Down on power - Mercedes Benz SLK Forum
 8Likes
  • 1 Post By Mn car guy
  • 1 Post By Avel Du
  • 3 Post By Jamec
  • 1 Post By Jamec
  • 1 Post By savcom
#1 Old 02-03-2017
Vehicle: 1999 SLK 230k
Down on power
My slk 230k seems to be down on power. I've done the gearbox reset but I'm sure it used to be more rapid and fun than it is, in fact on a local steep hill it almost struggled.
Now I did have some issues last September with the k40 relay and the car was misdiagnosed with a gearbox problem which resulted in the air mass sensor being replaced (probably unnecessarily) before I got round to fixing the relay myself.
I suspect the the kompressor is not working as it feels like there is no boost. Besides this there are no other issues and the car is tip top. Is there anything I should look/test for or tell the garage to look at first?
Jamec is offline
#2 Old 02-03-2017
Quoted: 133 Post(s)
It's pretty easy to tell if the super charger is working. I think the early ones have a clutch and it's set up to come on around 2,000 rpms. If it's not, it could be the connection at the back of the supercharger or it could be the k40 relay. How did you fix the relay? Did you resolder all the joints? Below is a video of a clk 230 which will show you how to visually see if the s/c is working.
Jamec likes this.
Mn car guy is offline
The Following 2 Users Say Thank You to Mn car guy For This Useful Post:
#3 Old 02-03-2017
Quoted: 2284 Post(s)
Does sound like you do have an issue.
Our 230 used to romp up steep hills. We were quite surprised how well it would go.
Jamec likes this.
#4 Old 02-04-2017
Thanks for the YouTube clip, very helpful. I've just had a look and as in the vid the clutch isn't engaging after the revs reach 2500 so this is my problem.
I changed the k40 in September and I am pretty confident that it has been this way ever since. I wasn't able to repair the old relay and got a second hand one from eBay. I've seen another thread on here re the kompressor where someone suggested the two could be linked, any ideas to what steps I could take next?
The car is perfectly driveable, just not as much fun!
Jamec is offline
The Following User Says Thank You to Jamec For This Useful Post:
#5 Old 02-19-2017
Had a technical friend (Audi tech) fit a new DAB stereo today (new pollen filter as well, old one was as black as the ace of spades) and he said he'd have a look at the supercharger as it could be something as simple as it not being connected properly.
Walked there after work in the glorious (for February) sunshine to see the dash all in bits and not quite finished and hadn't had the chance to look under the bonnet yet. So walked another three mile home.
Hour later he's outside with everything fixed and working including the supercharger. When I had the original k40 issues in September and the garage replaced the air flow meter they left something unconnected. Took him five mins to locate, diagnose and fix. Ł35 mates rates all in Inc filter. Very happy. Car very fast.
jbanks15, LetHerRyp and Avel Du like this.
Jamec is offline
#6 Old 02-19-2017
Quoted: 133 Post(s)
Good for you. Glad it worked out. We've had unseasonably warm weather (60f in Minnesota) and I've been driving mine everyday. Enjoy.
Jamec likes this.
#7 Old 02-19-2017
Minnesota that's a proper winter! It's only snowed here twice in 17 years, pushing 15c (59f in old money) yesterday which woukd be good for April. Not had the roof down though, will only do it May to September.
Jamec is offline
#8 Old 02-20-2017
now the car is ruining as it should I am going to follow J Banks' advice and have ordered some Techron. Once its ran through she will be getting an oil and filter change as its now been a year.
https://www.amazon.co.uk/Techron-Inj...ywords=techron
Jamec is offline
#9 Old 02-20-2017
savcom's Avatar
Quoted: 609 Post(s)
Only May to September? You're missing half the year James!
There's enough heat from the SLK to put the top down in quite unseasonably cool weather and not feel the cold. We've been out with the roof down in the sunshine when it's 2.5°C and I'm sure others will have been out in similar. And there's nothing to beat smelling wood fires as you drive through the villages in Sussex. Really puts a smile on your face.
The only thing to be slightly careful about is to make sure that the car has had a chance to warm up before dropping the top so as to give the pump and hydraulics an easier job of putting the top away.
Then enjoy!
Jamec likes this.
Also
Previous :
savcom is offline
Kia Ranks Highest in J.D. Power 2016 U.S. Initial Quality Study Berliner Heckflosse Off Topic 2 06-23-2016 04:03 PM
2015 Mercedes-Benz C-Class recalled for power steering failure Berliner Heckflosse Off Topic 0 01-08-2016 02:18 PM
SLK200 (2001) Power Loss Problem Nicksnake1 SLK R170 General Discussion 8 03-29-2014 01:27 PM
2010 J.D. Power survey results Santamonica SLK32 General Discussion 8 06-23-2010 01:51 AM
