Are all your bypass valves leaking? - Mercedes Benz SLK Forum
  • 1 Post By Avel Du
#1 Old 12-10-2016
Vehicle: Silvia S15
This question is a copy of a question i posted on a different forum but got no answers.
The SLK230 uses the supercharger bypass valve VDO 1110980009 it uses a 45hz PWM signal to operate.
I have been testing and it does not seem to seal when fully closed. On the lowest duty cycle , I have tested it with a small air pump and it bleeds boost.
I think this is not me operating the valve, even when I force it shut with my hand you can see light through the butterfly piece.
I do not think I have a worn valve, but rather since it is metal on metal and there is no rubber sealing it will not hold boost.
Has anyone else encountered this problem or thought about it?
With all this talk about using smaller pulley sizes, deleting maf screens and squeezing extra boost out of the setup surely someone has noticed this inherent boost leak.
Testing of the unit with a Haltech:
matt234 is offline
#2 Old 12-11-2016
Vehicle: 1999 SLK 230
Quoted: 24 Post(s)
I agree that the situation you have found is a leak. However, is the leak so small that it is unmeasurable?
twright is offline
#3 Old 12-14-2016
Vehicle: Silvia S15
On a seperate forum, a user said he resealed the valve by loosening and tightening the butterfly, and gained about 0.5 psi, so if he was correct the loss is not negligible
also when i tested the valve using soapy water it was spewing bubbles when i pressurised it
matt234 is offline
#4 Old 12-14-2016
Quoted: 2286 Post(s)
According to your vehicle you have a Silvia S15 but you're asking about the SLK 230 engine.
Have you fitted the 230 into the Silvia?
Avel Du is online now
#5 Old 12-16-2016
Vehicle: Silvia S15
no, i am just using the valve. Do you have any experience in testing it ?
matt234 is offline
Tags
bypass, slk230, valve
Leaking valve covers on 05 SLK55 maruishirx4 SLK R171 General Discussion 22 11-21-2017 10:41 PM
Leaking Valve Cover (gasket) SLK 350 firstmercedes SLK R171 General Discussion 44 01-26-2016 01:59 PM
Roof leaking, supposedly fixed + rant. MrADeveci SLK R171 General Discussion 7 11-27-2014 08:31 PM
Changing the latches for the hard top due to leaking octanep SLK R170 General Discussion 2 11-20-2012 12:28 PM
Oil pan drain plug leaking. poinde SLK R171 Class DIY 10 06-30-2011 04:04 PM
