Brake Light Problem - How to remove the R170 Brake Light - Mercedes Benz SLK Forum
 5Likes
  • 2 Post By TFP
  • 1 Post By Mn car guy
  • 1 Post By Elmer Fudd
  • 1 Post By elkorn44
#1 Old 01-29-2017
elkorn44's Avatar
Vehicle: Designo SLK320 2002
Other Toys: 2016 Discovery 4, Caravan
Unhappy Brake Light Problem - How to remove the R170 Brake Light
I need to have a look at this problem on my SLK320 / R170 / 2002 model.
My RHS brake light has failed and I have the warning indicator on the dash.
I would like to try to rectify this, but cant see how to remove the light assembly to correct the issues. Can somebody direct me to the removal method?
Thanks.
elkorn44 is offline
#2 Old 01-30-2017
TFP
TFP's Avatar
Vehicle: 02 SLK32 AMG
Quoted: 151 Post(s)
Thanks.
If you're looking for a 'how to' video, have a peek here
TFP is offline
The Following User Says Thank You to TFP For This Useful Post:
#3 Old 01-30-2017
Quoted: 133 Post(s)
You might just need to replace the light. It's not necessary to remove the assembly to do this. You can access the bulb from the back of the assembly
pjb likes this.
Mn car guy is offline
The Following User Says Thank You to Mn car guy For This Useful Post:
#4 Old 01-30-2017
Elmer Fudd's Avatar
Quoted: 190 Post(s)
I didn't even get that wiggy
I just removed the inspection panel for the hydraulic roof pump ( behind that youtube clip owner's cd changer, at the bottom of shot, with a scoop handle visible) and went onward and upward from there.
Elmer Fudd is offline
The Following User Says Thank You to Elmer Fudd For This Useful Post:
#5 Old 01-30-2017
elkorn44's Avatar
Thanks for that. I have done the same thing, after locating the third nut at the top of the light by removing the upper trim.
I found where the nut was and then was able to reach it from below.
elkorn44 is offline
#6 Old 01-30-2017
elkorn44's Avatar
I have now removed the brake light, with some finger contortions to reach the nuts, and have found the following:
1. The lamp holder was "welded" into place and could not be moved. I used a pair of multigrips and some brute force to loosen and move it.
2. The plastic had overheated (see burn spot on the picture below). I had to file the distorted plastic to allow the holder to be re-inserted.
3. The lamp was also blown.
In addition to actions above, I cleaned the burned rail, and also built the contacts up using solder. (See pictures below).
I tested the electrical connections using a multimeter, inserted a new bulb and re-attached the assembly to the vehicle (again with some awkwardness).
The warning light is off, and the brake light is working.
Time will tell how long this repair will last. If this does fail again, my "plan B" is to solder a wire to the faulty contact and make the electrical connection permanent.
Time taken approx 1.5 hours, as I had difficulties removing the welded on bulb holder, and I did not want to break the fitting.
elkorn44 is offline
The Following User Says Thank You to elkorn44 For This Useful Post:
#7 Old 01-30-2017
elkorn44's Avatar
Thanks to all for help. The car really is just a standard vehicle, and quite easy to work on, provided you do some homework first. This forum is excellent value. Who knows what this may have cost me if I had taken it to a repairer to fix!
Elmer Fudd likes this.
elkorn44 is offline
#8 Old 01-31-2017
TFP
TFP's Avatar
Quoted: 151 Post(s)
The R170 was subject to a recall for it's faulty rear cluster, for exactly the same reasons your's is showing.
https://www.slkworld.com/slk-r170-ser...ht-recall.html
MB was aware of the issue and in the US it paid for replacements, but only in the US I believe
The rest of us either pay for the improved clusters ourselves, or do what you've done.
Thanks for the write-up and pics
TFP is offline
#9 Old 06-06-2017
RLander's Avatar
Vehicle: 2001 32 AMG
Quoted: 138 Post(s)
Thumbs down
Always wondered what the grips were for in this OEM tool kit, now I know.
That really is a terribly dang nab it fiddly fitting to get out and then back in again.
Thank you posters, I was almost convinced I had to get an entirely new (second hand) light for a day or so, was in the middle of writing an email going looking for a price on one then I thought...'I should double check'...
Same thing here, plastic under the connection melted - current fix is to simply bend the connection back up a bit (2-4 millimeters) safely away from the plastic probably wont last but who knows, might be lucky.
Not happy with Mercedes today especially as I bumped my head on the the boot latch on the way out of there after a frustrating 15 minutes.
RLander is offline
Rear left turn, right license and 3rd brake light not working milky2k SLK R171 General Discussion 6 05-11-2018 10:17 AM
NoRegret4Life's KLEYMAN Flashing 3rd Brake Light Module SLKman SLK R170 General Discussion 54 11-13-2016 06:58 PM
New Front Brakes 2000 SLK230 SLK R170 class DIY 20 12-28-2014 01:46 PM
The dreaded brake light problem mypennyblacks SLK R170 General Discussion 9 11-01-2012 08:16 PM
