Engine oil - Mercedes Benz SLK Forum
 9Likes
  • 2 Post By Bankerboy1
  • 3 Post By jbanks15
  • 1 Post By Robrowdy
  • 2 Post By Robrowdy
  • 1 Post By WoZ53
#1 Old 12-08-2016
Bankerboy1's Avatar
Vehicle: 01 SLK 320
Other Toys: 40' Express Cruiser
Engine oil
Hi All,
My paper work from the dealer regarding my new to me 2001 SLK 320 states that MB service has been using Mobil 1 M 5W-40. I know a few here have mention 0W-40. Does this mean I can use either one?
I purchased the SLK while home in FL and now in MD for a few months. I would guess the 0W-40 maybe better for the winter months.
Any suggestions?
Bankerboy1 is offline
#2 Old 12-08-2016
Robrowdy's Avatar
Quoted: 245 Post(s)
Originally Posted by Bankerboy1 View Post
Hi All,
Any suggestions?
Not near cold enough here bro, but there is hardly any difference any way. I use 0-40 in mine because I bought it out of Colorado and I just like to keep the oil grade the same ( I live in Alabama). If you look at a recommended oil grade chart in an owners manual they all run about the same temperature ranges, some for colder climates like 0-40 and 5-40. Since you are moving to a colder climate then I would do the 0-40
Robrowdy is offline
#3 Old 12-08-2016
Bankerboy1's Avatar
Vehicle: 01 SLK 320
My owners manual suggest using the recommended oil, however doesn't tell you what the recommended oil is.....
murat orhan and Steven Braun like this.
#4 Old 12-08-2016
Quoted: 6554 Post(s)
here:
229.5 Multigrade engine oils (Specification 229.5)
https://bevo.mercedes-benz.com/bevolisten/229.5_en.html
Australian, WoZ53 and Steven Braun like this.
#5 Old 12-09-2016
Robrowdy's Avatar
Quoted: 245 Post(s)
On this chart you can see that both 0-40 and 5-40 have the same operating temp range but 0-40 will withstand lower temps and yes always use 229.5 specified oil.
Steven Braun likes this.
Robrowdy is offline
#6 Old 12-09-2016
Robrowdy's Avatar
Quoted: 245 Post(s)
Don't sound like that year has a very good owners manual, oh well I guess this site will be it from now on
jbanks15 and Bankerboy1 like this.
Robrowdy is offline
#7 Old 12-09-2016
LeonardoDaBenz's Avatar
Quoted: 1066 Post(s)
Mine doesn't either (from what I can recall--book is in car and she's covered for the winter). Just gives a range of 4 (5?) diff "blends" ( but all are synthetic). All 4 are appropriate for my locale.
I guessed at 0/40 because of most comments here. I'll find out at the next change which one is used (or I'll tell them to go with 0/40).
LeonardoDaBenz is online now
#8 Old 12-10-2016
Robrowdy's Avatar
Quoted: 245 Post(s)
Definitely up there in Canada for sure, probably already has 0-40 in it. I probably should run 5-40 in mine being in warmer climate but it had 0-40 when I bought it and thats what I'm keeping in it. Not much difference between the two its just the 0-40 has a better startup viscosity for the cold.
Robrowdy is offline
#9 Old 12-10-2016
Elmer Fudd's Avatar
Quoted: 190 Post(s)
here in the relatively tropical UK
well, compared to your Canadian type weather, I have been using Costco's Chevron 5w30 Fully-Synthetic in my petrol-engined MB's for years, even in my SL for a while, with no problems whatsoever. The SL does prefer a 10w40 or 15w40 , as the only noticeable difference is that when hot and idling, the oil pressure will show at about 2.5 bar on the synthetic. On the mineral 10w40, it idles at, or very near, the full 3bar. .
I have driven the best part of a hundred thousand miles on this oil, in 4 cars, a C280, S320, 500 SL and SLK320. it has saved me a fortune on Mobil 1. I'll bet I could use it in my diesel E320CDi as well if I looked it up. At today's prices it's Ł2.20 a litre. Costing that little, you could run it through your horse and put it on your roses.
Elmer Fudd is offline
#10 Old 12-10-2016
What goes around, comes around
I've seen references here for engine oil test kits. Here's one for $28 http://www.blackstone-labs.com/free-test-kits.php located in Indiana.
They handle US and CDN orders.
Here's another, located in Canada http://www.oildepot.ca/products/by-p...analysis-kits/ (couldn't locate a price)
#11 Old 12-10-2016
Vehicle: 2006 SLK350
Other Toys: 1986 Toyota Truck 4WD-SR5
Quoted: 21 Post(s)
FYI..
I have a 2006 SLK and it doesn't state viscosity either
Jim
Samson3113 is offline
#12 Old 12-10-2016
WoZ53's Avatar
Vehicle: 2006 280 SLK Caspian Blue Metallic
Quoted: 387 Post(s)
It's not in the owner's manual, it's in the Factory Approved Service booklet.
etyu likes this.
Welcome to the forum
Where search is your friend
and the info never ends
Tim Wozny/ WoZ
Eureka,CA
WoZ53 is online now
#13 Old 12-10-2016
I usually buy the 5 quart size of Mobil 1 0W40 from Walmart for roughly $25 USD.
#14 Old 12-10-2016
Vehicle: 2013 SLK250
Quoted: 61 Post(s)
I like to use the Mobil 1 0W40 as that is the European formula which is supposed to be made from esters. I have excellent oil analyst tests using it in my previous SLK230
DucatiSteve is offline
#15 Old 12-11-2016
Vehicle: 2013 CDi 250 R172
Quoted: 21 Post(s)
My dealer does a 'free' top up of fluids every 3 months- I let them top up the oil
but then I'm lazy (and cheap)
grimree is offline
Engine oil leak identification Airman SLK R171 General Discussion 15 07-24-2019 03:45 PM
DIY Oil Change Coolant/Antifreeze Flush Power Steering Fluid Change Swoley2k SLK R171 Class DIY 5 04-17-2017 05:27 PM
The Queen Inaugurates Jaguar Land Rover Ingenium Engine Plant Berliner Heckflosse Off Topic 1 11-02-2014 01:28 AM
DIY : R170 : '98 Benz SLK 230 How to exchange engine cover gasket and valve gaskets w PIC dr.Benz SLK R170 class DIY 13 08-06-2013 01:40 PM
