Roof hydraulic problem - Mercedes Benz SLK Forum
 4Likes
  • 1 Post By Hdhostler
  • 1 Post By efair
  • 2 Post By dedgar
#1 Old 01-21-2017
Vehicle: 1998 slk230
Other Toys: Motorcycle
Thumbs down Roof hydraulic problem
The driver's side roof actuator was leaking hydraulic fluid. I replaced the o-ring. Put everything back together. Filled up the reservoir with the correct type of hydraulic fluid. Now the roof will not open on its own. I have to give it a push to open it. It retracts back into the trunk like it is supposed too. Everything seems to work. The trunk closes and I am ready to go. However, when I try to put the roof back up it comes out of the trunk ok and when the roof is overhead it drops like a rock into locking position. Does anyone have an idea what I am doing wrong? Or how to fix this? The roof was working properly before I replaced the o-ring. Thanks
1998 SLK230
LIL DON SLK likes this.
Hdhostler is offline
#2 Old 01-21-2017
Quoted: 914 Post(s)
Is the emergency relief valve fully closed? Try opening and re-closing it. And you're sure there's no other leaks, even small? It sounds like the pump is generating slightly below full pressure - like the pressure is marginal at the extreme. The roof actuators do the heaviest lifting, and it's at its heaviest during the first few inches of motion.
Robrowdy likes this.
efair is offline
#3 Old 01-21-2017
Quoted: 58 Post(s)
You have some air in the system. That will get 'flushed' out with more operation. You will probably have to give the roof a push the next several times.
This happened to me when I replaced my leaking cylinders.
El_Toro_33809 and Robrowdy like this.
dedgar is offline
#4 Old 01-23-2017
Gbarringer100's Avatar
Vehicle: 2013 SLK250
Other Toys: 2016 GLA250
Quoted: 101 Post(s)
Check the latch release did you reinstall that the cables releases the latch correctly. Remove the headliner and operate the top. It has been known that the cables are not releasing the latches and takes a little push on the top to release it fully.
Gbarringer100 is offline
#5 Old 01-23-2017
Robrowdy's Avatar
Quoted: 245 Post(s)
I agree with dedgar, you just need to wait for the air to be flushed out of the system seeing how you just rebuilt cylinder. It should get better with each operation.
Robrowdy is offline
#6 Old 01-26-2017
Roof Hydraulic Problem
I doubled check the relief valve and made sure it was closed. There are no leaks. I have opened and closed the roof at least 25 times and still have the same problem.
#7 Old 01-26-2017
Thanks. I have raised and lowered the roof about 15 times without success. I checked the relief valve to make sure it is closed and there appears to be no leaks in the system. I'll keep trying to bleed the system.
#8 Old 01-26-2017
The roof assembly works fine. It locks and unlocks fine. I just have to give the roof a little push before the roof automatically retracts. I only replaced the o-ring on the drivers side actuator. I'll keep trying to bleed the system.
#9 Old 01-26-2017
Thanks. I'll keep trying the flush the air out of the system.
I fixed my roof problem - Heres how. rodge SLK R170 General Discussion 68 07-14-2019 10:28 AM
SLK 230 R170 Roof problem - Here we go again scoot_eruk SLK R170 General Discussion 19 05-20-2016 12:52 PM
Another roof problem :( Help Needed Kowboy1 SLK R170 General Discussion 4 07-22-2013 10:40 PM
Roof opening problem Mats T Sweden 3 10-10-2010 03:17 PM
