Control box - Mercedes Benz SLK Forum
 7Likes
  • 1 Post By Markperry
  • 2 Post By jbanks15
  • 1 Post By markja
  • 1 Post By 1978L82
  • 1 Post By efair
  • 1 Post By efair
#1 Old 02-14-2017
Vehicle: 1998 230 slk
Other Toys: 1970 MGB GT O/D 1800
Question Control box
Hi, just wondering if anyone has photo's or a diagram of the control box next to the battery on a R170 SLK 230, as when trying a bypass method for opening the boot / trunk lid, buy grounding a thin grey wire with a mauve tracer (as instructed on a different site) all that happened was smoking from the associated control unit, and now i only have first and reverse and esp / abs / brake warning lamps lit that will not go out. I suspect I have fried the control module, but without a diagram, have no idea of its function, (other than it has no relevance to the roof) I have a 1998 R170 with the round O.B.D port in the same box of e.c.u's. A diagram of the box with labeled components, should help me sort this out, and in the near future, i could still need info on how to open the boot / trunk, as the operating rod from the manual boot / trunk lock has fallen off, and I was led to believe that grounding that wire, to override the luggage blind /tray was the solution.My car has no rear speaker holes so that's why i gave it a go, any suggestions / info greatly appreciated.
LIL DON SLK likes this.
Markperry is offline
#2 Old 02-14-2017
Quoted: 6554 Post(s)
BBB Industries - TSB's & Wiring Diagrams - End User License Agreement
Avel Du and Markperry like this.
#3 Old 02-14-2017
Vehicle: slk 170, 1997. blue. 230. and loverly!!!!
Other Toys: sports bike and canoe
Quoted: 38 Post(s)
The grey / purple wire is correct to ground but you have probably done the wrong wire. I will photo the correct wire on my car. The wire is at the rear of the box. Be careful, some wires appear to fit the bill but only one is proper colouring.
I stick a pin into the wire then join a thin speaker wire to the battery negative.
Markperry likes this.
markja is offline
The Following User Says Thank You to markja For This Useful Post:
#4 Old 02-15-2017
1978L82's Avatar
Vehicle: 1998 MB SLK230
Quoted: 111 Post(s)
Markja is correct. Ground pin 54. Grey/Violet to bypass the roller blind switch.
File Type: png Screen Shot 2017-02-14 at 11.43.35 PM.png (86.3 KB, 13 views)
File Type: pdf Screen Shot 2017-02-14 at 11.43.35 PM.pdf (73.7 KB, 19 views)
1978L82 is offline
The Following User Says Thank You to 1978L82 For This Useful Post:
#5 Old 02-15-2017
Quoted: 913 Post(s)
There are duplicate colors present so yes - use the pinout diagram to find the correct one. Letting the smoke out will ruin it...
efair is offline
#6 Old 02-15-2017
Quoted: 913 Post(s)
The roof module aka CCM is the right-most or "outboard" module BTW (at least in US cars).
efair is offline
#7 Old 02-15-2017
Thanks to 1978L82, Markja, and efair, for your help, But sadly had connected to the wrong wire, and have fried the module shown (see below)
I did however perform the roof manual unlock, and partially open the roof, couldn't depressurise it though as pump in trunk, but opened enough to see, if not reach the rod that has come off, as there isn't enough room to access it as the "C" pillars touch the unopened trunk. Has anyone opened the trunk another way, it seems i need to open it to sort the roof issues, or maybe i blew something (in the module pictured) that affect's it ?
More info.
The roof control button operates the Front windows down, and nothing else, when held back to open, but when pushed forward, flashes and a pump and latching sounds are heard, and front windows go up, any ideas on this one guys ? This was the same as it did when i first got it, except the trunk was open and wouldnt close, i pushed the roof control forward, the catch plate lined up and i shut the lid... and the rod fell off.
Then i fried this module..
Common and easy to do DAS 'tweaks' Seanhump DAS/STAR Coding 103 08-25-2019 04:55 AM
The Perfect Cup Holder Solution! Stinger General Modifications R171 127 07-22-2018 08:36 PM
SmartTop Roof module Install for the R171 etyu SLK R171 Class DIY 13 09-29-2017 09:49 PM
Mercedes-Benz Premieres Refreshed SLC Model Featuring MAGIC SKY CONTROL Using SPD-SmartGlass Technology at Detroit Auto Show Berliner Heckflosse Off Topic 1 01-11-2016 02:06 PM
Acronyms, TLA's and other abbreviations Seanhump General Discussion 3 11-20-2014 06:06 PM
