230 slk kompressor 2000 SAS clock spring/squib has overheated/fused together & broken - Mercedes Benz SLK Forum
 3Likes
  • 3 Post By curlyp
#1 Old 02-07-2017
Vehicle: 2000 R170 SLK230 kompressor. RHD 6 speed Manual
Other Toys: Suzuki Katana 1000. Porsche Boxster. Honda CB750/4 K1. Shogun LWB.
HI good people... Out of the blue whilst driving along the horn comes on & stays on. Removed the fuse - horn still on. Disconnected the horns - silence at last. Then, when turning steering wheel, a grating noise behind the wheel. After dismantling & revealing SAS unit i found damaged "clock spring/squib" (3 core flat data cable) within SAS unit. Appears to have mildly fused itself together, hence, not allowing it to rotate with steering wheel & snapping. |Has anyone experienced this? I kinda guess a short circuit in horn or airbag circuit, but why are no fuses blowing? Any ideas?
jbanks15, LIL DON SLK and Avel Du like this.
curlyp is offline
#2 Old 02-09-2017
Quoted: 2290 Post(s)
Have you had the car read for codes?
Worth doing as it may narrow down the general area for the problem.
What you have found already may well be the source, but you also want the cause.
Search gives the following for the horn, which might help trace the rest of the problem:
Mercedes Benz SLK Forum - Search Results for SLKWorld.com R170 Horn stays on
Lot to go through and little that is quite the same.
Still, at least it gives your thread a bump.
Good luck
Avel Du is online now
#3 Old 04-27-2018
Vehicle: 2003 SLK200
Send a message via AIM to Gordon Fraser
I had exactly the same issue - had burnt through 3 clock springs over a period of years, (2 since January) - I took it in to a local garage who specializes in car electrics.
They traced it to a short on the break light switch - one of the cables was shorting out against the steering column causing the clock spring to burn out- from memory, it was on a wiring loom and they had to strip the steering column down.
No error codes showed up either and no fuses were blown.
The fuse box chart doesnt help - the fuse for this is in the compartment beside the battery on my R170- guess it will be slightly different on your car.
Hope this helps
cheers
Gordon
Gordon Fraser is offline
SLK 230 Splash Cover Missing jpowelso New Members Introduce Yourself Here 31 06-10-2015 02:15 PM
01 280 SLK bumper fit a 01 230 Slk? ziagroup SLK R170 General Discussion 4 07-25-2008 05:14 PM
