R170 won't scan on OBD - Mercedes Benz SLK Forum
 3Likes
  • 1 Post By Avel Du
  • 1 Post By Durkatlon
  • 1 Post By Mn car guy
#1 Old 02-19-2017
Vehicle: 2000 SLK230
Quoted: 7 Post(s)
Hello all,
Anyone have an idea why it will not scan? Hooking up to the Mercedes OBD SCANNER and the output shows only exclamation marks. No other display. No check Mark's or fault codes.
First_timer is offline
#2 Old 02-19-2017
Quoted: 2288 Post(s)
Have you used OBD on it before?
Until the boffins arrive I think it may be due to different types of connector being used.
I think they look the same externally.
Have a look through the 'which scanner' threads.
I think it is mentioned in there.
Robrowdy likes this.
#3 Old 02-19-2017
Quoted: 7 Post(s)
Yes actually it worked on the same scanner a few months ago. I recently had an issue with something electrical and was shocked thru the ignition switch as I tried to start the car. Since then it has been cutting off intermittently after driving and starting the car repeatedly.
#4 Old 02-19-2017
Best that I can do is mention a few good names and see if they can figure it.
@Seanhump
@efair
@mchild @Sneaky Pete @Durkatlon @Zenman 63
They'll probably check in when next online.
Good luck
#5 Old 02-19-2017
Durkatlon's Avatar
Vehicle: 2009 SLK55
Quoted: 273 Post(s)
Sounds like something got fried :-(
Durkatlon is offline
#6 Old 02-19-2017
Quoted: 133 Post(s)
This will probably be a little tough to diagnose over the web but here goes. First off, I'd test the scanner itself on a different car. If I were you, I'd pray it doesn't work cause then it's an easy problem to solve: New scanner. If the scanner does work, the problem is likely related to the earlier problem. Can you go into more detail about what happened and what the solution was? Finally, why are you running a scan? Bored on a weekend or are you having an issue with the car?
Mn car guy is offline
#7 Old 02-20-2017
Quoted: 7 Post(s)
Hello and thank you for your reply. I did run scan on another car and it worked. It worked on my car before also. I am trying to understand because the bar has been cutting off intermittently after I've had issues when I started the car I got shocked. Ever since then some days it will run with no problem other days it will give me issues with trying to keep it started when I first crank up the car.
#8 Old 02-20-2017
Quoted: 7 Post(s)
Yes and apparently it is affecting everything to the OBD. Another using here thanks that it could be the K40 relay switch
#9 Old 02-20-2017
Quoted: 913 Post(s)
Did you have the key on when scanning?
efair is online now
#10 Old 02-20-2017
Seanhump's Avatar
Vehicle: 2005 SLK 55 AMG
Quoted: 424 Post(s)
Sounds like a short somewhere has fried something close to the OBD port - not sure if the 170 has a central gateway or not ....
Sean
Not the 'Probie' anymore..!
Mods so far...
Seanhump is offline
#11 Old 02-20-2017
Quoted: 548 Post(s)
Can't find anything in WIS about a CGW either. WIS does mention something like a Multifunction Control Module that seems to control various systems in the R170 like the wipers,PSE,lights,etc. As I understand it it also used for diagnosing and maybe also serves as the storage location for the DTC's. It is located in the engine bay, maybe something got fried in that area?
Sneaky Pete is offline
#12 Old 02-20-2017
Quoted: 913 Post(s)
No CGW in R170's.
The month and year of manufacture may be important here - what is yours? (see the label on the door jamb).It looks like X11/22 (OBD port) receives power from F1 Fuse 37. It is switched, so won't be hot if the key's not on. The car does not need to be running.
efair is online now
#13 Old 02-20-2017
Quoted: 913 Post(s)
Should've added: the OBDII port is connected to the ECU directly (but has its own +12V mentioned above, and its own ground).
efair is online now
#14 Old 02-21-2017
Quoted: 7 Post(s)
I had the key in position 2 and I also turned the car on during scanning both produced the same results
#15 Old 02-21-2017
Robrowdy's Avatar
Quoted: 245 Post(s)
Intermittent power could be the issue with the scanner. What does the exclamation symbols mean for the scanner tool you have?
Robrowdy is offline
#16 Old 02-21-2017
Robrowdy's Avatar
Quoted: 245 Post(s)
Sounds like maybe a ground wire issue. Be good idea to check your ground wire cable condition as well as the connection and make sure it is clean and corrosion free.
Robrowdy is offline
Cheap Diagnostic Scan Tools... JameSLK SLK R171 General Discussion 15 04-15-2017 10:07 AM
OBD for early R170 on the cheap PaulXLE SLK R170 General Discussion 25 06-04-2016 02:13 AM
R170 interior, supercharger, diff, hubs, doors, calipers for sale in merseyside kwthomas064 SLK Parts For Sale 5 02-21-2014 07:42 AM
Does Basset Slooper counts 4 a R170 Problem Berliner Heckflosse SLK R170 General Discussion 3 03-16-2012 12:22 AM
