2003 SLK230 - Won't start - Mercedes Benz SLK Forum
 10Likes
  • 1 Post By garbo7441
  • 1 Post By Avel Du
  • 1 Post By jbanks15
  • 1 Post By Avel Du
  • 1 Post By Avel Du
  • 2 Post By garbo7441
  • 1 Post By Avel Du
#1 Old 03-12-2017
Vehicle: 2003 SLK230 - Fire Mist Red
Other Toys: Every woodworking and air tool known to mankind
Hello everyone,
I am new to the forum, so please excuse any faux pas. We have a 2003 SLK230 with a little over 20k miles. Yesterday, I attempted to put a new CD in the changer and received the 'No Changer' message. Took the magazine out, turned ignition to 'on' then 'off', and reinserted the magazine. All is well with the CD.
This morning, my wife was leaving and the SLK will not start. Not turning over, no click. All dash board indicators activate and the batter is reading 12.85 volts. A search of the internet revealed it could be a K40 issue. I removed the unit from the vehicle and separated it from its case. No indication of bad solder joint, overheating, or anything amiss visually. Verified continuity in all fuses on the unit. It is possible it can still be the root of the problem? I also wonder if the CD issue was somehow related to the starting issue, as it seems to be an electronic/electrical problem
I will be extremely grateful for any suggestions anyone might have.
Thank you.
garbo7441 is offline
#2 Old 03-12-2017
Quoted: 2282 Post(s)
Your first post should be your introduction.
New Members Introduce Yourself Here - Mercedes Benz SLK Forum
The reason that we ask you to update vehicle/location details is to save repeating the same
information every time that you ask a question.
Also, this site is truly worldwide. That can matter when you ask for help and information.
Are you looking for a bonnet, or a hood, a boot, or a trunk? Makes a difference.
Driving on the left, or the right?
#3 Old 03-12-2017
Quoted: 6546 Post(s)
How old is the battery?
The slk needs a great battery, not a good recharged one
after checking the battery
reflow the solder joints. you cannot see itty bitty cracks
#4 Old 03-12-2017
Check your battery.
SLKs need a great battery. Good is not good enough.
How old is it?
Do you do lots of small journeys?
Use the car daily?
Any longer (15-20 mile) trips?
SLKs don't like to sit. 3 weeks tops for a fully charged battery.
#5 Old 03-12-2017
Great minds...Myk....
#6 Old 03-12-2017
Search is really good on this forum.
Always start a search with 'SLKWorld.com' to get forum specific results.
In your case
SLKWorld.com R170 won't start
Gives:
Mercedes Benz SLK Forum - Search Results for SLKWorld.com R170 won't start
But start with the battery. It's THE most common cause of issues.
How to age your battery:
Mercedes Benz SLK Forum - Search Results for SLKWorld.com how to age a battery
Good luck fixing.
Don't forget the Intro
#7 Old 03-12-2017
john hannon's Avatar
Vehicle: SLK320 Auto 2003
I do think you guys over egg this SLK's need a great battery mullarkey
Mine ran for a year on one well past its sell by date!!
Like all cars when it's flat the car won't start, but half an hour on the charger and everything works fine till the next three week spell when it's cold and the cars not started up
When my K40 was on its way out garbo7441 the first symptoms were that the starter motor just wasn't activating, try it an hour later and it was fine.
It then manifested itself in the starter motor not activating and the radiator fan spinning faster then the turbine on a 747 taking off.
I pulled the K40 and stripped it, all looked good.
I took the precaution of replacing it and I've had no problems since
Sent from my iPhone using Tapatalk Pro
john hannon is offline
#8 Old 03-12-2017
It WAS the battery
As suggested, I checked the age of the battery. It was a 72 month battery installed 11/10, thus it was over 6 years old. Took it to, O'Reilly and their tester stated it had 12.1 volts and 700 CCA. However, the tester advised to 'charge and retest'. Based on the age of the battery and statements here about SLK's requiring a very strong battery, I just went ahead and bought a new one.
Installed the new battery and we are back in bidness... Thanks for the help, everyone. Great!!!
The Following 2 Users Say Thank You to garbo7441 For This Useful Post:
#9 Old 03-12-2017
That is great news!
#10 Old 03-12-2017
Malarkey? see his post 8 above
#11 Old 03-12-2017
Mullarkey
#12 Old 03-12-2017
The thing with checking the battery?
It's easy and quick.
It's been the cause so often that it is a recommended starting point. Including checking terminals etc.
Then fuses.
Then K4/Starter et al.
The more electrical issues I read, the more often this is the fix.
It is not the only fix though.
Repair or Replace 2003 SLK230 Driver Side Mirror Housing? ezeman200x SLK R170 General Discussion 1 05-04-2016 07:59 AM
99 SLK230 Not starting/stalling Kuklaw SLK R170 General Discussion 1 09-29-2014 10:38 AM
1998 SLK230 Won's Start willymack SLK R170 General Discussion 2 07-19-2014 09:00 PM
2003 SLK230 Manual - Stiff Clutch Erok SLK R170 General Discussion 8 02-20-2014 09:35 AM
SLK230 Limp, Delayed start Stoli2112 SLK R170 General Discussion 6 02-18-2011 09:06 PM
