LHS rear fog light out ?? - Mercedes Benz SLK Forum
 7Likes
  • 3 Post By nigxls
  • 2 Post By Avel Du
  • 1 Post By Avel Du
  • 1 Post By ExpatScot
#1 Old 03-08-2017
Vehicle: R170 230K 1999
Other Toys: Zodiac 550 RIB
Quoted: 14 Post(s)
Not getting any power to the lamp unit, although the RHS lamp is fine so I'm guessing the fuse is good.
Any ideas?
Also just remembered not getting power to the boot lamp also, could be bad earth? If so does anyone know where the earth is before I start dismantling the whole car
nigxls is offline
The Following User Says Thank You to nigxls For This Useful Post:
#2 Old 03-08-2017
Quoted: 14 Post(s)
Any ideas?
Cancel that I've just used the search function and found out that it's disabled from the factory
jbanks15, dbgrn and Avel Du like this.
nigxls is offline
#3 Old 03-08-2017
Quoted: 2290 Post(s)
If you really want it, you can have it activated.
Avel Du is online now
#4 Old 03-08-2017
Quoted: 14 Post(s)
Doesn't really bother me, I was just checking the car over for the MOT and it puzzled me.
The boot lamp is cured too, turns out I had switched off the interior lights when repairing my door cards.
Interior light needs to be activated before the boot light will work.
nigxls is offline
#5 Old 03-09-2017
sokoloff's Avatar
Chats: 3
Quoted: 66 Post(s)
But please don't. Can't tell you how annoying that is, especially those drivers who turn the foglights on when they are not needed.
Len
1999 E300D 215,000 miles
sokoloff is offline
#6 Old 03-10-2017
Too Late!
When you mix driving between LHD and RHD countries
and the offside fog is required by law...
You need both lit to comply.
Added bonus, should one fail you still have a fog.
However, those that use them as a rear DRL need
[edited to preserve membership] in a [edited to preserve membership]
as they are simply [edited to preserve membership].
You'd think the clue was in the name...
Fog light is for?
Bright sunny day in many cases.
dbgrn and TerryT like this.
#7 Old 07-15-2017
ExpatScot's Avatar
Vehicle: R172 2011 SLK 250 Edition 125 Iridium Silver/Black leather
Other Toys: Nice Swiss watches.
Activation of both rear fog lights
Thanks for this information. I've lived in Germany for many years where their discipline of using, and not abusing rear fog lights is much better than here in UK.
Thankfully, most cars now automatically switch them off with the ignition so that they aren't left on for days by mistake.
I'm returning to Germany for a road trip in September and want to have the other (in my case left hand side) fog light activated as well as the UK default of right side only.
Is this something I have to get done by the MB Dealer or is there another way?
And I promise never to use them unless it's foggy!
ExpatScot is offline
#8 Old 07-15-2017
It's a computer change, so the correct software is needed. DAS/STAR.
We have members with that ability.
Some MB Indy dealers can do it.
A list of common tweaks:
https://www.slkworld.com/das-star-cod...as-tweaks.html
ExpatScot likes this.
#9 Old 07-16-2017
ExpatScot's Avatar
Thumbs up
Many thanks. I have it in for servicing at the MB Dealer next month and will ask them to do it, hopefully FOC!
Cheers!
Don
#10 Old 02-24-2019
Vehicle: 2003 SLK (duh) 320, MT, black on dark gray
Other Toys: '91 Vanagon Syncro, 3.0L Subaru powered
I just found this thread from a search. I swapped out my stock tail lights for smoked housings with LED. Then while testing them, I noticed the rear "fog" lamp only worked on the left. "Weird" I thought, where they defective. Then I checked out the stock units I'd just removed, and there isn't even a bulb on the RH side. I wanted to be sure that this was correct before selling the originals on ebay, so I searched here. I feel validated that everything is OK, But as a Yankee, I would love clarification on what "rear fog lights" actually are, and why you'd run only one side.
Rev Root is offline
#11 Old 02-24-2019
Quoted: 6554 Post(s)
german car
so cars park on side of roads in germany
only 1 side gets lit on design for that reason
so drivers can see the parked car
also
Rear fog lights are designed to provide a powerful and concentrated beam of red light that can penetrate fog and heavy rain, which will make your car visible to drivers behind you. ... However, only the light on the driver's side is turned on to avoid confusion with brake lights.
and
https://www.autotrader.com/car-news/...side-ca-269684
#12 Old 05-27-2019
SLK World Junior Member
Thumbs up
thanks for the links and for the input
Nashi82 is offline
Rear left turn, right license and 3rd brake light not working milky2k SLK R171 General Discussion 6 05-11-2018 10:17 AM
Rear fog lamps. Waynifer SLK R171 General Discussion 5 08-07-2016 10:51 AM
Lose Wire/Connector behind right rear light Christoph SLK R171 General Discussion 2 07-29-2016 12:44 AM
Rear fog Lamp(s)... Who knew? Lioninstreet SLK R171 General Discussion 21 09-04-2014 12:11 PM
R171 oem driver rear light & 3rd stop light wts! Anual SLK Parts For Sale 0 08-28-2013 08:08 PM
