Windshield washer container - Mercedes Benz SLK Forum
 15Likes
  • 2 Post By Avel Du
  • 5 Post By WoZ53
  • 1 Post By sokoloff
  • 3 Post By S/RConcepts
  • 3 Post By sokoloff
#1 Old 03-19-2017
sokoloff's Avatar
Chats: 3
Quoted: 66 Post(s)
Figured I'd fill up the windshield washer container this morning. So I poured about three quarts of fluid in and hear the unwelcome sound of fluid dripping. Looked under the car and I see maybe a cup or two of the fluid had run out onto the garage floor. The good news is that I now have a three foot round clean spot on my garage floor. My question then is this. Is there an overflow on the container itself or is the only opening under the hood where it gets filled? If as I believe that there is only the one opening, then I've got an issue. At least it appears to be up high in the system, since it held so much of the new fluid.
The car has never been out in the freezing weather that I can recall and even if it had been, it always had freeze protected fluid in it. The only other thing I can think of is that a year and a half ago one of my family members misjudged the length of the front end and hit the garage door frame at the right front corner of the car. Damage wasn't terrible and it was more of a scrape than a dent, but I did take it to a body shop for repair. The hit had been hard enough to have damaged a couple of the plastic tabs that hold the grill on, so that had to be replaced. That was the only part that needed replacing. Wonder if that "bump" could have jarred the windshield washer container enough to either crack it or knock a tube off.
I assume the container is in the fender well behind the splash guard. If someone has a link to accessing and repairing/replacing that container, please share it. I'll do a search later to try to find something.
Len
1999 E300D 215,000 miles
sokoloff is offline
#2 Old 03-19-2017
Quoted: 2277 Post(s)
@WoZ53 @jbanks15 or @dbgrn can look up the diagram for the washer bottle which may show it's location.
I think you have access to epc anyway?
If so, just look up the part and the diagram may give the container etc location.
jbanks15 and sokoloff like this.
#3 Old 03-19-2017
WoZ53's Avatar
Vehicle: 2006 280 SLK Caspian Blue Metallic
Quoted: 387 Post(s)
Mercedes-Benz SLK 230 Windshield Reservoid Replacement | 1998-2004 | Pelican Parts DIY Maintenance Article
jbanks15, sokoloff, dbgrn and 2 others like this.
Welcome to the forum
Where search is your friend
and the info never ends
Tim Wozny/ WoZ
Eureka,CA
WoZ53 is online now
The Following User Says Thank You to WoZ53 For This Useful Post:
#4 Old 03-19-2017
sokoloff's Avatar
Chats: 3
Quoted: 66 Post(s)
Thank you - looks like I've got an unexpected job to do. Yes, I do have access to the EPC. As an FYI, reservoir is part #170 869 03 20 with an MSRP of $45 and a wholesale price of $33.75. Certainly not a deal breaker, especially when there is no labor charge.
Guess I ought to take it apart to see what's going on before I order parts I don't need.
Len
sokoloff is offline
#5 Old 03-19-2017
Vehicle: '02 SLK32 AMG
Quoted: 52 Post(s)
I'd personally check the washer pump line at the pump, there's a little plastic nipple on the end of the hose that just snaps onto the washer pump and has likely just come off. It happened on mine as well, there's not a lot keeping it on there.
Idiot101, Avel Du and WoZ53 like this.
S/RConcepts is offline
The Following User Says Thank You to S/RConcepts For This Useful Post:
#6 Old 03-19-2017
sokoloff's Avatar
Chats: 3
Quoted: 66 Post(s)
Thanks S/R, but I still need to get the fender liner off to see that correct? Seems to me with as much fluid as it took before it began to leak that my issue may be higher than the pump? Time will tell I suppose. If the hose to either the headlight washer or the windshield washer has come off, then one of those washer systems would not be working correct? That should narrow it down.
Len
sokoloff is offline
#7 Old 03-19-2017
Quoted: 52 Post(s)
Most likely the offending system would not be working correctly. When mine leaked out, I hadn't bothered to check to be honest
You would still need to pull out the reservoir to check, which isn't a bad job at all. Another possibility is that one of the grommets holding in the pumps has sprung a leak, in that case I could see possibility of the system working properly in spite of that.
#8 Old 03-19-2017
RLander's Avatar
Vehicle: 2001 32 AMG
Quoted: 138 Post(s)
Re-filled mine today (not all the way but put in approximately 2.5litres) and no leakage..
would say you need some kind of repair.
RLander is offline
#9 Old 03-19-2017
sokoloff's Avatar
Chats: 3
Quoted: 66 Post(s)
Tested both the windshield washer system and the headlight washer system and they both are working just fine. So that seems to be pointing me to either the reservoir itself or its associated grommets.
Len
sokoloff is offline
#10 Old 03-19-2017
curro101's Avatar
Vehicle: Slk 200K 2004 r171
Quoted: 528 Post(s)
You'll need to take your wheel and liner off to check, but it's a fairly common problem, usually due to the seal on the filler pipe...
curro101 is offline
#11 Old 03-19-2017
curro101's Avatar
Quoted: 528 Post(s)
Check this thread out:
https://www.slkworld.com/slk-r170-gen...reservoir.html
curro101 is offline
#12 Old 03-20-2017
sokoloff's Avatar
Chats: 3
Quoted: 66 Post(s)
Aha, a little research tells me that my leak is a feature and not a problem. I won't be digging into it further.
Mercedes Benz Workshop Manuals > SLK 230 (170.449) L4-2.3L SC (111.983) (2001) > Engine, Cooling and Exhaust > Cooling System > Coolant Filler Neck > Component Information > Technical Service Bulletins > Cooling System - Coolant Reservoir Leak Explan
jbanks15, Avel Du and devilman9050 like this.
Len
sokoloff is offline
#13 Old 03-21-2017
sokoloff's Avatar
Chats: 3
Quoted: 66 Post(s)
Jeff - think we/you should put up the entire service bulletin about the washer fluid container as a sticky for when this issue arises in the future?
Len
sokoloff is offline
Leaking Windshield Washer Reservoir GWHKahuna SLK R170 General Discussion 24 05-20-2019 05:37 PM
Windshield washer motor stevebis1 SLK R171 General Discussion 14 02-15-2019 11:11 AM
Adding Windshield Washer Fluid Into the Alfa Romeo 4C Is Not Exactly Easy Berliner Heckflosse Off Topic 1 01-17-2017 02:19 PM
Coolant & windshield washer lights on, windshield washer not spraying garricks SLK R170 General Discussion 2 10-11-2015 06:15 PM
Windshield Washer Spray DDS 350 SLK R172 General Discussion 4 12-30-2011 08:37 AM
