
Quoted: 17 Post(s)
If I remember correctly, the manual says to press the tow away switch/motion sensor switch when the key is in position 0 or 1, or removed completely. My switch will only flash with the switch pressed and key removed, otherwise, like yours, it doesn't appear to work. I can only assume that it works as I haven't found anyone to tow it away yet! Sorry, cheap gag! I realise I could have tried to find out if it had actually disarmed the motion sensor, but it was early in the morning when I was playing with the button and didn't want to disturb the neighbours incase it had (or hadn't if you know what I mean) worked. If I remember later, I will 'fiddle with my switch' again.
PaulRUK3 is offline
#9 Old 04-10-2013
Thanks for the replies
Yes I tried with the key out, and in position 0 and 1 to no avail.
I have access to a snap on modis diagnostic so I'll take it home tonight, it talks to body control modules including mercs but not sure if it can enable or disable sensors but it may tell me if they are turned off.
jakemate is offline
#10 Old 04-10-2013
Aycee's Avatar
Vehicle: 2002 Blue SLK 320
I believe the motion sensors don't work if the car is locked with the roof down. I tested my sensors by having the roof up, opening the drivers door window then locking the car. Waited a few minutes for everything to settle down then stuck my hand in the open window. This triggered the alarm. How did you test yours?
Aycee is offline
#11 Old 04-11-2013
I tested it the same way, locked the car with the window down, waited for a couple of mins and stick my arm in.
This was with the roof up.
Connected snap on modis but it doesn't have the function to talk to the body control modules or alarm
So if the ultrasonics don't work with the roof down surely it gets this information from a switch ?
My roof works fine but If I knew which switch I could test it.
jakemate is offline
#12 Old 04-11-2013
I never knew the R170 had motion sensors o_O
#13 Old 09-01-2014
Vehicle: SLK 200 2003-4 Kompressor (UK)
Motion sensors
Exactly where are the motion sensors located ? my friendly mechanic at the sailing club tells me that in his experience the first thing to do when they start to go off erratically is to check for spiders and the like moving into the sensors !
jawsnpaws is offline
#14 Old 09-01-2014
jawsnpaws,
#15 Old 09-01-2014
Vehicle: SLK
Quoted: 20 Post(s)
Is this an April fools joke? Does the R170 really have motion sensors inside the car? It would be cool if it did. But then, I am learning new things about this car every week. That's why I enjoy this forum so much.
Desert_SLK is offline
TPMS Sensors - which ones..? Seanhump SLK R171 General Discussion 6 05-23-2016 01:35 PM
Abs sensors Deccca SLK Parts For Sale 4 01-30-2013 09:11 AM
Aftermarket parking sensors curro101 General Modifications R171 142 06-28-2012 05:18 PM
