2003 Slk230 belt tensioner pulley question - Mercedes Benz SLK Forum
  • 1 Post By dedgar
#1 Old 01-19-2017
Vehicle: 2003 SLK 230
Yesterday the drive belt tensioner pulley bearing failed. This resulted in the pulley falling off and the belt coming loose. I replaced the pulley and both belts and everything is good. Out of caution I would like to go back and change the supercharger tensioning and idler pulleys. When I look online I see the supercharger idler pulley and the drive belt tensioning pulley but don't see a like part for the supercharger. Is it the same pulley as the drive tensioner or is it a Mercedes only part? I appreciate any help you can give me. Thanks, Charlie
Chasu is offline
#2 Old 01-19-2017
Quoted: 6547 Post(s)
Until the r170 experts show up, you might find some info here:
Mercedes-Benz SLK 230 Supercharger Removal | 1998-2004 | Pelican Parts DIY Maintenance Article
and here:
Mercedes-Benz SLK 230 Drive Belt Replacement | 1998-2004 | Pelican Parts DIY Maintenance Article
#3 Old 01-19-2017
Thanks Jeff. I used their belt pictures to properly install the replacement belts. Pelican has been very helpful. Unfortunately, they too only show the drive tension pulley and supercharger idler pulley, if I remember correctly.
Chasu is offline
#4 Old 01-19-2017
from your vin number
#5 Old 01-20-2017
Part number for the supercharger tensioner pulley is A1192001470. Part number of my original drive belt pulley is 1112000070. I will do a comparison when I receive my new supercharger pulley and provide feedback. Thanks for the help.
Chasu is offline
#6 Old 01-20-2017
Quoted: 58 Post(s)
The tensioner pulley is Part Number: 1192001470
The tension pulley (the one with the bolt through it) is Part Number: 1112020119
alberta.canada likes this.
dedgar is offline
#7 Old 05-05-2019
rorkes's Avatar
Vehicle: 1998 SLK 230
Quoted: 7 Post(s)
Belt Tensioner AND Shock Absorber?
My main belt tensioner bearings failed and took out the belt. I can find the parts for the pully, but the part number on the tensioner (111-200-12-70) on several parts web sites (including Pelican) says to use a tensioner part # 111-200-07-70, but that it needs a shock absorber (pn 111200-04-14) also.
My engine does not have the shock absorber now, but it looks like a mounting tab exists on the engine block for one to the attached.
A different parts web site said that engine serial numbers above 023380 do not have a tensioner.
So the question, are these two tensioner part numbers interchangeable?
I cannot find a tensioner with the 111-200-12-70 part number, so sort of stuck right now.
OBTW, The tensioner seems to move as I would expect, but the bad bearing caused the pully to wear a gouge into the face of the tensioner, so I think I should replace it.
1998 SLK 230.
rorkes is offline
#8 Old 05-05-2019
Quoted: 2284 Post(s)
@Turdo2 sounds like something you have dealt with previously.
anyone know where to get pulley kits, sports exhaust and other performance mods for an slk230 in the philippines? richardang Where to get R170 SLK Items 2 01-08-2012 10:24 PM
Security torx size for pulley of drive belt? topboxman AMGs 14 01-22-2011 10:39 PM
98 slk230 for sale, ASP pulley, Koni Yellows, Eibach Springs pdubq SLK Cars For Sale 7 10-01-2010 12:43 AM
