Engine cutting out need diagnostic help! Can send beer money! - Mercedes Benz SLK Forum
  • 1 Post By Opey521
#1 Old 02-13-2017
Vehicle: 2000 SLK230 Bahama Blue
Quoted: 12 Post(s)
Exclamation Engine cutting out need diagnostic help! Can send beer money!
I am in need of some help. I recently had an ECU that I got off of ebay for 80 bucks unlocked by Beckmann Technologies in North Carolina due to my ECU being bad. I then took it to a Mercedes dealer and had it reprogrammed, and now my car runs again. Yay! Since the reprogram, I have driven about 120 miles.
I want to explain the whole situation so that all the variables can be accounted for. When I removed the ECU I bent a pin in the ASR module and now I have and ASR/BAS light on. (I think this is completely unrelated to the engine issues, but I don't know.)
When I turn the car on, the fan runs on high all the time. When driving the car, it will accelerate regularly if the throttle is held below 1/4 position. Anymore and it surges violently, like the whole engine is cutting out intermittently. If I keep it at 1/4 though while driving and allow the rpms to slowly rise, they will, but then the car will not allow rpms over approximately 4300 when it starts violently cutting out again. Out of gear (I have a 5spd) regardless of throttle position, I can rev the engine up smoothly and quickly, but it is still limited to 4300 rpms.
Before the ECU was fixed, the car sat for over a month. I have pulled the K40 relay before and I could tell it had been repaired before. So, I have ordered an ASR module, a K40 relay, and a new MAF sensor in order to attempt to remedy this. I have also tried the ECU soft rest procedures, but it still has problems. Also, as I drive it more, it surges ever so slightly less as it revs up while driving, but still anything over 1/4 throttle , or at 4300 rpms the car starts surging violently.
I'm kind of thinking that it is in some sort of fail safe mode (if that exists) which is why the fan blows high and the rpms and fuel flow are all very limited.
If you can help diagnose this and it works, I will send you beer money via paypal. THANKS!
Gaby Rus likes this.
Opey521 is offline
#2 Old 02-13-2017
Quoted: 6573 Post(s)
just sayin' did you reset the esp per your manual?
see this thread as problem might be the same
https://www.slkworld.com/slk-r170-gen...ml#post3382954
#3 Old 02-13-2017
Vehicle: GONE - 2005 SLK350 Auto Caspian Blue/Beige Trim ,Heat, Light, Comfort, Premium, Ent. w/Nav
Other Toys: 1967 Chevrolet El Camino.2015 Charger R/T R&T B5 Blue
Quoted: 213 Post(s)
No Check Engine light? Get its codes scanned maybe.
Pioneer4x4 is offline
#4 Old 02-13-2017
Quoted: 12 Post(s)
Didn't know the ESP was a thing. Apparently neither did the Mercedes dealer that did the work. Also, no codes or engine light, I checked that right away.
Opey521 is offline
#5 Old 02-13-2017
from a search of our forum on fan running all the time
https://www.google.com/#q=site:slkwo...h+all+the+time
#6 Old 02-13-2017
Quoted: 12 Post(s)
Well I tried the esp sync thing, the ASR light didn't go out, but I'm thinking its the pin I bent and then "repaired" so ill swap the module. As for the fan, I'm thinking / hoping probably k40.
Opey521 is offline
#7 Old 02-18-2017
Quoted: 12 Post(s)
I replaced the battery, k40, brake light switch and maf. Car is running much better. Asr / BAS light remains on, and now it has smooth power, but cuts out at about 4300 rpms though. I suspect it it power limiting due to the asr/bas light. I took it and got the asr codes read, and it said it had a brake light switch code, but the code was cleared by the guy. No idea what to do next.
Opey521 is offline
#8 Old 02-19-2017
Vehicle: 2003 SLK 200 Kompressor
Other Toys: BMW R100 GS PD/C
Quoted: 29 Post(s)
Originally Posted by Opey521 View Post
Asr / BAS light remains on,... No idea what to do next.
Check wheel sensors?
Shalesy is offline
#9 Old 02-25-2017
Vehicle: 2001 SLK 200
Quoted: 7 Post(s)
Did u check abs control unit connection? I had the same issues..nearly the same diagnostics..just clean them connection and hopefully will do
Trimis de pe al meu SM-G900F folosind Tapatalk
Gaby Rus is offline
#10 Old 02-25-2017
Quoted: 7 Post(s)
Abs sensor needs a different diagnostic to be reseted
Gaby Rus is offline
Fuel additives and engine tick/tap/ping/knock/whine/sluggishness/hesitation and top tier gas jbanks15 Off Topic 252 3 Weeks Ago 01:31 PM
AMGPL: AMG 5.5-litre V8 biturbo engine Cold Shot AMGs 14 03-21-2010 09:11 AM
