Bas/asr problem - Mercedes Benz SLK Forum
  • 1 Post By jbanks15
#1 Old 11-29-2016
Turborider's Avatar
Vehicle: SLK 200k r170 97'
Other Toys: Honda CBR 900rr GHOSTEDITION Fireblade & 2x w124
Bas/asr problem
Hey guys!
I got a problem with my bas/asr which comes from brake pedal switch. So I get new one and replace it and now ASR works but... When I start the car bas/asr error doesnt light but when I push the brake pedal and turn it back, the bas/asr eerror light comes on BUT ASR works. I can turn it on/off without problem.
My question is why error light comes on when I push the brake pedal? Asr works.
Turborider is offline
#2 Old 11-29-2016
Quoted: 6573 Post(s)
Have you turned the wheel fully left n right?
i believe the procedure to reset is in your owner's manual
#FullDragon likes this.
#3 Old 11-29-2016
Turborider's Avatar
Yes I start the engine, make full left for about 2sec. then full right the same way and then straight after that turn off engine and start again- nothing.
Its strange, because issue comes on when I push and pull brake pedal. Could it be not good adjusted brake switch? But stop lights work good I mean when I push pedal a little bit and stop lights comes on.
I think its something from the switch. I will try to adjust it again but in weekend. If u have any ideas, share them.
#4 Old 11-29-2016
Quoted: 914 Post(s)
No ideas but keep in mind the switch is actually two switches: one N.O. that closes as soon as you touch the pedal, and one N.C. that opens as soon as you touch the pedal. So some things working and others not may be expected.
I don't think there is any adjustment for the switch.
efair is offline
#5 Old 12-08-2016
Turborider's Avatar
Here is the problem. Any ideas what to do?
#6 Old 12-09-2016
Vehicle: 2003 SLK 200 Kompressor
Other Toys: BMW R100 GS PD/C
Quoted: 29 Post(s)
Have you checked all 4 wheel sensors?
OBDII diagnostics. Trouble code definition for code C1000. Causes of error C1000
Shalesy is offline
#7 Old 12-09-2016
TFP
TFP's Avatar
Vehicle: 02 SLK32 AMG
Quoted: 151 Post(s)
Hey guys!
If your battery charge level is on the low side, the bas light will come on under braking.
If the battery is not fully charged, and I mean fully charged, get it on a trickle charge until it is.
Then perform the reset as stated earlier and take it for a short spin while everything settles down.
Remember the old adage, the R170 doesn't love a good battery, it loves a great one !
TFP is offline
#8 Old 12-09-2016
Turborider's Avatar
Originally Posted by John Shales View Post
Nope. I haven't check them yet. Can you show me where to look for them?
#9 Old 12-09-2016
Turborider's Avatar
Ok I'll try to charge it. Thanks
#10 Old 12-10-2016
Quoted: 29 Post(s)
Check this link at PelicanParts out:
Mercedes-Benz SLK 230 ABS Wheel Speed Sensor Replacement | 1998-2004 | Pelican Parts DIY Maintenance Article
Shalesy is offline
The Following User Says Thank You to Shalesy For This Useful Post:
Intermittent seat adjustment problem. Seat relay fix. JaysonM SLK R170 class DIY 46 03-29-2019 03:34 PM
Intermittent Starting Problem edzed SLK R171 General Discussion 44 07-28-2018 03:38 PM
Help needed with a possible problem please ?? curro101 SLK R171 General Discussion 15 06-15-2014 06:34 PM
SRS & Tele Aid problem thepiratetech SLK R171 General Discussion 2 04-11-2013 04:40 PM
