odometer/trip odometer display light - Mercedes Benz SLK Forum
#1 Old 03-19-2013
Vehicle: Silver '98 230; salsa/black interior; purchased 2/23/13 with 84K miles
Other Toys: autos from 40's, 50's, 60's, and 80's
I'm a new owner of '98 230. I've taken the dash and console apart for refinishing. Before reassembling the dash, I checked all the instrument cluster lights. They are all good now (I replaced two lamps). However, with the lights on (either parking or headlights, engine running or off), I'm not getting any illumination of the odometer and trip odometer (the display is fine...just no illumination...so can't be read at night). The lights for the similar clock and external temperature displays are fine. I rechecked the lamp for the odomter/trip odometer and it's fine...I even checked it with the lamp installed in the cluster (using straight pins in the clips of jumper wires from a 12 volt battery). So...I disassembled the instrument cluster thinking I may be able to get to a bad solder joint (or something). Everything on the printed circuit board looks fine (as near as I can tell...I did not try to separate the instrument faces from the board). Trying to follow the printed circuit for the lamp, it appears (to me) that the circuit is not connected to a power source, but I could be wrong about this. If this is the case, the lamp wouldn't have been functional from the factory. What are others' experiences with this display? By the way, my car, as I suspect is the case with other early SLK's, has the "LIM" display (just below the center of the speedometer) which I understand is not functional on US cars (even though my car had a lamp in the PCB for this display and this lamp is connected in parallel to the lamp for the odometer/trip odometer display. So, bottom line, is this a quirk of the early cars (i.e., no illumination for the odometer/trip odometer) or do I have some sort of fault in the instrument cluster PCB that's not delivering power to the lamp?
C-IIAgSLK is offline
#2 Old 03-19-2013
Quoted: 6580 Post(s)
moving to the r170 general discussion section. forum operations is for forum operation issues
‘Usercp’ at the top left of page, then ‘edit your details’ on the left side, ‘additional information’ near the bottom, edit your ‘location’ and ‘vehicle’
Want to post a picture? Start a new thread, make a post, click on the ‘paper clip’ or go to ‘advanced’ and then ‘manage attachments’ then ‘choose file’ then ‘upload’ and ‘submit’!
Moderator/Founding Member
#3 Old 03-19-2013
Aycee's Avatar
Vehicle: 2002 Blue SLK 320
Just been out and checked mine, they are illuminated but mine is a facelift model so maybe slightly different.
Aycee is offline
#4 Old 03-19-2013
robbiemarcelo's Avatar
Vehicle: 1997 slk230 Linarit Blue
I have a 97 Japan Version and has the LIM display but the trip/odometer light is functional (illuminates at night).
Can anyone tell me what the "LIM" display is for?
robbiemarcelo is offline
#5 Old 03-19-2013
LIM display
It's my understanding (via internet discussions that I've seen) that LIM was (is?) used on European models as part of the cruise control system that allows the driver to set an upper speed limit which he/she does not want to exceed. This is not used with the cruise control engaged. I believe that only the pre-'99 USA models had the LIM display in the speedometer, although it was not functional.
#6 Old 03-20-2013
Aycee's Avatar
That's right, it's set by pushing in the cruise control stalk and then setting a speed by pushing up on the stalk. Very handy over here as have average speed cameras which keep a track of you over a number of miles.
Aycee is offline
Tags
instruments, lighting, lim, odometer, trip
