Front Seat Heater Not Working - Mercedes Benz SLK Forum
#1 Old 01-31-2017
Vehicle: slk32 AMG, 2002
Other Toys: 328GTS, 951 Porsche track car, 528 BMW Sedan
The driver side seat heater in my 2002 SLK32 AMG is not working. Can someone tell me which plug is the source of power so I can detach it and check to see if there is voltage. That way I determine if the heating element is shot. The car has always been garaged and the seat heater was rarely used but I suspect flexing can break the heat element.
Also, I had attempted to remove the seat so I could more easily get at the plugs but could not loosen the bolts that hold the seat to the floor. The bolt heads are peculiar so I was afraid a normal socket wrench would ruin them because they are quite tight. What kind of tool fits these bolts? The bolt head looks like a coarse Torx bit. They are also used for block coolant drain plugs and probably elsewhere that I have not noticed.
lacoppari is offline
#2 Old 01-31-2017
Vehicle: '02 SLK32 AMG
Quoted: 52 Post(s)
I cannot recall which plug goes to the seat heater at the moment, but it shouldn't be too hard to trace once the seat is removed.
However, I can help with this- the seat bolts are E-Torx (stands for External Torx, aka Female Torx). If you'd like to do yourself a future favor, get a set of both standard Torx and E-Torx sockets, as you'll find both all over the car (especially the engine compartment). There's inexpensive sets all over Ebay, but I use Snap-On myself. They're a lot more expensive, but I've never broken one either, and the inexpensive Torx bits do like to twist and sometimes break.
S/RConcepts is offline
The Following User Says Thank You to S/RConcepts For This Useful Post:
#3 Old 01-31-2017
Vehicle: 1999 SLK230 W/Sport package
Quoted: 8 Post(s)
When i replaced the engine in my slk230 i needed these for all sorts of places under the hood and on the transmission. I bought these and they worked perfectly. Hope it helps.
6 Pc 3/8 in. Drive E-Socket Set
wolfords is offline
The Following User Says Thank You to wolfords For This Useful Post:
#4 Old 02-01-2017
Thanks for the inputs. I'll look for those E sockets.
Psngr electric seat won't go back, only forward grizzlyak SLK R171 General Discussion 13 07-11-2017 08:01 PM
Wow i used my seat heater today Berliner Heckflosse Off Topic 2 03-01-2011 04:44 PM
R172 Detail Specs UK-C200 SLK R172 General Discussion 5 01-19-2011 05:10 PM
