help please - Mercedes Benz SLK Forum
 6Likes
  • 1 Post By Avel Du
  • 1 Post By macmike
  • 1 Post By john hannon
  • 1 Post By macmike
  • 1 Post By macmike
  • 1 Post By jbanks15
#1 Old 02-20-2017
Vehicle: 1998 r170 slk 230 designo copper
Other Toys: c220d bmw z3
help please
hi,my r170 slk 230 designo copper 1998 60k miles has a fault.Car only used in summer but I start up most weeks and drive round the block.Last week car went flat then cut out, it did start again and I got home only half a mile, few days later started up left on drive ticking over when it went flat again and cut out but will not start up now.I Think it was fuel related so checks ive done k40 fuse,relays and circuit board look ok no sighn of burns or damage, put a bulb test onto fuel pump connectors with ignition on 2 and no power then wired fuel pump to spare battery direct and it spun up ok.Put things back tried to start and it did fire up for a second I think fuel pump sent a little fuel through when I tested it.So that's it want to try and figure it out before getting technician in, THANKS.
macmike is offline
#2 Old 02-20-2017
Quoted: 2288 Post(s)
In truth you have so many potential sources getting it read is probably the best solution.
Check out the threads on the MAF which is an easy job.
'SLKWorld.com MAF'
Mercedes Benz SLK Forum - Search Results for SLKWorld.com MAF
Remember to clean the airway and not just the sensor or it will repeat.
Fuel pump may still have a fault even with power.
Filter could be blocked.
K40 can look ok but have micro breaks on the contacts.
Worth resoldering.
How long did this happen after your last fuel fill?
Did you fill to the brim?
macmike likes this.
#3 Old 02-20-2017
thanks, I will clean MAF also think I will change fuel pump and filter as not too expensive, then if no joy I will get a read on it,cheers.
LIL DON SLK likes this.
macmike is offline
#4 Old 02-20-2017
john hannon's Avatar
Vehicle: SLK320 Auto 2003
My K40 looked brilliant, even under a magnifier.
In desperation, Ł120 part but a 10 minute fit, I replaced it.
Started on the button since and runs sweet as a nut
Sent from my iPhone using Tapatalk Pro
macmike likes this.
john hannon is offline
The Following User Says Thank You to john hannon For This Useful Post:
#5 Old 02-20-2017
oh last fuel was a couple of weeks ago just topped up from 1/4 tank to 1/2 tank, thanks.
macmike is offline
#6 Old 02-20-2017
would a k40 fault show up on a diagnostic read ? cheers.
macmike is offline
#7 Old 02-20-2017
Quoted: 6554 Post(s)
Hi Mike,
See your intro thread to update profile please
First please update your profile with your location and vehicle year and model (year?: 1996-2016, model?: 32, 200, 230, 250, 280, 300, 320, 350, 55), if you haven’t already done so, as it helps the members answer your questions which usually are based on that information.
Follow this to update: ‘User CP’ at the top of page, then ‘edit your details’ on the left side, ‘additional information’ near the bottom, edit your ‘location’ and ‘vehicle’ (and then click ‘SAVE CHANGES’ button at the bottom of the page). Info in your garage does not update your profile.
macmike likes this.
#8 Old 02-24-2017
Update, cranked car over today and found no fuel going to rail,got a friend to put his reader on and only error was p1605 can abs speed sensor.Can this cut off fuel supply also where is this located,thanks.
macmike is offline
