SLK32 SC oil change - Mercedes Benz SLK Forum
 9Likes
  • 1 Post By S/RConcepts
  • 1 Post By imola red
  • 4 Post By kentaggart
  • 1 Post By Mn car guy
#1 Old 02-06-2017
Vehicle: 2002 SLK32 AMG Black on Anthracite
Other Toys: Formula car
Red face SLK32 SC oil change
Hi everyone,
I seem to need help. I followed our esteemed JBANKS suggestion to do searches before posting a question. Well, I've read page after page both here and MBWorld but have not found correct information on the location of the drain/fill plug on the supercharger on a 2002 SLK32 AMG. One poster wrote that it was on the lower left corner of the front case but there is nothing on mine except one of the front case bolts. At 139K miles from a previous owner who did nothing in the form of regular maintenance, I am sure it is overdue to replace the SC oil.
I guess my question is do I have to remove the front pulley to even locate the plug? I can't even find anything on youtube!
Any information will be greatly appreciated and photos will qualify you to my first born!!!
kentaggart is offline
#2 Old 02-06-2017
Quoted: 6573 Post(s)
This is for a SLK 230 but still a r170 until the experts jump in
Mercedes-Benz SLK 230 Supercharger Oil Change | 1998-2004 | Pelican Parts DIY Maintenance Article
#3 Old 02-06-2017
Vehicle: '02 SLK32 AMG
Quoted: 52 Post(s)
The drain/fill plug is just to the left of the supercharger pulley, it's a 5 or 6mm hex plug IIRC. You won't have to remove the supercharger pulley, however you might want to remove the belt and idler pulley next to it for easier access. It's small and easy to miss.
S/RConcepts is offline
#4 Old 02-06-2017
Quoted: 52 Post(s)
I tried to post a photo, but my hosting website of choice seems to be down. So, here's a quick tip- crouch down so that you're looking at the idler and supercharger pulley face-on at eye level, and look directly in between them- right by where the casting leading to the idler pulley is. Use a flashlight (probably clear some gunk away), and you'll see it!
Edit: Thanks to jbanks, here's a picture: follow the screwdriver. Forgive the quality, I was trying to hold a flashlight and dial in my DSLR (not easy).
#5 Old 02-06-2017
#6 Old 02-06-2017
Vehicle: '04 SLK32 AMG
Other Toys: '01 M5 Imola Red
Quoted: 15 Post(s)
Look for Jae's build #38 . Good write up with pics.
Idiot101 likes this.
imola red is offline
The Following User Says Thank You to imola red For This Useful Post:
#7 Old 02-07-2017
You guys (and Gals) are aces. Especially S/RConcepts for the assistance. I looked at that thing for an hour and never spotted it. True to my word, you can have my first born. He's 48 already but he may be of some use.
Oil change coming up as soon as the oil arrives. I'll let you know how I make out.
Ken
#8 Old 09-17-2018
Vehicle: SLK32 AMG Obsidian Black 2002 RHD
How necessary is this?
Are there any signs to look out for that would indicate this needs to be done (noise or anything?)
To my knowledge, the SC oil has never been changed on my 2002 SLK32 AMG, certainly not since 2012 when I bought it.
Hubert1 is offline
#9 Old 09-17-2018
Idiot101's Avatar
Vehicle: 2004 slk32 amg
Other Toys: 69 GTX - Red!
Quoted: 265 Post(s)
MB doesn't address changing the S/C oil. But I changed mine simply because the car is 15 years old. Can't hurt!
The Toy
Idiot101 is offline
#10 Old 09-17-2018
Quoted: 52 Post(s)
IMHO, with how much strain the S/C is under on these cars (especially with higher mileage), I would file it under very necessary. Unfortunately, this is one of the most neglected maintenance items on these cars. Most M112K/M113K AMG enthusiasts recommend changing the S/C oil at 30k intervals, even though MB files this under 'lifetime' lubricant. Judging by the smell and state of the oil that came out of mine, a 'lifetime' was about 4 lifetimes ago!
This said, if you're hearing any type of internal noises coming from your S/C, it's much too late for a simple fix... hence, this small bit of preventative maintenance can save you potentially thousands in repairs. A can of Mobil Jet Oil (either II or 254) can be had for less than $30, and that can will give you enough for a true lifetime of oil changes!
M4rCu5 likes this.
#11 Old 09-17-2018
Quoted: 133 Post(s)
Getting the bolt out is the hardest part. After that, it's dead simple. As others have stated "why not"? Just dont get any on you if you're planning to 'get lucky' as it smells terrible.
M4rCu5 likes this.
Mn car guy is offline
What did you do to your SLK 'TODAY'? ichris93 General Discussion 7662 8 Hours Ago 11:59 PM
slk 55 amg oil change pokorny SLK R172 General Discussion 0 10-19-2016 05:48 PM
First time Oil change for my SLK 200 R171 Hui Sweetcheong SLK R171 General Discussion 0 05-30-2016 11:36 AM
SLK 200 R171 Oil Filter Housing/Oil cooler change/ seal change Chris J SLK R171 Class DIY 4 02-28-2015 01:35 PM
Oil Change Question razr-01 SLK R171 General Discussion 12 01-06-2011 08:44 PM
