Odd thing just happened, BAS, ABS, Brake warning Lights came on at the same time - Mercedes Benz SLK Forum
#1 Old 02-23-2017
Vehicle: 2002 slk320
This just happened, About 1/4 mile from work, I was driving about 25-35 mph, I felt a clunk sort of like the car down shifted a little stiff, haven't really felt that before. Then I notice that the BAS, ABS, and the Brake warning lights are on, also the gear number instead of D is just dark. I get to work and in a parking spot, the car is stuck in a higher gear than usual as I am pulling into the spot, then after about 5 seconds, all the warning lights go off and the car seems fine then.
Any ideas on this?
sghokie is offline
#2 Old 02-23-2017
Quoted: 2288 Post(s)
Any ideas on this?
From a site search:
Mercedes Benz SLK Forum - Search Results for SLKWorld.com ABS BAS and brake lit up
#3 Old 02-26-2017
Vehicle: 2004 SLK 230
Quoted: 18 Post(s)
90% sure its your Wheel speed sensor. Have the same problem with my Escalade. You have to replace the sensor, and or hub, if often comes"packaged" together. Check codes
Lepper is offline
#4 Old 02-26-2017
LeonardoDaBenz's Avatar
Quoted: 1064 Post(s)
As it did with my Magnum (there, it's called a "tone ring"). Scary when it happens, ain't it?
LEN
(Moderator)
Herbert Bayard Swope
LeonardoDaBenz is offline
#5 Old 02-26-2017
The speed sensor is what I was thinking it probably is.
Previously a few months ago I had attempted to replace the transmission connector with a URO branded version connector, this was a failed attempt, however, I couldn't get the screen to engage to hold the connector in. I ended up using the o-rings from the new connector with the old one.
I pulled codes again with the iCarsoft the other day and was receiving the same codes as before, 1 for the transmission connector and 1 for the brake switch, along with 2 I can't find anything about.
I purchased the $16 connector from the dealer Friday. I removed the wire plug from the connector and there was oil in there. I removed and replaced the connector with the MB part and had no issues getting the screw to engage this time.
I sprayed cleaner on the connectors and blew dry everything and put it back together. I replaced the brake switch also.
So far so good, however, I am still thinking that I might need a speed sensor.
Which one though?
I tried to clear out the codes from the transmission with the scan tool, but it kept coming back as unsuccessful.
The codes from the ESP system that I read are P1200-001 and P1202-001
I drove the car home on the day that it went to limp mode without issue (about 27 miles) and then about 65 miles since I replaced the connector and brake switch without issue also.
sghokie is offline
Daylight savings time changes tonight 2 am for those that participate. jbanks15 General Discussion 31 11-05-2018 10:16 AM
Daylight Standard time starts Sunday Nov 3rd 2 am for those that participate. jbanks15 Off Topic 8 11-02-2013 01:51 PM
For those of us in the USA concerned about our favorite shows getting renewed! jbanks15 Off Topic 5 05-11-2013 04:15 PM
How to have the main lights + the LED lights on at the same time? addictive SLK R172 General Discussion 7 08-09-2012 05:29 AM
