ignition switch FYI - Mercedes Benz SLK Forum
 8Likes
  • 1 Post By 04slk230
  • 1 Post By jbanks15
  • 1 Post By efair
  • 1 Post By Anthony in Australia
  • 2 Post By M4rCu5
  • 1 Post By m70ab2
#1 Old 01-21-2017
Vehicle: 2004 slk230 kompressor
ignition switch FYI
Ok
I don't know how I can work on this thing (sk230) when I can't figure out how to use this forum..to many things going on around me, I guess...but anyway
Apparently the previous owner installed an aftermarket radio the only thing I can think is it is wired incorrectly along with the vacuum pump problems but one thing at a time, but here's the problems
1) no alarm
2) no remote locking...but the lights flash with the key & doors lock upon driving & unlock when I open the drivers door including trunk
3) the lock and anti tow control on the console don't work* this is where I think some of the ignition problem comes from...I tried to lock the car with it and then the car wouldn't shut off...maybe coincidence...?
to shut the engine down:
first loosen NEG battery cable...because you will have to disconnect it immediately after you pull the ignition fuse because the switch is in the run position and everything goes crazy... fans lights etc.
last time I left the cable of and fuse out till I replaced the switch and everything worked fine once I reconnected everything
The hardest part is removing the ignition lock assembly to remove the switch... and very time consuming to remove all the dash panels and instrument cover without breaking them...that's $500 worth of parts...ask me how I know that...NO DON'T...but mine were cracked when I got it..
I replaced the brake light switch last week pretty straight forward & I'm waiting for a tensioner pulley because that went bad along with the ignition switch... at least it wasn't the water pump... as I thought...!
Does anyone know where I can find a wiring diagram for the ignition switch and/or radio, lock and tow switch...and just how much can I do before the car locks me out and won't start..? THAT'S MY BIGGEST FEAR
I love the way it handles when it runs ( I know you don't like the noise from the sport comp 2 but they stick to the road really good)...but it doesn't seem to be running much...I might have bit off more than I can chew on this one and it's my only vehicle.. and can't afford another one shame on me...!
any help with the wiring diagrams would be greatly appreciated...and help to read the response would be great too...what do you want from a retired pipefitter/welder..????
thanks for your help
Harry
04slk230 is offline
#2 Old 01-21-2017
Quoted: 6573 Post(s)
wiring diagrams here:
BBB Industries - TSB's & Wiring Diagrams - End User License Agreement
#3 Old 01-21-2017
Quoted: 914 Post(s)
None of your symptoms align exactly with the usual symptoms but if you're comfortable doing so, remove the K40, disassemble it, and re-flow all the solder joints on the PCB. You don't need to remove or add any solder, just melt the solder on each connection for a second or two.
A STAR scan might reveal additional helpful information.
You have a confusing set of symptoms, and I'm guessing you have multiple issues. Disconnecting the battery while the car is running cannot be healthy for the electronics.
efair is offline
#4 Old 02-13-2019
Vehicle: SLK320 2001
Other Toys: Volvo 242GT turbo, Macan
BBB Industires wiring - BRILLIANT
Thanks Jeff
Anthony in Australia is offline
#5 Old 02-14-2019
Vehicle: 2002 R170, 230K
Quoted: 17 Post(s)
I say leave K40, PCB and all that stuff alone for now. You don't know that that's where the problem lies and if you mess up with soldering there you might be left with a bus ticket.
Tackle one problem at the time.
Did you already replace the ignition switch? If not, check the wires with voltmeter/test light to see if any are hot/dead when they shouldn't be (so check all of them in all key positions). My guess, one is hot at all times when it shouldn't be. That can happen if wires get hot, insulation melts and 2 wires get shorted. It can be inside the switch or somewhere else.
As for alarm, this is probably related, as the car might not turn the alarm on when it thinks it is still running. Do dome lights and the trunk light work? They share fuse 9 with the alarm (I think).
m70ab2 is offline
#6 Old 02-14-2019
M4rCu5's Avatar
Quoted: 257 Post(s)
It'd be nice if people would come back with a conclusion to threads that they started to let us know what happened next, did it ever get fixed? if so, what was it? etc. etc. doesn't happen enough but there we go. It's not just this forum but pretty much every forum, car related or otherwise.
It's about now that Jeff dives in with his "this thread's over two years old, 04 slk230 hasn't been here since last August, here's a few links to to help you to avoid posting in old threads .. "
@jbanks15
jbanks15 and Australian like this.
M4rCu5 is online now
#7 Old 02-14-2019
@jbanks15
We have a new mini me!!!
My limit for nagging varies.
M4rCu5 likes this.
#8 Old 02-14-2019
Quoted: 17 Post(s)
LOL, I didn't even realize this thread is so old
Maybe close it?
m70ab2 is offline
#9 Old 02-14-2019
Not that old. 2017...good for a few chuckles
Instructions/pics clutch pedal ignition lock switch or light switch tlc2032 SLK R171 General Discussion 12 10-22-2016 05:40 PM
GM fund rejects 91 percent of ignition switch claims jbanks15 Off Topic 0 08-25-2015 11:19 AM
Chrysler recalls 350,000 vehicles on ignition switch issues jbanks15 Off Topic 1 09-25-2014 04:22 PM
Can't see your ignition switch at night..? - Read on... Seanhump General Modifications R171 24 12-23-2013 12:09 AM
