Help, 1998 SLK230 Kompressor missfire codes - Mercedes Benz SLK Forum
#1 Old 04-05-2013
Wheels52's Avatar
Vehicle: 1998 SLK Black Opal
Other Toys: 2010 SV6 Commodore 210kw, 4.7 Mtr Runnabout
Hi Great and Learned MB enthusiasts.
I have a problem with my 1998 SLK230 Kompressor, 89000km.
For a while now it has had a missfire at around 4500revs under load when accelerating and occasionally all through the rev range when cold.
I have a Carsoft 7.4 Diagnostice code reader and the car has shown the following codes:
0300 Off assessor / Off assessor Catalytic Converter noxious = Random Missfire detected
0303 Off assessor Cyl. 3/ Off assessor Catalytic = Missfire cyl 3
B1470 Fuel level indicator sensor B4 - open circuit
B1755 Serial Port K2 from the KLA/TAU panel with the instrument cluster : open circuit
I think i have a bad coil or two. I think the Cat converter may be unservicable as it rattles on startup and within 15 seconds stops rattling.
What are your thoughts?
Any help and advice would be appreciated.
[SIGPIC]Old but not broken!!
Wheels52 is offline
#2 Old 04-05-2013
Hopeless *** owner
stinger608's Avatar
Vehicle: 1999 SLK 230 AMG
Hi Wheels,
A plugged Cat converter can cause all kinds of issues including what your describing. Although it will usually be across multiple cylinders.
stinger608 is offline
#3 Old 04-06-2013
nimbusgb's Avatar
Quoted: 253 Post(s)
My 230 has been parked up for two weeks, when it went to bed there was nothing wrong with it, took it for a wash yesterday and it's running like a dog! Popping and missing all over! The only thing I've done is remove the roof module .... electrical.
nimbusgb is offline
#4 Old 04-06-2013
Wheels52's Avatar
I went to check the coil voltage and resistance today and the battery is a bit flat charging overnight and i will take it for a run after checking the coils. Then i will check the tempreature at the cat converters to see if there is a difference between the front and the back (they tell me this is one way of detecting cloged cat's.)
Wheels52 is offline
#5 Old 04-16-2013
Vehicle: 1999 SLK R170 230K
read live data when idling, give the engine a bit of throttle and see all readings if they check out.
My slk 230, 1999 gave the same misfire, o2 sensor, you name it... and it turned out to be the MAF- just that the carsoft could not figure that one out due to bad temp resistor in the MAF and I did not have sense to see something was wrong in intake air temp readings...
DarkBlight is offline
#6 Old 04-16-2013
REB_TN_06's Avatar
Vehicle: '06 SLK 280
Other Toys: Taylor 814ce
Just a general comment. I have read that SLK's do not handle marginal batteries well. All kinds of weird things start happening.
Best Wishes,
Gene
REB_TN_06 is offline
#7 Old 04-17-2013
Another hint; (which you might know but anyway..)
don´t go straight away spending money on a new coil but swap the coils and see if the misfire changes a cylinder.
Also, does your supercharger seem to operate normally?
Problem with Radio Code - 1998 SLK230 errjunior SLK R170 General Discussion 19 03-08-2016 05:07 PM
1998 SLK230 Kompressor missfire codes Wheels52 Australia 0 04-05-2013 08:17 AM
My new purchase a 1998 SLK230 angelbob New Members Introduce Yourself Here 24 03-18-2013 12:55 PM
1998 SLK230 top operation problems chess SLK R170 General Discussion 3 10-26-2012 02:13 PM
Selling my 1998 slk230 OEM headlights / OEM bumper park light / OEM side marker light (turn signals) afr00t SLK Parts For Sale 1 04-17-2012 03:23 PM
