Can't turn engine off - Mercedes Benz SLK Forum
 10Likes
  • 3 Post By Avel Du
  • 1 Post By allenhh
  • 1 Post By allenhh
  • 1 Post By jbanks15
  • 2 Post By rbeckert
  • 1 Post By allenhh
  • 1 Post By Avel Du
#1 Old 03-19-2017
Vehicle: 2002 slk 230
Quoted: 21 Post(s)
Have a problem on my 2002 slk230.I cant turn the engine off, I can take the key out and the engine is still going....have to pull the fuel pump fuse to stop it.The key is a bit lose in the barrel but everything else turns off except the engine, sigh.Do you think just a new barrel will cure it or do I need a new ignation unit? Any thoughts would be appreciated
allenhh is offline
#2 Old 03-19-2017
Quoted: 2288 Post(s)
It's been a topic previously.
Try this:
Mercedes Benz SLK Forum - Search Results for SLKWorld.com Can't turn engine off
I don't think page 1 has any solutions but there are many pages.
jbanks15, allenhh and WoZ53 like this.
#3 Old 03-21-2017
Quoted: 21 Post(s)
Update, also my inability to spell engine, having left the battery disconnected for a few days, I reconnected it and all seems peachy, normal lights, engine starts and stops.Am I looking at a possible ignition switch problem or engine management problem?Do I start at the cheapest option and work my way up?The AA man seemed to think its something to do with the switch on the rear of the ignition unit.
Dont you just love intermittent faults.......
allenhh is offline
#4 Old 03-21-2017
Quoted: 6554 Post(s)
I fixed spelling in your title
How old is the battery?
#5 Old 03-21-2017
Depending on cost difference start with the most likely issue.
I generally start with quick/free fixes and work my way up.
Check out the number of threads where issues like this crop up.
Although not a guaranteed fix, the battery is often a good place to start.
As Jeff said.
Did you charge your battery whilst it was disconnected?
#6 Old 03-22-2017
Quoted: 21 Post(s)
No idea how old the battery is,but I didnt charge it when I disconnected it. I have another new battery so I think I will swop it over, as I know SLKs like a good battery (also thanks for correcting my spelling)
allenhh is offline
#7 Old 03-22-2017
As we've said, the slk wants and needs a great battery
not a good battery
not a good battery that one keeps recharging hoping it will resurrect itself
battery could have a bad cell or cells and still keeps starting the car after 'resting'
allenhh likes this.
#8 Old 03-23-2017
Vehicle: 2002 SLK 320
I can confirm/re-affirm the need for a GREAT battery. Bought an '02 SLK320 with 31,000 miles and drove it for a year. Last January it didn't want to start on first key turn. Turn key 2nd time and started and ran with no problems. Parked it, went into store, came out, same thing. Then transmission went into 'limp mode' (2nd gear). Did this over several days and I finally replaced the battery. Hasn't gone into 'limp mode' for past 8 weeks. Battery I replaced was an MB and date code seem to indicate Sept 2005!
rbeckert is offline
#9 Old 03-24-2017
Quoted: 21 Post(s)
and again
Hi all thanks for all the ideas,I have a new battery so will replace it.The latest trick is the remote wont lock the car, I have replaced the battery's, re synced the key, it locks OK with the button on the dash, but thats it.Is there a way to find out if the key is transmitting a signal(the red light flashes) or the receiver is working?
allenhh is offline
#10 Old 03-24-2017
Before you start chasing down the new problem change the main battery.
If your lucky, the new problem may be related.
A quick and free secondary check.
Take a look at the foam around the pse in the boot.
Check for damp, especially on the bottom.
Moisture in the pse causes all kinds of problems.
New Projector Headlights - Turn signals stuck on when headlights turned on - Used existing socket to fit tubeamps General Modifications R170 5 02-20-2018 06:14 PM
Need help: Remove bumper with turn signal permanently affixed to headlight riehl SLK R170 General Discussion 2 03-03-2017 04:08 PM
How to remove 3457A facelift front turn signal bulb out of holder jbanks15 SLK R171 General Discussion 38 03-04-2016 05:44 PM
How to fix turn signal hyperflashing if you have LEDs JaysonM SLK R170 class DIY 4 03-03-2015 12:47 PM
when do you turn traction control off? esqdg AMGs 3 09-26-2010 04:25 PM
