Smarttop install and BAS/ESP light after... I thought I broke something ;) - Mercedes Benz SLK Forum
 9Likes
  • 3 Post By mono
  • 2 Post By mono
  • 1 Post By jbanks15
  • 2 Post By mono
  • 1 Post By Avel Du
#1 Old 03-17-2017
Vehicle: 2003 SLK320
Other Toys: SL500, GL450
So I finally got my smarttop and installed it last night. Based on the instructions I saw I thought it would be easy and take 15 minutes tops...
Overall it took me about an hour and a half and it got dark before I was finished so I had to make the last 3 connections holding a penlight in my mouth. When you do something like this the first time give yourself extra time. You don't want to rush it. A couple of the wires were twisted around each other on my wiring harness and it was really hard to get enough slack on them to put the taps on.
I got everything in and made sure I hadn't left any tools sitting on the engine and when I got in to start the car the BAS ESP light was on... Did a quick search on my phone and the threads that came up here were all talking about which sensors may have gone bad and how expensive it was to fix, etc, etc and I was thinking "what the hell did I break?"
I tried turning the car off and back on and it was still there... so I decided to take it for a drive and see if it cleared the error and it was gone after about half a mile. I've tried restarting several times and it hasn't come back so I guess I didn't break anything.
I'm delighted with the smarttop so far. I've had SL500's (R129) since the year 2000 and I wish I had discovered the smarttop years ago.
I was a little apprehensive on the install because all the wiring insulation on my SL500s is rotting away and if you move any wires there is the chance that you will cause a short somewhere else. (I've had to replace the throttle body and main engine wiring harness on one of them and the other needs both replaced in order to pass smog so it's currently on PNO with the DMV and has been sitting idle in front of my house for 3 years.
All that being said it's not difficult if you can follow instructions. If I keep the other SL500 I will be getting a smarttop for it, and the first thing I will do to any future SLK is add the smarttop!
Thanks for all the pointers everyone!
jbanks15, Avel Du and RLander like this.
mono is offline
#2 Old 03-17-2017
Quoted: 6554 Post(s)
Glad you got it sorted
The SmartTop has been around a long time and covers all generations of SLKs
so any issues have been covered before and resolved happily!
the bas/esp light, usually comes on after driving for a bit or turning the wheel left and then right
had you disconnected your battery? if so, that is why
#3 Old 03-17-2017
Yes - I disconnected the battery before digging into all those cables (per the Smarttop instructions)
When I woke up this morning I searched on the computer and found a lot of other topics regarding the BAS/ESP and realized it had to do with disconnecting the battery. However when I was in a panic last night, the way I searched brought up threads having to do with bad sensors and the car automatically braking at speeds with this light on and I was getting myself more and more worried.
Nice to know that nothing was going on...
mono is offline
#4 Old 03-17-2017
you did see the part in your....oh what is it called....the owner's manual
about resetting the esp/bas?
#5 Old 03-17-2017
LOL - NOPE! I always look here BEFORE I look in the owners manual...
mono is offline
#6 Old 03-17-2017
Quoted: 2290 Post(s)
Aw!
You made Jeff blush!
Avel Du is online now
#7 Old 10-06-2017
6007.us
Padgett's Avatar
Quoted: 573 Post(s)
Found the nut gone on the negative battery clamp and musta broke contact. Got BAS/ESP. Found the cure on page 167 of OM but why not just say "Start engine, turn wheel full right then left and return to center. The BAS/ESP light should go off after a few seconds.
Padgett is offline
#8 Old 10-07-2017
Australian's Avatar
Vehicle: SLK 320 2002
Quoted: 85 Post(s)
Many of us have been caught with the BAS/ESP light after disconnecting the battery.
Australian is offline
The Following User Says Thank You to Australian For This Useful Post:
BAS/ESP light with codes. joeyuk SLK R170 General Discussion 4 02-11-2015 01:17 AM
BAS/ESP light discovery I think sokoloff SLK R170 General Discussion 0 06-16-2014 07:57 PM
BAS/ESP light Simprof SLK R170 General Discussion 10 10-17-2013 03:11 AM
Intermittent BAS/ESP light SLK320Bob SLK R170 General Discussion 14 04-08-2011 10:01 AM
