Battery drain and fog lights on even with its fuse removed! - Mercedes Benz SLK Forum
  • 1 Post By curro101
#1 Old 01-25-2017
Vehicle: ML350 2006 60k miles, SLK320 2002 with 100k miles, C230 1997 150k miles
I have a 2002 SLK320 (100k), with battery drain issue.
I found the fog lights coming on randomly as if there is a wire moving loose. Few seconds and they are on for as long as the battery has power. The surprise is: even when I remove the fog light fuse, it would not go off. Note that when fuse is removed and the light is off, turning the fog light on doesn't turn the light on (confirming that the fuse is in fact for the fog light).
I changed PSE and Vario modules... nothing changed. I took the car to 3 dealers, no luck after $1500 diagnostic costs. I even swapped PSE with a friend's car, his car worked well while mine is still having issues.
I also checked the wires (as much as I could) but found nothing. the car is accident free and in a good shape. I don't know where or what to look for!
What should I do? please help.
samzin is offline
#2 Old 01-25-2017
curro101's Avatar
Vehicle: Slk 200K 2004 r171
Quoted: 528 Post(s)
Please update your car and location details in your user profile to help us help you better...
Have you had the car long?
Has this just started?
Does it have any module installed to use the fogs as Drls by any chance ?
curro101 is offline
#3 Old 01-25-2017
Had the car for a year, with the issue on from day one. I basically disconnect the battery every time I leave the car for more than 2 hours.
Everything in the car is Stock. If DRL is installed, it would be from Mercedes.
samzin is offline
#4 Old 01-25-2017
curro101's Avatar
Quoted: 528 Post(s)
Have you checked for parasitic drain on the battery?
curro101 is offline
#5 Old 01-25-2017
Vehicle: 2018 SLC 43
Other Toys: 2013 Lincoln MKT
Quoted: 142 Post(s)
Are you sure this isn't a Jaguar?
SLKomatic is offline
#6 Old 01-26-2017
mge_1's Avatar
Vehicle: 1999 SLK230 Sport
Quoted: 12 Post(s)
Send a message via AIM to mge_1 Send a message via Yahoo to mge_1 Send a message via Skype™ to mge_1
Same exact thing happens in my 99 SLK230 except it is the driver side parking light or that safety curb light or whatever the heck it is. I've done the fuse thing and etc as well. What a PITA!!!
mge_1 is offline
#7 Old 01-27-2017
Were you able to find a solution at the end?
samzin is offline
#8 Old 01-28-2017
mge_1's Avatar
Quoted: 12 Post(s)
I ended up buying a new (used) headlight switch assembly that I plan to swap soon. I'll check back shortly. Thanks
mge_1 is offline
Tags
battery, drain, fog, r170, slk
