Mystery Noise ? - Mercedes Benz SLK Forum
 8Likes
  • 1 Post By Badger
  • 1 Post By Avel Du
  • 1 Post By Avel Du
  • 2 Post By dbgrn
  • 1 Post By Avel Du
  • 2 Post By dbgrn
#1 Old 02-23-2017
Vehicle: 2014 SLK 250CDI Tenorite Grey
Other Toys: Austin A40 Woodie Hotrod
Quoted: 16 Post(s)
Mystery Noise ?
Hi, I don't know if anybody might be able to help. Our R170 has started to occasionally make a loud "twanging" noise from the rear. This may happen if we go over a bump...though it does not happen all the time. It almost sounds like the noise a large spring would make. It seems to be from underneath, but could be from the boot. Any ideas please.
Badger
Badger is offline
The Following User Says Thank You to Badger For This Useful Post:
#2 Old 02-23-2017
Quoted: 2291 Post(s)
Not easy but get a look at the exhaust mounts underneath.
Handy if you have a friendly local garage for this one.
Remove the rear wheels and inspect the suspension behind them.
Your spring thinking is the more likely.
How is it handling?
If parked on level ground does it look balanced from say 20 yards away.
dbgrn likes this.
Avel Du is online now
#3 Old 02-23-2017
Almost forgot.
Push down on each rear corner with all your weight and release immediately.
Does it bounce straight back into place
Do nothing
Bounce like a rubber ball
#4 Old 02-23-2017
4 Ways to Inspect Your Suspension System - wikiHow
Also, look at the gap between the top of your tyre and the wheel arch and compare each side.
Should be a matching gap.
#5 Old 02-23-2017
dbgrn's Avatar
Vehicle: 2005 SLK 55 AMG
Quoted: 1035 Post(s)
I agree with Myk's comments above
... and I now realise why he's gaining on my post count so quickly... 3 separate posts for one update!
Seriously, I'd be wary of a potential suspension issue... I've read before that sometimes a small piece of the spring at the very top can break off, which makes it very difficult to see that it's broken.
- Dave
Mods:
(MB p/n A1718202075)
wind deflector
• Post-FL wing mirrors
• CF-effect interior trim
• AMG LED puddle lights
• Piecha DRLs
dbgrn is offline
#6 Old 02-23-2017
That was the problem that Daviethescaff had, if memory serves.
(the other way of catching up )
dbgrn likes this.
#7 Old 02-23-2017
dbgrn's Avatar
Oh, and if you're going to 'test' the suspension by pushing down on each corner, be very careful not to ding your wing while doing so! (thanks to Russ @55russamg for this shared 'learning').
55russamg and Avel Du like this.
- Dave
Mods:
wind deflector
• Piecha DRLs
dbgrn is offline
ID this 07 SLK55 Engine Noise Pls (VIDS ATTACHED) esqdg AMGs 34 04-23-2018 01:21 PM
Warm engine noise froome SLK R171 General Discussion 26 03-31-2015 12:13 PM
SLK 350 Annoying recirculation pump noise vibration – how common? Goggomobil SLK R171 General Discussion 3 09-18-2010 08:28 PM
