:crying:Reconnected my fully charged battery yesterday after being disconected for a few weeks. Turned key to start engine but there is no cranking noise, not even a clicking noise. Could it be a problem with the immobiliser? Thanks.:smile:
Battery is 4 months old and has 12.6v. Battery cables good. Central locking and lights / indicators work. Dash lights work but no crank to start engine!
Sounds like the "K40" issue. Look at the sticky at top of this page & all will be revealed.
Also check the very last post of mine & see where my problem lay ;-)
The starter is controlled by the cycle module N65, which is inside/under the fusebox in the engine compartment. There is a relay inside N65 for the starter. You can check the voltage at the diagnostic connector (the white connector inside the other box that's also under the hood) when cranking to isolate your issue. It's a VT/WH wire on pin 1 of the diagnostic connector. Look for +12V during cranking. If +12V is present during cranking, you likely have a bad starter or bad wiring to the starter.
Tbh, sounds like people are pointing you at more difficult options. Pick the simplest to disregard. I spent months figuring mine out & all it was, is a **** plug connection (green wire).
Look at that first, will take you less than 3 mins to absolutely confirm & then fix it or move on ;-)
Rick, can you provide links to your relevant post?
You will have to open the "apparatus box" either way, and since the diagnostic connector is right there, measuring voltage on pin 1 during cranking shouldn't be too much trouble or too complicated.
Pasted from the Sticky: K40 relay module post.....
Mine (as mentioned before) has had the intermittent fail on the K40 relay. But i have since narrowed it down.
On the top of the K40 are a series of plugs, as you look at it in situ, the LH plug (black 4 pin) which has only 1 green wire going into it is now my culprit.
When it entered "Overheat" mode, fan going full tilt but not starting, i wiggled the plugs & the fan died off & car started. I then waited till it did it again & noticed LH plug was the culprit.
I disconnected this plug & tried starting & hey ho, it went into overheat! Plugged it back in after using switch cleaner & all is good.
So there you have it, a temp fix is wiggle it while fans spinning, then clean contacts for this single green wire to sort a permanent fix
When I turn the key there is no clicking noise from the starter. The engine fan comes on and stays on. The diagnostic machine is not getting any communication from the engine control unit. Checked the K40 relay but could not see any damage. Is it more likely the ECU gone bad or K40?
I'm sure I've read that engine fan coming on and staying on can be a symptom of bad K40 solder joint... apparently (never needed to do it myself as I have R171), you might need to inspect the K40 solder joints under a magnifying glass. If you confident with a soldering iron, may be worth re-flowing/soldering the joints anyway, just to be sure.
I've heard people say that jump starting a car can cause other issues, possibly with the ECU, but I don't know anyone personally that's had a car's ECU suffer because of it.
I'm sure others with R170 experience will weigh in again soon..
"I'm sure I've read that engine fan coming on and staying on can be a symptom of bad K40 solder joint..."
Agree. This is a classic symptom of a K40 relay joint(s) failing. The bad solder joints can be very difficult to identify. My K40 went bad, albeit on a different part of the board with different symptoms. Re-soldering some of the joints fixed it for me and it's lasted ages since I did it.
The Diagnostic machine says 'no communication from the engine control unit'. Does this mean the engine control unit is bad or is this caused by the K40?
The K40 relay provides power to the ECU. Now that you've seen the fan on - game over. Re-flow the solder on the K40, or just replace it (it's pretty cheap). Try cockneyricks solution too.
Don't rely on a visual check of the solder joints - you can't see the areas where the joints fail.
If you're not handy with a soldering iron, find someone who is, and have them re-flow it.
Related Threads
Mercedes SLK World
1.3M posts
78.9K members
Since 2006
