Condensation in headlight - Mercedes Benz SLK Forum
 5Likes
  • 1 Post By jbanks15
  • 1 Post By Delucas
  • 1 Post By Avel Du
  • 2 Post By Delucas
#1 Old 03-11-2017
Vehicle: SLK 230 2002
Can anyone tell me how I can get rid of the condensation in my headlights?
Thanks in advance
Sam
Samantha is offline
#2 Old 03-11-2017
Quoted: 6547 Post(s)
http://www.billsden.org/fileadmin/me..._82_10_419.pdf
#3 Old 03-11-2017
and using our 'search' feature (hint hint hint)
https://www.google.com/#q=site:slkwo...in+headlight&*
savcom likes this.
#4 Old 03-11-2017
Quoted: 2283 Post(s)
Whilst your thinking about the fix a temporary aid is to have the headlights on whenever you drive.
The heat generated helps reduce the problem.
Long term fix is the seal though.
It's not dear to buy.
Avel Du is online now
#5 Old 03-12-2017
Quoted: 1138 Post(s)
Thanks in advance
Sam
You can reseal your headlights with v good silicon sealent !
And while there off carefully clean the inside of lens you will be surprised how dirty they get but once you see the diff you will take the other side to clean .
Delucas is online now
The Following User Says Thank You to Delucas For This Useful Post:
#6 Old 03-12-2017
Thanks for that - I will try and have a go and see how I get on. They were both very misty when I got her but now one is completely clear and the other still murky!
Samantha is offline
#7 Old 03-12-2017
Thank you - very useful!
Sam
Samantha is offline
The Following User Says Thank You to Samantha For This Useful Post:
#8 Old 03-12-2017
Easy job to do just dont drop your headlight doing it .
Good quality sealent takes 24 hours to seal etc
#9 Old 04-10-2017
Other Toys: cars
I had same problems with my mazda. I recommend you to remove the lid and turn on the lights, standing on the spot. After 40-60 minutes they dried out and after installing the plugs, headlights no more fogged up. If this advice can not help you I recommend check here https://www.uzooka.com/mazda-headlights/ and buy new headlights.
nikolas 22 is offline
#10 Old 04-10-2017
Originally Posted by nikolas 22 View Post
I had same problems with my mazda. I recommend you to remove the lid and turn on the lights, standing on the spot. After 40-60 minutes they dried out and after installing the plugs, headlights no more fogged up. If this advice can not help you I recommend check here https://bwww.uzooka.com/mazda-headlights/ and buy new headlights.
No nead to replace headlights the sealent / rubber dries out / hardens etc over the circa 17 years of its life and re - sealing
With quality sealent and let cure for 24 hours does the job for a few more years .
#11 Old 04-10-2017
Totally agree with that.
Not only did we have this problem with our own 230, but I have read many threads on the issue.
The only two reasons that I can see to go for new headlights:
Damage, especially cracks in the lens.
Damage/Corrosion of the reflective surface inside the headlight.
Any rubber parts will dry out with time.
Sometimes lubrication of ignored seals can spring new life.
Failing that, new seals puts back the original flexibility needed for a good fit.
Delucas likes this.
#12 Old 04-10-2017
Its such an easy job to do and while there out upgrade the H7 headlight bulbs to Osram ones clean inside headlight plastic
And they will look like new headlights to for very little money .
Avel Du and Pictor like this.
#13 Old 04-10-2017
Other Toys: cars
thank you guys. i think it is better to go to service center, when we have problems with our cars
#14 Old 04-10-2017
If your not handy with tools then yes go to a specialist
But then you will never learn how do do things and some repairs are simple to do if you take advice from forums like this if you get stuck .
Wet Carpet - Passenger Side ??? - 230SLK AND Headlight Condensation Advice wanted as Well ?? Swini United Kingdom Region 5 11-26-2012 06:24 AM
Headlight condensation robby214 SLK R170 General Discussion 4 09-20-2012 02:24 PM
Headlight condensation? BenzOwner SLK R172 General Discussion 9 02-15-2012 08:22 PM
SLK 2001 - Condensation in Headlight Swini SLK R170 General Discussion 4 02-26-2011 01:45 PM
