99 SLK - Convertible Top Won't Open Manually - Mercedes Benz SLK Forum
 4Likes
  • 2 Post By efair
  • 2 Post By SLKKID
#1 Old 01-21-2017
Vehicle: 1999 SLK 230 MT
Question 99 SLK - Convertible Top Won't Open Manually
I'm trying to rebuild the hydraulic top cylinders on a 99 SLK. I rebuilt the roof top hydraulic cylinder and had no problems before moving the top up and down manually. After the repair I tried to operate the top normally, but I learned three other hydraulic cylinders were leaking. So now I'm trying to access the main hydraulic cylinders behind the seats and the top needs to be in the down position to access these hydraulic cylinders.
At this point, I have manually unlocked the top roof lock, the truck lid is tilted to the back position, rear vent windows are in the down position, the hydraulic pump pressure valve is open, but I can't lift up the top to open it - it's stuck in the closed position. When I'm trying to open the top manually, I can see it separating from the windshield frame, but it won't move any further. Are there any other locks or pins that need to be released to open the top manually? Thanks!
SLKKID is offline
#2 Old 01-21-2017
Quoted: 2291 Post(s)
Can't remember how I did it now.
Maybe these will help.
Mercedes Benz SLK Forum - Search Results for How to manually open R170 boot to get roof down
Avel Du is online now
#3 Old 01-22-2017
El_Toro_33809's Avatar
Quoted: 87 Post(s)
Sounds like you don't have the roof fully unlocked.
Tim
El_Toro_33809 is offline
The Following User Says Thank You to El_Toro_33809 For This Useful Post:
#4 Old 01-22-2017
Quoted: 913 Post(s)
There are two hinges, left and right, between the roof and the rear window. You can see these just above your shoulder. These hinges each have a safety mechanism (like a pocket knife) that prevents these hinges from folding until the safety is released. This is obviously what you're facing - you haven't released these safeties yet.
These safeties are cable driven from the front actuator. So even though you've turned the front latch (through the hole) to the point of unlatching the roof from the windshield, you haven't turned it far enough to tug on the cables. So put your allen wrench back in and twist it just a little bit harder. Watch the hinge area when you do this and you'll see it moving. Don't be afraid to put some torque on it.
El_Toro_33809 and Avel Du like this.
efair is offline
#5 Old 01-23-2017
Thanks for everyone's help! I looked at the top again and indeed the left side hinge lock by the back window was not releasing. Since the headliner had been removed, I was able to just pull the release cable for that hinge lock by hand. Also, the right windshield frame lock was not completely opening to release it from the windshield frame. A few taps with a screwdriver and hammer got it to the full "open" position. And... it seemed the top was stuck to the rubber seal on the windshield frame. I hadn't opened the top in about three months, so with the changing temperatures, the top was stuck on the rubber seal... I'm a bit concerned, though, with why manually turning the top release crank would not fully open the release hinge lock and the windshield frame lock. Hopefully, the locks will fully open when using the hydraulic cylinders... Anyways, I can now manually open and close the top again. Now I can access the main hydraulic cylinders... The repair continues... Thanks!
SLKKID is offline
#6 Old 01-23-2017
Quoted: 6554 Post(s)
gummi and lithium grease em!
https://www.slkworld.com/general-disc...ts-hinges.html
Tags
convertible top, open top manually
How to open to R170 Top manually? Arachnyd SLK R170 General Discussion 19 03-12-2018 12:09 PM
2000 SLK Open Top / Parcel Shelf Issue jpeter6981 SLK R170 General Discussion 3 08-13-2015 08:03 PM
Smart Top Supercharged591 General Modifications R172 43 10-29-2014 07:22 PM
Manually release trunk for top to go up or down.... dpoppitt SLK R170 General Discussion 4 09-04-2014 09:55 PM
