R170 rear ABS sensor - no connection - Mercedes Benz SLK Forum
 8Likes
#1 Old 01-17-2017
Vehicle: SLK 200 Kompressor R170 2001
Hello all,
My left rear ABS sensor had no reading with ABS and BAS/ESP lights on permanently for a while now. I replaced the sensor which made no difference. I did notice it was not held correctly in the rubber bung so thought maybe the weight of this had broken the connection of the harness/hub to wire. I took it to an autoelectrician who had a look, agreed it was the harness rather than the sensor (apparently it should look like a castle or lego but mine is flat) but states he can't replace it. I'm trying to find a connector on eBay but can't find anything. Does anyone know the official name for this to help my search?
Matt
Giant Scotsman is offline
#2 Old 01-17-2017
Quoted: 6533 Post(s)
Matt, if you post your vin, not only will you get your free datacard but we might be able to get you the name/part number
in the meantime, look here for what you need
Mercedes Benz EPC Type R170 170 Information Everything Benz
#3 Old 01-17-2017
from a r170 230...
Mercedes-Benz SLK 230 ABS Wheel Speed Sensor Replacement | 1998-2004 | Pelican Parts DIY Maintenance Article
#4 Old 01-17-2017
rpm sensor maybe? part 95?
this is from a 320
post your vin for yours
Giant Scotsman likes this.
#5 Old 01-17-2017
Hi Jeff,
That's very useful thank you. Unfortunately the car is being stored at my friends for 2 weeks now but I'll get the VIN as soon as I get it back. I replaced part 95 and it made no difference. It is the attachment this goes into (i.e. the connector on the car lead side, rather than the sensor lead side). Much more difficult to try and replace!
#6 Old 01-17-2017
still post your vin for your datacard when you can
in USA we have our vin also on our insurance card, etc
#7 Old 01-17-2017
I've looked through all three schematics and two use part number A0125458628, the other doesn't show the connector. Found one on eBay. Now just need to find someone who can reliably fit it! Thanks for your help Jeff.
#8 Old 01-17-2017
fyi that part number is not for a r170
#9 Old 01-18-2017
Thanks for catching that. I'll wait to have my VIN before ordering.
#10 Old 01-31-2017
Hi Jeff,
My VIN is WDB1704442F236890. Can you find which model it is? Do you have the prints & part numbers for it?
Matt
#11 Old 01-31-2017
Standby Matt
Let me reread the thread to see what i am looking for besides datacard
#12 Old 01-31-2017
Ok here is your datacard. let me see what you now need or tell me
#13 Old 01-31-2017
rpm sensor right?
#14 Old 01-31-2017
Here is the only sensor i found for the brakes
#15 Old 01-31-2017
Yeah, it was the speed sensor for left rear wheel. Doesn't show up on that picture. Do you know if my car is a chassis 170.444 or 170.445 on the parts list you gave above? I think I need part number A0125458628, is this compatible? It looks like similar to what I think I need Mercedes Wiring Connector Plug Terminal A0125458628 | eBay
#16 Old 01-31-2017
So no speed sensor for rear wheels per epc
your datacard does not show a chassis number
170444
My datacard also does not show a chassis number
that part number is not shown in epc
but like you found, spend $4 and see
#17 Old 01-31-2017
That was my plan. Fingers crossed!
#18 Old 01-31-2017
At least you got your datacard...sorry....
#19 Old 02-23-2017
Just to conclude this story - that part made no difference whatsoever. It transpired to be the reluctor ring in the hub. You have to remove the rear drive shaft so I took it to a garage. Picked it up this morning, what a difference! The ECU must have been upset by the warning lights because the power and gear shifts are much improved. Very happy.
jbanks15 and Robrowdy like this.
#20 Old 02-23-2017
Robrowdy's Avatar
Quoted: 245 Post(s)
So what was the problem with reluctor ring? Damaged somehow or worn?
Robrowdy is offline
Tags
abs sensor, bas esp abs light on, r170, traction control
R172 Rear Brake Pad Replacement WhiteRabbit SLK R172 Class DIY 33 02-13-2019 09:48 AM
R170 rear quarter windows override? PaulRR New Members Introduce Yourself Here 14 08-20-2016 04:10 PM
Looking for R170 AMG rear bumper/side sills 56586 SLK Parts Wanted 2 08-05-2016 07:26 AM
slk r170 heated rear screen problem monkxtreme SLK R170 General Discussion 0 04-24-2008 01:21 PM
Remove rear bumper Zeiser50 SLK R171 General Discussion 1 08-18-2007 12:14 PM
