N10-3 module location? - Mercedes Benz SLK Forum
 6Likes
  • 1 Post By LeonardoDaBenz
  • 1 Post By Okkie
  • 1 Post By efair
  • 2 Post By steve pring
  • 1 Post By savcom
#1 Old 02-12-2017
Okkie's Avatar
Vehicle: 1999 SLK 230 Kompressor, 2005 C350
Other Toys: Lotus 7's
Hi guys and gals
Can anyone advise me where I can find the N10-3 module? Any pictures? Trying to fix my vario roof.
How can I test the hydraulic pump?
I have been through all the posts but could not find a picture.
Many thanks
Okkie is offline
#2 Old 02-12-2017
Star/DAS Registered Owner
Quoted: 505 Post(s)
Originally Posted by Okkie View Post
Hi guys and gals
Many thanks
The Combination Control Module N10-3 is located - on left had drive cars, on the right side of the engine compartment next to the battery. If you wish to send me your email address by private message I can send you a picture of it.
mchild is offline
#3 Old 02-12-2017
LeonardoDaBenz's Avatar
Quoted: 1055 Post(s)
This help?
LEN
(Moderator)
Herbert Bayard Swope
LeonardoDaBenz is offline
#4 Old 02-12-2017
Quoted: 505 Post(s)
Originally Posted by LeonardoDaBenz View Post
This help?
That's it.
mchild is offline
#5 Old 02-13-2017
Okkie's Avatar
Thanks guys. I'll give it a try at the weekend.
Okkie is offline
#6 Old 02-13-2017
curro101's Avatar
Vehicle: Slk 200K 2004 r171
Quoted: 528 Post(s)
This might be helpful to you in the future:
SLK Home Page
curro101 is offline
#7 Old 02-14-2017
Okkie's Avatar
SLK Home Page
Thanks curro 101. No 12V+ at the relay on the pump. My car does not have a fuse next to the pump as I have seen in various photos. I can only assume that it is in the fuse box under the hood?
Okkie is offline
#8 Old 02-14-2017
curro101's Avatar
Quoted: 528 Post(s)
According to the fuse diagram, the 40A fuse at number 24 in the engine bay is for the hydraulic unit.
What does the red button in the centre console do when pushed?
Do the windows lower?
Does the trunk lid open?
curro101 is offline
#9 Old 02-15-2017
Okkie's Avatar
The windows (both front and rear lower.
The trunk lid can open and the red button remains lit after the trunk is closed - this tells me that S69/7 and S69/8 is not activated?
I don't hear the pump at all. Def. electrical supply issue. no 12v+ at the relay when the switch is activated
Okkie is offline
#10 Old 02-21-2017
Okkie's Avatar
Thanks guys.
Fixed my problem. Cleaned all the connectors at the K40and CCM. Restored power to the switch
M4rCu5 likes this.
Okkie is offline
#11 Old 02-16-2018
Vehicle: SLK32 AMG (2002)
Other Toys: Yamaha FZ1 (gen1) and DRZ400E
Quoted: 43 Post(s)
Does anyone know if this N10/3 CCM is the same for the face lift model. I have a 2002 which I need to some how bypass the boot micro switch that operates when the boot divider is pulled to enable the roof to open.
My problem is that I cant open the boot as lock is seized and now cant open the roof as the divider is not pulled up.
Long story by I did manage to open the boot by opening the roof and then trip the boot lock ,,happy days or so i thought .
Put the roof back up and then accessed my PSE pump but needed to retract the divider. Great so far,,,then I stupidly closed the boot which had locked again. No problem I thought.... I will do the same again but......this time the roof wouldn't open because I hadn't taped down the micro switch . Damn damn and damn again!!!!
Hence my question.
I did find the answer to how to do it but I feel this was for the pre facelift model so the wiring might be different and just needed some confirmation. Its PIN 54 apparently the grey wire with the violet tracer. OMG HELP!!!
Any help would be most grateful
Regards Steve
PS It also said the micro switch S69/10 can be bypassed through the Star Diagnostics... can any body confirm this please? Forum member i860 has be helping me so far but doesn't think his Star has the right programme to do this.
steve pring is offline
#12 Old 02-16-2018
savcom's Avatar
Quoted: 608 Post(s)
Hence my question.
Regards Steve
PS It also said the micro switch S69/10 can be bypassed through the Star Diagnostics... can any body confirm this please? Forum member I820 has be helping me so far but doent think his Star has the right programme to do this.
According to my files there is only one wiring diagram for the roof whatever the age of car you have. And yes, S69/10's sole purpose in life is "To connect ground signal through to combination control module (N10-3) when retractable luggage cover is closed in order to release the Vario roof opening/closing function." You are right in that S69/10 connects to pin 54 of N10-3 with a Grey/Violet cable and the microswitch connects between this cable and the W7 ground.
Also
Previous :
savcom is offline
#13 Old 02-16-2018
Quoted: 905 Post(s)
The pinouts and colors didn't change at the facelift - Pin 54, GYVT is correct. Don't need to disconnect or remove anything - just back-probe and jumper pin 54 to ground.
efair is offline
#14 Old 02-16-2018
Quoted: 43 Post(s)
Thanks for your replies guys. At least it appears I'm on the right track then.
The photo of the wires above is for a left hand drive pre facelift model.
Can anyone help me to narrow down my search for this Grey/Violet cable. I have taken off the cover to the black box next to the battery and I have never seen so many wires tightly packed in all of my life.
There is a long thin container that pulls up right next to the battery. Would it be in this area?
Thanks again
Steve
#15 Old 02-16-2018
Quoted: 905 Post(s)
It has by far the single largest connector in the box. For pin placement, see post 20 at https://www.slkworld.com/slk-r170-gen...ere-start.html
M4rCu5 likes this.
efair is offline
#16 Old 02-25-2018
Quoted: 43 Post(s)
Boot divider micro switch bypass success
Hence my question.
Regards Steve
For any of you that have been following my tales of woe with my seized locks and schoolboy errors, I have some good news to share if anyone has a similar issue in the future of trying to get into the boot by using the vario roof but forgot to put your roof divider screen back in place.
I had picked some of the best Mercedes brains around my area to ask if this micro switch S69/10 could in some way be bypassed to allow the roof to be opened. Lots of sharp intakes of breath and head scratching ensued.
Having done my homework with 'google being by friend' to quote a wise old sage, I knew that the small grey wire with the violet tracer leading to PIN 54 in the N10/3 CCM needed to be grounded. This was way beyond my pay grade.
In steps my hero Martin aka forum member Savcom who very kindly offered to help me and with the precision of a brain surgeon waved his magic electric wands in the direction of PIN 54.
One minute later he called out.....try the roof now!
I pulled back that magic red button we all know and love and ...Bingo... I could hear the familiar sound of motors springing into action as she started to open up.
Needless to say I was a very happy bunny and could now get on with my original task of sorting out my PSE pump.
After a thorough clean up it still doesn't open my central locking but I do now have my dome light working again .
So if any of you know a good PSE pump going for a reasonable price please let me know.
So I would like to give a big thanks to Savcom for his time and help with this issue and to Ross aka forum member i860 who has also provided me with his help and assistance too and finally to this forum which provides the vehical for all of us to share our woes and happiness our cars bring us
Cheers Steve
M4rCu5 and savcom like this.
The Following User Says Thank You to steve pring For This Useful Post:
#17 Old 02-25-2018
savcom's Avatar
Quoted: 608 Post(s)
To complete the story using Silkie as a model, here is a diagram showing the pinouts of N10-3 and a series of photos showing where N10-3 is located (note Silkie is a RHD car):
Under the bonnet beside the battery is a box of electronics that contains N10-3 (together with other components such as the K40)
Taking the lid off the box shows a number of modules and one or two wires ...
This is N10-3 outlined in green:
If you gently tease the wires apart along the centre line on N10-3 you can see the cable you need (you may need to cut the cable tie to get more access):
N10-3 pin 54 is the fourth pin (second wire) from the left on this part of the connector as shown with the arrow:
The 'magic' that I did for @steve pring was to use a multimeter lead to touch the metal connector at the end of the wire in pin location 54 and press the other end to the negative of the battery (you can use the ground point on the wing too). Holding the wire in this position Steve was then able to open the boot using the switch from inside the car to the point that the boot lid was fully open. He could then unlock the boot catch from the inside and pull the luggage cover into place.
M4rCu5 likes this.
Also
Previous :
savcom is offline
SRS Module Location Dazman1360 SLK R172 General Discussion 17 05-30-2016 08:05 AM
Location of ABS BAS ESP Control Module spacetiger SLK R170 General Discussion 7 10-25-2015 05:39 AM
R171 seat module location TWOPORSCHE SLK R171 General Discussion 1 09-04-2015 02:23 PM
Module Location Simprof SLK R170 General Discussion 3 12-22-2014 07:26 PM
ASR Module Location and Type Timdojo SLK R170 General Discussion 8 11-17-2012 09:58 PM
