Relay for wiper motor - Mercedes Benz SLK Forum
 4Likes
  • 1 Post By savcom
  • 2 Post By savcom
  • 1 Post By savcom
#1 Old 01-07-2017
Vehicle: SLK 230 year 2000
Other Toys: Motor Cruiser moored in France
Send a message via Skype™ to Dave T
Can a member please tell me where the relay for the wider motor is located in my car, and which one it is?
I have checked the fuses, they are ok, but the blades are stuck firmly in the centre of the screen, and refuse to budge, I realise the motor may be the issue but need to check this first I think.
SLK r170 230 year 2000.
Dave T
Dave T is offline
#2 Old 01-07-2017
Quoted: 6546 Post(s)
search relay
Component Locations
#3 Old 01-07-2017
savcom's Avatar
Quoted: 609 Post(s)
The relay is, I think, in the multi-function control unit.
I'll see if I can get the wiring and diagnostics sheet for you.
Dave T likes this.
savcom is offline
#4 Old 01-07-2017
Wiper motor relay
Thanks Jeff,
I have seen this list but the wiper motor relay is not there,
Dave T
Dave T is offline
#5 Old 01-07-2017
BBB Industries - TSB's & Wiring Diagrams - End User License Agreement
#6 Old 01-07-2017
savcom's Avatar
Quoted: 609 Post(s)
I've prepped a PDF with wiring / diagnostics and here is a picture of the internals of the Multi-Function Control Module. It shows three relays, one of which is the flasher relay, so let me know when you find the wiper relay and I'll update the picture.
Suggest you try cleaning the contacts and checking solder joints around the relay. Also see if the relay contacts are free to move and are not held shut by corrosion / carbon deposits.
jbanks15 and Dave T like this.
savcom is offline
#7 Old 01-07-2017
Hi Savcom
Thanks for the info.but exactly where on the car is the multi function unit?
Dave T
Dave T is offline
#8 Old 01-07-2017
Quoted: 913 Post(s)
The MFCU is in the black box under the hood; the wiper relay is the one closest to the edge of the board (at least on the sample I have).
efair is offline
#9 Old 01-08-2017
savcom's Avatar
Quoted: 609 Post(s)
Thanks @efair. I was going to point him at the R170 encyclopedia and say to go to Component Locations and to look through the list for N10/3 - Control Module Meanwhile I'll update that photo and we can all benefit.
Dave T likes this.
savcom is offline
#10 Old 01-31-2017
Cool Problem solved....
Well it wasn't the fuse, nor the relay (when I eventually found it) nor the switch or the control unit or motor but the seized spindles that had caused the wipers to grind, literally to a halt.
Thanks to a duff replacement bought on ebay(and returned) the job took longer than I had hoped even by my standards.
The solution was to press out the spindles and clean up and grease the bearings and it should be good for a few more years.
Total cost Ł1.50 (includingVAT) for the replacement washer hose connector from the local Merc agents, which I broke removing the cover,
a bad back from leaning over and a smug satisfaction in sorting the bugger out!
Dave T is offline
Alfred Neubauer: the First “Don” of Motor Racing Berliner Heckflosse Motorsports 0 08-14-2016 05:46 PM
Issue with indicator/turn and hazard lights (relay clicking very fast) azazel_iii SLK R170 General Discussion 9 07-26-2016 10:26 AM
Replacing the Heater/AC Motor Foggy SLK R170 General Discussion 10 09-10-2015 01:07 AM
I have always found this link handy cnovack Off Topic 1 09-01-2015 05:46 AM
