SLK Oil in Coolant Radiator - Mercedes Benz SLK Forum
 9Likes
#1 Old 02-02-2017
Vehicle: Mercedes-Benz SLK 200 Kompressor, 2000cc, 197hp, 1999, 5-speed Manual.
Hi to all SLK owners!
I recently bought an SLK 200 KOMPRESSOR, with 192 HP, from 1997, with the engine M111.943. The engine itself is almost the same of the one used on the SLK 230. This is an exclusive model that Mercedes produced to some markets in Europe. After I recently changed the Water Pump, and made an oil change to a full synthetic 5W30, I start noticing oil slowly appearing on the coolant radiator. Some time ago at that oil change, I was able to inspect the car from beneath. And discover an oil leak on the passenger side of the engine. Initially I thought it was from the camshaft or the crankcase seals, an issue very common on these cars, but I start to suspect that the oil leak came from de headgasket. Firstly I thought that this issue was the oil cooler (oil in the coolant), but investigating further I suspect this type of engine doest have an oil cooler.
This way I came to ask to all the owners out there, if this is a head gasket job, or just some seals that are letting the oil in pressure go the coolant system.
In my opinion...the fact of being using a synthetic oil, might had made de already gasket leak get worst.
To first attack the problem I'll try to tight the head gasket bolts (yes I know it's not a good measure) to see if the leak into the radiator slows down. If doesn't make any difference at all, I'll try the full head gasket repair. The engine drives fine...just that issue of coolant being contaminated with oil. I already test the radiator for exhaust fumes, and there are none. That's the reason why I firstly thought it was an oil cooler problem, since this car have a manual transmission.
Hope to hear some opinions.
My best regards, Roger.
jbanks15, LIL DON SLK and Avel Du like this.
RogerM is offline
#2 Old 02-02-2017
Quoted: 6534 Post(s)
Roger,
Join the gang! Your 1st thread should be your introduction so we can welcome you properly so post an introduction in the ‘New members introduce yourself here’ section, if you haven’t already. New Members Introduce Yourself Here - Mercedes Benz SLK Forum
#3 Old 02-02-2017
Quoted: 2273 Post(s)
Hi Roger.
Thanks for joining SLKWorld.
Your first post should be your introduction:
Don't worry if English is not your first language. It is not important.
A search of our site gives:
Mercedes Benz SLK Forum - Search Results for SLKWorld.com R170 oil in coolant
Good luck fixing the problem and don't forget to post your introduction soon.
Avel Du is online now
#4 Old 02-02-2017
Vehicle: 2005 SLK 350
Other Toys: H20 V-Dubs, MK1s
Quoted: 411 Post(s)
Personally I wouldn't be driving the car at all until I figured out the problem. Maybe you can do a compression test to rule out a bad head gasket?
Roxanne7169 is offline
#5 Old 02-02-2017
Quoted: 133 Post(s)
You likely have one of two problems. Blown head gasket is a likely suspect. Replacing one is a pretty major project in an slk. The second possibility is it's transmission fluid. It circulates through the radiator to cool it. If the passages of the cooler crack, you'll get trans fluid in the coolant which looks fairly similar to oil.
Without giving offense, it seems that your car skills are a limited and it might be money well spent to take it to a repair shop to have it diagnosed. Continuing to drive it with either problem will lead to engine or transmission failure.
Avel Du and Robrowdy like this.
Mn car guy is offline
#6 Old 02-02-2017
Hey Roxanne7169! Yap, I'll try on a MB dealer for some diagnostic more conclusive. ;-)
Hi Mn car guy. I'd say my level of expertise in mechanics is between an average and a plus. When I started this discussion topic, was to isolate the major problem, since I have more knowledge in Toyota engines. My first thought, that took me to write this post, was the fact that this problem appeared suddenly after that water pump job, and didn't have any issues at all with overheating... or even presence of water in the oil. I'll try the local MB dealer to further testing. But to me for what I saw...the most headache part for de head gasket change on these SLK, is the timing belt part. So to all the readers who are thinking to make some head gasket repairs on an SLK R170 be very careful with the timing belt. Even some experience Mechanics get some headache changing gaskets in M111 engines, just because of the loosening timing belt procedure and reassemble. In this case I'm almost sure it's a problem on the head gasket, since it uses a manual transmission. Thank for the help. ;-)
LIL DON SLK likes this.
RogerM is offline
#7 Old 02-03-2017
Quoted: 133 Post(s)
I apologize for not reading your post correctly and I missed the fact that you have a 5 speed car.
#8 Old 02-03-2017
Mn car guy Mercedes introduced firstly the 5-speed manual in the SLK200 in some markets in Europe. This 2.0L engine is similar if not almost identical to the 2.3L engine. They made that for tax reasons, that incise over the engine litres. After a while, they introduced the SLK 230, with the same 2,3L engine global wide, and the 6-speed automatic. In my case, what had happened...almost for sure, it's the oil in pressure is travelling trough the head gasket (or other part) to the water circuit. That's the reason why in first place I'll try to re torque de head gasket bolts, and see what happens. The head gasket eventually is going to be change. The only thing that concerns me more, it's the procedure of removing and reassembly the timing belt (chain), cause I saw some online reviews, of people and experience Mechanics getting wrong the procedure, witch involves the loosening of the tensioner bolt, close to the water pump and after reassembly. I might well change the car, for a good deal on a SLK R171 or in an CLK. Some time...the better things in life is to move on, and forget the losses.
There in USA you are fortunate to have more flexible tax laws, and get some V8s. A car that I steel love, and is now very affordable there, it's the SL55 AMG. The SL55 AMG Black edition turns me on instantly while revving...still love that car. But in Europe, for the middle price sports car, we just can play more with 4 bangers, and some 6 bangers, for tax reasons.
Hope next summer go in vacations to the US, and rent an SL55 AMG to take to some speeding on the desert to Las Vegas....
RogerM is offline
#9 Old 02-03-2017
*"still love"... sorry I was just typing quickly.
RogerM is offline
#10 Old 02-03-2017
I added 'still' for you
#11 Old 02-03-2017
So returning to the initial problem... I try in first place the more quick approach to the problem, that in some cars does work, re torquing the head gasket bolts. But i eventually give up trying that, since the valve cover was too stuck to come loose...and I would end up destroying it, even with all the bolt loosen. In my point of view the only way to open that stuck valve cover, it's to use some razor sharp thing to cut it off, and replace it after. So I'll might order the kit parts to the head gasket job.
RogerM is offline
#12 Old 02-03-2017
I moved your intro out of this thread to the
new member introduce yourself section here:
https://www.slkworld.com/new-members-...ew-member.html
#13 Old 02-03-2017
Quoted: 133 Post(s)
If you decide you want to attempt it, here is an excellent guide. Although it's pretty straightforward, it does look like an awful lot of work and would likely take the better part of a weekend. 1998 Mercedes SLK 230 Head gasket removal & replacement
#14 Old 02-03-2017
Thanks for sending the link. Yes I already saw that website some time ago. The head gasket change will be made in an repair shop MB. But if I see that i can handle by my self...who knows. I think the worst part is dealing with the timing belt, that's why I'm not thinking to do the job. If it was like a brand new SLK, forget it, ...direct to the dealeas shop to repair. Since it's an old model, some times is good to have our hands get dirty...to make the bond with the car.
RogerM is offline
#15 Old 02-04-2017
Mn car guy, do you know where is located the oil cooler on the SLK230 engine, or if they have it?
RogerM is offline
#16 Old 02-04-2017
I read a lot of posting from other owner describing leaks trough the Oil Filter Housing, where there are some seal that can be weak. It mite be a clue to me...since this problem occur after a water pump change. In my view, de loosen bolts of the water pump...that also are connected to the Oil Filter Housing, mite have loosened the weak seals. What you all think?
RogerM is offline
#17 Old 02-04-2017
Quoted: 133 Post(s)
I'm not quite sure I understand but are you wondering if the oil filter housing could be leaking and the oil gets into a poorly sealed water pump? That would be a real long shot and if the water pump was improperly sealed so oil could get in, you'd have a very visible coolant leak.
#18 Old 02-04-2017
Mn car guy I'm talking about an internal seal gasket, that is just visible after removing all the front oil filter housing. This seal is behind the water pump, and near it, it's a high pressure oil gallery. Here are some links to some images of the Oil filter housing panel from a SLK230. But like you said, it's along shot in the dark.
https://www.google.pt/imgres?imgurl=...:&vet=1&w=1024
RogerM is offline
#19 Old 02-04-2017
The coolant levels are almost the same, just the oil contamination in the coolant reservoir, just after that Water Pump change, that's a reason for this theory, of a bad Oil Cooler seal. But of curse it's almost sure a head gasket problem, but who knows. One off the upgrades that I see in MB engines, it's the oil cooler design and relocation in the engine, maybe for a quicker maintenance of the seals. In the SLK230 the oil passes close to the water pump, and if you are unfortunate of having a bad seal, you have to take off all the panel with the oil filter housing attach. Newer MB engines, have the oil cooler closer to the oil filter housing, and it can be taken off individually from the rest of the panel, letting to be a easier job to replace the seals.
RogerM is offline
#20 Old 02-25-2017
One suspect cause for the oil leak into the coolant radiator...is on of the head bolts from the water pump. I decide to reseal the water pump gasket with some high temperature silicone, and discovered some oil in one of the longer bolts. So I resealed the all thing, including that bolt. Let's see what happens. That bolt passes over a high pressure oil gallery. When the water pump was changed, it might had rupture that wall, due to excessive torque or something else.
RogerM is offline
How to change/replace coolant tank on SLK 230 JaysonM SLK R170 class DIY 8 03-28-2018 03:55 AM
Oil at the Radiator reservoir tank. frankycordero SLK R170 General Discussion 17 02-02-2017 06:23 PM
2009 SLK 350, Mobil 1 0w40, Oil Analysis mb911 SLK R171 General Discussion 4 06-19-2014 02:34 AM
