Shifter knob removal - Mercedes Benz SLK Forum
 5Likes
  • 1 Post By DWCO
  • 1 Post By tcrankwa
  • 1 Post By Summerian
  • 2 Post By Summerian
#1 Old 04-03-2013
Vehicle: 2001 SLK 230 Kompressor
Would someone be a kind soul and tell me how to remove the factory original shift knob from the shaft?? Tiptronic?? I need to get into the shifter asm to adjust the left/right tension.
Thanks !
DWCO is offline
#2 Old 04-03-2013
Quoted: 6527 Post(s)
moving this question to the r170 general discussion section. the diy section is for established diys and if someone can assist, they will point you into the right direction
#3 Old 04-03-2013
this is for a r171 but might get you close:
http://www.formymercedes.com/Shift_K...ather_Boot.asp
try a search top right
#4 Old 04-04-2013
leapyfish's Avatar
There is a collar at the bottom of the shift knob
rotate the collar 1/4 turn.
Vario roof
R170 & R171
SLK 230 320 32AMG
leapyfish is offline
The Following 2 Users Say Thank You to leapyfish For This Useful Post:
#5 Old 04-05-2013
Thanks folks,
Finally got the pesky bugger off!!! Twist collar to the left..
DWCO is offline
The Following User Says Thank You to DWCO For This Useful Post:
#6 Old 04-05-2013
Hopeless *** owner
stinger608's Avatar
Vehicle: 1999 SLK 230 AMG
Originally Posted by DWCO View Post
Thanks folks,
Is this on an automatic or standard transmission?
stinger608 is offline
#7 Old 04-05-2013
Shifter
Auto.. with factory knob..
DWCO is offline
#8 Old 04-06-2013
Wizard of ID
tcrankwa's Avatar
Quoted: 22 Post(s)
Thanks !
This help?
https://www.slkworld.com/general-modi...automatic.html
Chris V Penn likes this.
Sportlich, Leicht und Kurz
Margie and Terry
tcrankwa is offline
The Following User Says Thank You to tcrankwa For This Useful Post:
#9 Old 05-10-2013
Other Toys: Traded them all!!
Quoted: 121 Post(s)
Thanks !
Various opinions out there but dead simple.
The black collar at the bottom of the knob itself rotates 90 degrees counter clockwise. It may be stiff - I had to wrap a rag on my water pump pliers to bump it free as it was on there for 12 yr. - but it will turn. The knob will pull off quite easily.
To replace it is easier to make sure the collar is mounted on the knob correctly. Just push it down on the shaft, put a bit of upward pressure on the collar and turn it 90 degrees clockwise.
I just replace a delaminated and cracked shifter gate panel and went through the same dilemma only to find it so easy it was embarrassing. Good Luck.
Alex 3 is offline
The Following User Says Thank You to Alex 3 For This Useful Post:
#10 Old 05-10-2013
wilsonpd64's Avatar
Vehicle: 2005 SLK350, Pewter w/chocolate interior.
Other Toys: None
I was worried for a moment- I thought somebody was going to take that classic 3 pointed star off in favor of an eight ball or a skull shifter knob.
I love looking down at the top of that shifter- just classy.
wilsonpd64 is offline
#11 Old 05-11-2013
Naffdave's Avatar
Vehicle: Looking used to own a 2005 SLK 280 and a 1999 230K
Other Toys: NSM Sattilite Jukebox
Quoted: 23 Post(s)
Send a message via Yahoo to Naffdave
I never seen the top of my shifter I sit so low cant see it ha ha
Dave
Naffdave is offline
#12 Old 06-29-2015
Question gate panel removal
Originally Posted by Alex 3 View Post
. . . I just replace a delaminated and cracked shifter gate panel and went through the same dilemma only to find it so easy it was embarrassing. Good Luck.
I'm having a similar issue with mine. (I think some super glue and some clamps might arrest the degradation . . . the panels are seemingly getting very hard to get a hold of.) Am I correct in understanding that there are 4 clips under the panel holding it in place? I can see 4 anyway, they look like they might be a bit tough to spring them all free at the same time. (And I'm a little leery of snapping them off!)
Any particular trick to getting it free?
lilred320SLK is offline
#13 Old 06-30-2015
leapyfish's Avatar
Have you removed the outer surround (#2 in the following pics)
after you have gently pried up the chrome surround,
then pry the outer surround,
that will expose the clips that hold the inner surround in place.
gently pry them open 1 at a time.
Vario roof
R170 & R171
SLK 230 320 32AMG
#14 Old 06-30-2015
Originally Posted by leapyfish View Post
Have you removed the outer surround (#2 in the following pics) . . . .
Actually I've had the whole console/dash apart - side to side and front to back. (Some of it's still in pieces actually! :-\ So getting to them isn't an issue, but since it's really tight, I wasn't sure what I was looking at. I probably should have tried to get it unhooked when I had the front console out . . .
I'll give it another look tonight. Hopefully there aren't any other loose pieces involved, and the shifter will still operate normally . . . ? (Mine is an auto . . . )
#15 Old 07-09-2015
The "trick" in removing the section around the shifter is to press the inner tabs in! (Not to try to pull the outer tabs (shown) out.)
#16 Old 03-22-2017
Summerian's Avatar
Vehicle: 2001 SLK320 Manual Transmition
Shifter knob surround panel
Hi, I have 2001 SLK 320 manual, the shifter knob panel seems a little different then this picture and i am scared to break it. How should I remove it exactly?
LIL DON SLK likes this.
Summerian is offline
#17 Old 03-22-2017
Join the gang! Your 1st thread should be your introduction so we can welcome you properly so post an introduction in the ‘New members introduce yourself here’ section, if you haven’t already. New Members Introduce Yourself Here - Mercedes Benz SLK Forum
#18 Old 03-22-2017
Mercedes-Benz SLK 230 Shifter Knob Removal | 1998-2004 | Pelican Parts DIY Maintenance Article
Mercedes-Benz SLK 230 Shifter Cover Plate Removal | 1998-2004 | Pelican Parts DIY Maintenance Article
#19 Old 03-22-2017
Summerian's Avatar
Thanks Jeff, I actually checked those links they are for automatic transmission but its probably the same for all.
I will update my info asap and do the introduction.
#20 Old 03-22-2017
remember you can reply to my private messages if you delete anything in your inbox and sent
you are limited to 5 messages until you get 15 posts
Cutler
Shift Knob Removal Sway SLK R171 Class DIY 25 07-26-2013 01:38 PM
Shifter knob and boot? touli SLK R171 General Discussion 9 12-10-2012 01:12 PM
Gear Knob removal JonB General Discussion 20 07-06-2011 07:17 AM
Removing Shifter Knob (automatic) tcrankwa General Modifications R170 0 05-27-2010 04:03 PM
Removing auto shifter knob? tcrankwa SLK R170 General Discussion 2 05-17-2010 12:27 PM
