can anyone tell me where the seat adjuster relay is situated? adjustment has been intermittent for a while,but now has stopped working altogether:crying:
Bearing in mind I am in the UK and right hand drive mine was to the upper right of the steering column behind the dash. Took mine out and re soldered all connections on the PCB now it works fine.
Having the whole wiring harness, along with the seats, removed from one R170, and put into another, I do not recall having any relay.
The whole thing was one harness, that on one end has 2 cables, connecting into the fuse box, another 2, which went to ground, connected to the wall of the car, and two ends at each side which plugged into the seats.
Pull the a/c and head light unit out located to the left of the steering wheel. I have 02 320slk WHICH THE SEATS stopped working. I ordered the relay from Rock Auto, opened side fuse panel cover, removed the screws holding the fuse block in place, pulled the a/c head light unit forward and removed. Once the head light switch unit is removed you can see the seat relay (black one inch square to the right & rear of the fuse block. Had a little trouble getting the relay out (just wiggle and pull) Replaced the relay and tested the seats...They work! reassembled the parts and it took about 1-1/ hour.
Join the gang! Your 1st thread should be your introduction so we can welcome you properly so post an introduction in the ‘New members introduce yourself here’ section. Click this: http://www.slkworld.com/new-members-introduce-yourself-here/
If you wish to become PM (Private Message) capable or to ‘edit’, you need 15 posts. To get those 15 posts quickly, just go to the ‘New members introduce yourself here’ section and welcome enough new members as we welcomed you to obtain your needed posts to PM/edit. You can always pm a moderator.
Want to ‘like’ or thank’ someone’s comments? Use the ‘like’ button to the right or the ‘Thanks’ button, bottom right of any post you like. This saves you having to comment or use the 'quote' button so we know who you are asking or replying to or referencing.
FREE!! Post your vin in the Vehicle Datacard Request section to get a free datacard (options on your car). You must update your profile with vehicle info and your location and post an introduction first. http://www.slkworld.com/vehicle-data-card/67706-free-how-get-free-datacard.html
Related Threads
Mercedes SLK World
1.3M posts
78.8K members
Since 2006
