low mile engine nightmare - Mercedes Benz SLK Forum
  • 1 Post By Charlie350
#1 Old 12-08-2016
Vehicle: 1998 SLK 230 completly stock engine currently does not run.
Hi guys I just recently installed a low miles engine in my SLK after it been handed down to me the previous engine is toasted from the previous owner. After I installed the engine the nightmare begins. First I had a crank no start trouble shoot the problem wasn't getting a spark signal to the coils, the coils are getting 12 volts with key on then replaced the crank & Cam sensor engine tried to show sign of life after several attempts the engine started up and ran flawless until rev past 2K it will start to sputter. But the issue is when cranking the engine over I'm getting spark and fuel but engine wont run. Could it be a knock sensor ? or does the car need to be re-flash or am I missing something ?. The car is a 98 SLK 230.
Thanks in advance,
Doombugie
doombugie is offline
#2 Old 12-08-2016
Vehicle: Former SLK/350/55 Owner
Other Toys: C43AMG Cabriolet, A 220 4MATIC, W114/8
Quoted: 228 Post(s)
I guess you do not have a code scanner?
Even a cheap one can pull the basic codes, so with just $15 you could get one.
It will be much easier for people to help.
Best Regards
Charlie350 is offline
#3 Old 12-09-2016
Already check... no codes or CEL popped up. That why I resulted to the forum for other ideas what it could be.
#4 Old 12-09-2016
Quoted: 508 Post(s)
Thanks in advance,
Doombugie
I may be having a bad day but I have read your original post a couple of times and I'm left confused. Does the engine run or not? You state that it runs well up to 2,000 RPM, but then you state it doesn't run.
mchild is offline
#5 Old 12-09-2016
Other Toys: H20 V-Dubs, MK1s
Quoted: 411 Post(s)
Equally confused. However, if the engine does in fact run "flawlessly" until around 2ooo rpms, then starts to sputter, could this be a turbo boost problem? I have a 171 but I think (bc I don't not KNOW) that all the 170s have turbos on them?
Roxanne7169 is offline
#6 Old 12-10-2016
Quoted: 228 Post(s)
Did the engine came with an ECU or you just plugged the one you had?
Tapatalking
Fuel additives and engine tick/tap/ping/knock/whine/sluggishness/hesitation and top tier gas jbanks15 Off Topic 252 3 Weeks Ago 01:31 PM
Low voltage causes? Flickering lights. 2_Big_Red_Dogs SLK R170 General Discussion 8 12-28-2015 07:15 AM
New moVe - Mercedes V6 & V8 Engines Twisted General Discussion 19 05-10-2010 05:41 PM
