Transmission Connector Leak Even After Replacing Connector - Mercedes Benz SLK Forum
  • 1 Post By sghokie
#1 Old 03-12-2017
Vehicle: 2002 slk320
For the last few months I have been fighting with my transmission.
First attempt I tried to replace and install a URO connector, however I couldn't get the 7mm screw to catch, it was like the threads were different. I used the new o-rings with the old connector and put it back together after.
A couple weeks ago transmission went to limp mode for a minute or so.
I went to the dealer this time and bought their connector. This one fit without issue, however, there was some oil in the old connector + new o-rings. I cleaned everything up very well and put it all back together with the new MB connector.
A couple of days ago it went into limp mode for a few seconds again.
I just pulled the wire harness off to check for oil and sure enough, there was oil in there again. Not as much as before, but much more than a few drops.
So my question is if you put a new connector and o-rings and it still leaks oil, what is the next step?
I obviously don't want to go into limp mode.
The codes I have read from the iCarsoft are:
P0600 serial communication link error
p2001 Component N15/3 (ETC Control module) is faulty (current and stored)
P2404 The stop lamp switch signal from the traction system via the CAN bus is implausible (stored)
Forgot to mention, I replaced the brake switch a few weeks ago hoping to clear out the p2404 code. For some reason when I try and cleare out the transmission codes it will tell me that clearing has failed.
sghokie is offline
#2 Old 03-12-2017
sokoloff's Avatar
Chats: 3
Quoted: 66 Post(s)
Are you sure the ATF is coming from the transmission end and is not old ATF that had wicked up the cable draining back down? Have you checked the under the hood connector on the passenger right) side where the fluid wicks up to?
Len
1999 E300D 215,000 miles
sokoloff is offline
#3 Old 03-13-2017
I will look there later on when I get home.
It was much more oil there than I would have expected to see if it had wicked up.
Is that wire section replaceable without replacing the whole engine harness?
sghokie is offline
#4 Old 03-13-2017
No oil in the control box.
I did find a bunch of garbage under it though.
I will need to pull out the battery to clean it out from under the box.
sghokie is offline
#5 Old 03-13-2017
Quoted: 914 Post(s)
The transmission controller is inside the car, under the passenger carpet. This is where the wicking fluid does its damage. Did you inspect it too?
efair is offline
#6 Old 03-14-2017
Is that near where the radio amplifier is?
sghokie is offline
#7 Old 08-17-2017
Vehicle: 2004 Crossfire Coupe Limited, 60k miles. All original silver car.
Other Toys: 2016 Thor ACE 30.2 Motorhome
sghokie,
Seeing the exact same P2404 code and it will not clear, even after replacing the brake light switch as you did. BAS/ESP light is intermittent.
Did you find a fix? Thanks.
From your post:
"The codes I have read from the iCarsoft are:
Forgot to mention, I replaced the brake switch a few weeks ago hoping to clear out the p2404 code. For some reason when I try and cleare out the transmission codes it will tell me that clearing has failed."
tnrambler is offline
#8 Old 08-18-2017
Since putting the dealer version of the connector in I have no more leaks there and not had any more trans issues.
I have not had any more BAS/ESP lights either.
I don't think icarsoft can clear out some of the transmission codes.
sghokie is offline
R170 Manual Transmission Mount Confusion TrooperSlick SLK R170 class DIY 3 02-02-2019 07:23 PM
Replacing iPhone connector in console jlc1 SLK R172 General Discussion 4 05-17-2017 05:17 PM
Accelerating goes wrong once in a while Federiko SLK R171 General Discussion 3 03-12-2017 02:50 PM
Transmission issue after coductor plate, electrical connector, and fluid change M2-Motoring SLK R170 General Discussion 5 01-05-2015 10:38 AM
Replacing connector under seat Rich171 SLK R171 General Discussion 3 09-15-2014 12:13 PM
