slk 230 2002 roof not working - Mercedes Benz SLK Forum
 7Likes
#1 Old 02-20-2017
Vehicle: slk 230 special edition black 2002
Other Toys: gsxf 750
Quoted: 14 Post(s)
Hi guys,
Ive just had the alternator fixed, now when i go to put the roof down i get no noise no nothing but the roof switch flashes, but when i push the roof switch forward i hear a noise as if the roof is trying to close even though its already closed, ive checked the relay and thats fine, any ideas please . Does the engine have to be running to put the roof down, although i have tried this and it still dont work.
many thanks matt.
muskey67 is offline
#2 Old 02-20-2017
1978L82's Avatar
Vehicle: 1998 MB SLK230
Quoted: 111 Post(s)
Originally Posted by muskey67 View Post
Hi guys,
many thanks matt.
You have to have the key forward at least, but best to have the car on if your battery is weak. Mine also does a bit of motion even when already closed. I guess it loses a bit of hydraulic pressure when sitting and so it builds it back up when you try to close again. As far as it not opening, check your shade roller. It is closed? if not, check that pin 54 on the roof module has ground. If not, the roller switch may be broken or it's not getting ground at the source (bolt in truck somewhere). If it is, then you'll have to go from there checking the the other pins as well. Efair just posted the pin numbers here on post #7 . https://www.slkworld.com/slk-r170-gen...em-solved.html
El_Toro_33809 and muskey67 like this.
1978L82 is offline
The Following User Says Thank You to 1978L82 For This Useful Post:
#3 Old 02-20-2017
RLander's Avatar
Vehicle: 2001 32 AMG
Quoted: 138 Post(s)
sounds to me like his boot cover is simply not put out, thats what happens in my r170 when the light flashes, just the boot cover (pull out l;uiggage cover) is not in place?
RLander is offline
The Following User Says Thank You to RLander For This Useful Post:
#4 Old 02-20-2017
Quoted: 14 Post(s)
ive tried that with no result.
muskey67 is offline
#5 Old 02-20-2017
Quoted: 14 Post(s)
il get busy on that tomorow thanks
muskey67 is offline
#6 Old 02-20-2017
Quoted: 6554 Post(s)
try these?
https://www.slkworld.com/slk-r170-cla...-blinking.html
https://www.slkworld.com/slk-r170-cla...ostic-aid.html
https://www.slkworld.com/slk-r170-cla...leapyfish.html
#7 Old 02-21-2017
snoopykissedlucy's Avatar
Vehicle: 2004 Mercedes SLK230
Quoted: 8 Post(s)
My best guess:
If I was changing out your alternator, I would have disconnected the battery for my safety.
I bet your problem is related to the switches being powered down.
I'm not sure about the top switches but I know the seat switches need to be reset sometimes.
Does anyone know if there's a procedure to reset the top switches?
snoopykissedlucy is offline
#8 Old 02-21-2017
devilman9050's Avatar
Vehicle: 2003 SLK230
Other Toys: ML280, CBR600
Quoted: 137 Post(s)
Originally Posted by snoopykissedlucy View Post
My best guess:
I found this on another post, my roof still has problems though so I couldn't say 100% whether it works or not:
Reset vario-roof :
• Switch off the engine
• Get out and shut the door and Lock
• Wait Min. 30sec
• unlock the car, get in and close door
• put the Key in the ignitionlock ( not switch )
• The roof switch with the left hand in the closing position
press and hold.
• Switch on the ignition with the right hand and the engine start .
• Close the roof .
• When no result :
• Disconnect the battery terminals . ( First minus then plus)
• Min. 30 minutes wait.
• Connect the battery terminals . ( first plus then minus)
• Repeat the previous steps .
devilman9050 is offline
#9 Old 02-21-2017
Quoted: 14 Post(s)
hi yeah i did disconect neg
muskey67 is offline
#10 Old 02-22-2017
Quoted: 14 Post(s)
ok guys i tried all those things still nothing happening.
muskey67 is offline
#11 Old 02-22-2017
Quoted: 913 Post(s)
Do you have an automotive test lamp, and are you comfortable reading a pinout diagram?
efair is offline
#12 Old 02-23-2017
Quoted: 14 Post(s)
hi buddy all i have is a multi meter. not sure what a pinout diagram is. just to mention ive just been out and tried to help the pull out cover in the boot by wedging a small socket into the switch tried the roof again with the engine running and i have this continuous clicking noise coming from over my shoulder and when it clicks the dash lights that are on go dim do you think that is related to this issue?
muskey67 is offline
#13 Old 02-23-2017
Quoted: 913 Post(s)
IDK what would cause a continuous clicking... I would find and fix that first.
efair is offline
#14 Old 02-23-2017
Quoted: 14 Post(s)
IDK is that related to the roof system? where do i find the IDK and also where is the roof module?
muskey67 is offline
#15 Old 02-23-2017
IDK means 'I don't know'
dbgrn likes this.
#16 Old 02-23-2017
Quoted: 14 Post(s)
told you i was thick, can you tell me where the roof module is and is it N10-3? And its quite a nightmare working out on the car in a storm but i wont stop.
muskey67 is offline
#17 Old 02-23-2017
Quoted: 14 Post(s)
right i found the n10-3 and know how to get it out but can it be opened up? and does anyone know if this would suffer from the dreaded dry or cracked solder joints? if anyone intrested i have a pdf on how to remove this module.
right i have taken out the n10-3 took it apart although theres loads of solders that dont look consistant with the others its all good and i have taken the k40 apart resoldered 2 contacts as they look dodgy put back together and no change what so ever so what does that tell you? is it a switch?
muskey67 is offline
#18 Old 02-24-2017
Quoted: 14 Post(s)
todays progress
well today i stripped out the boot lock sprayed it with electrical spray and gt85 and pulled the plug out next to pump a sprayed that with electrical spray let it dry plugged it back in and after, i tried the roof but i double activated the roof switch by mistake and the front windows went down but nothing else happened does this sound familiar to anyone? this is so confusing but hey slight progress.
muskey67 is offline
#19 Old 02-24-2017
double tap puts windows down
that is supposed to happen
just hold the button to the rear (if top is up) until something happens and do not let go
muskey67 likes this.
#20 Old 02-25-2017
Quoted: 913 Post(s)
Look at post 13 and 15 in this thread. The pinout shows the physical location of the various pins.
Measure the ohms resistance between each of the pins mentioned in post #13 and tell us what you measure for each. Also tell us the physical state of the roof while you made the measurements.
https://www.slkworld.com/slk-r170-gen...ere-start.html
efair is offline
SLK 230 Hydraulic Roof actuator repair Thud57 SLK R170 General Discussion 347 06-21-2019 06:16 AM
1998 slk 230 trunk opens roof fails [email protected] SLK R170 General Discussion 8 11-16-2017 12:45 AM
SLK 230 R170 Roof problem - Here we go again scoot_eruk SLK R170 General Discussion 19 05-20-2016 12:52 PM
2002 SLK 230 for sale Linarit Blue uncleCol SLK Cars For Sale 0 02-19-2014 03:21 PM
