Indicator problems still! - Mercedes Benz SLK Forum
#1 Old 04-08-2013
Vehicle: 99 slk230k
Other Toys: Cars lots,Yacht-colvic atlanta 32..
My 99 R170 230k has intermittent indicators. I have looked for anything obvious but some days they just don't work. The hazards work fine and the indicators blink with the alarm. The bulb warning light is on, on the dash. Any ideas.
single is offline
#2 Old 04-08-2013
nimbusgb's Avatar
Quoted: 253 Post(s)
Is the stalk switch ok? Perhaps some contact cleaner sprayed into the switch?
nimbusgb is online now
#3 Old 04-08-2013
slk8907's Avatar
Vehicle: 2006 SLK55
Other Toys: 2011 SL63, 1979 450SL, 2015 MasterCraft X-2, 2002 SLK32-R.I.P, 2001 SLK320-SOLD
Quoted: 7 Post(s)
Maybe you need the stalk replaced. My high beam flash didn't work on 32 and on my 320 the high beam function didn't work at all. Both needed the stalk replaced.
slk8907 is offline
#4 Old 04-08-2013
Vehicle: 99 slk230k
My thoughts too. I'll check it out later.
single is offline
#5 Old 04-08-2013
Vehicle: 99 slk230k
Update after Merc. Specialists put it on diagnostic is instrument cluster for indicator prob and eratic fuel gauge. They want 800 to replace it.Any better solutions.I could do it myself.
single is offline
#6 Old 04-08-2013
nimbusgb's Avatar
Quoted: 253 Post(s)
There are a few on eBay for a lot less!
#7 Old 04-08-2013
Vehicle: 99 slk230k
Ok, just bought one. Are they easy to fit?
single is offline
#8 Old 04-08-2013
nimbusgb's Avatar
Quoted: 253 Post(s)
Pretty much but first things first is to remove the battery positive cable and do not reconnect it until all other wiring is reconnected otherwise you may end up with an airbag error that needs a trip to a stealer or at least a Merc independent.
If you want to test before all the panelling is back together then make sure any wiring / harnesses are connected before connecting the battery.
#9 Old 04-10-2013
Vehicle: 99 slk230k
Ready to start on replacing it so any tips apart from ones above? I really hope this works.
single is offline
#10 Old 04-10-2013
nimbusgb's Avatar
Quoted: 253 Post(s)
http://ryououki.no-ip.com/r170/ click on dissasembly then dash and centre console
The Following User Says Thank You to nimbusgb For This Useful Post:
#11 Old 04-10-2013
Vehicle: 99 slk230k
Ok, easy job done and fuel gauge now works and have 30000 miles less on the car BUT indicators are still not working even though diagnostic said instrument panel change would fix that too! Stalk time I think?
single is offline
#12 Old 04-10-2013
nimbusgb's Avatar
Quoted: 253 Post(s)
Well the really good news is you still have 700 in your pocket!
#13 Old 04-10-2013
nimbusgb's Avatar
Quoted: 253 Post(s)
Indicator stalk should be an easy replacement. I did my cruise control stalk some time ago.
#14 Old 04-10-2013
Vehicle: 99 slk230k
I have ordered a stalk. Funny thing is, all evening the indicators have worked. Differences being its raining and the engine has been hot most of today. It does seem to be better with a hot engine. Thanks.
single is offline
#15 Old 04-12-2013
Vehicle: 99 slk230k
Was all going well but how on earth do you remove the 10mm allen head bolt in the centre of the steering wheel? Its rock solid.
single is offline
#16 Old 04-12-2013
curro101's Avatar
Vehicle: Slk 200K 2004 r171
Quoted: 528 Post(s)
Get someone to hold the steering wheel and usually with a bit of brute force you'll get it !
I use a sawn off straight piece of allen key abourt 5cms long held in a socket from my socket set . Remember the longer the ratchet the easier it will be ..
curro101 is offline
#17 Old 04-12-2013
Der Flieger's Avatar
Vehicle: silver/red 06 350
Quoted: 123 Post(s)
...and use a quality allen key (more precise and the steel is harder)...that bolt will probably have been installed with some lock tite..
FUN 4 2
Der Flieger is offline
#18 Old 04-12-2013
Mensra's Avatar
Quoted: 400 Post(s)
If all else fails, remember the Mexican speedwrench! LOL
Mensra is online now
#19 Old 04-12-2013
curro101's Avatar
Quoted: 528 Post(s)
As Archimedes said :
curro101 is offline
#20 Old 04-12-2013
nimbusgb's Avatar
Quoted: 253 Post(s)
I have a set of top quality large allen keys that fit into an adaptor that fits a 1/2 inch socket drive. I couldn't get it loose with that. I took the adaptor and the correct allen drive down to the local tyre place and they popped it on to the impact driver they use for wheels and cracked it loose for me. I tightened it up using the normal socket wrench and drove home to complete the job.
Then I bought a pneumatic impact driver for my garage, surprisingly reasonably priced and a very usefull tool to have at hand.
I did assemble with a drop of loctite when I was done
