What is the ring around the ignition called? - Mercedes Benz SLK Forum
#1 Old 03-14-2013
LRC
LRC's Avatar
Vehicle: 2001 SLK230 & 2007 ML350
Other Toys: Snowboard
Hi, I'm starting a new thread because I don't know how to search for the part in question. The metal ring around the ignition for my car (2001 SLK230) has a chip and cuts my knuckle when I turn the key. I taped over the chip, which helps -- but now it's just ugly. I somehow have the right part and have an idea how to take apart the dash in order to replace it. However, there is a wire on the part and I was afraid that if I replaced it, it may somehow mess up the match between my key and my ignition. Does anyone know if this is the case? And, if so, what I can do to prevent it?
I've attached pictures below for reference. Sorry two of them seem to be flipped on their sides.
Thanks!!!
-L
LRC is offline
#2 Old 03-14-2013
Quoted: 6551 Post(s)
I flipped 2 of em over
#3 Old 03-14-2013
LRC
LRC's Avatar
Thank you!!
LRC is offline
#4 Old 03-14-2013
Hmmm... I would say it acts as a magnet marking the position of the key when you turn it. The question is whether it receives the signal (electronic key) from the transponder and sends it to the ECU or whatever...or not.. I think if you call your mb dealership and ask them if you simply can replace it or if it has to be ordered especially for you VIN then it would give us some hint.
#5 Old 03-14-2013
Indeed, this ring is called "Immobilizer transponder ring".
Here's what one website says about it: "Transponder keys emit a special signal to the ignition to let it know that the right key is in the lock. The signal receiver in the ignition is known as an immobilizer."
From now I personally would be cautious replacing this thing. If it acts as a "mean" (which is most likely) by which the signal is sent/received then it's ok. It just reads the code from the transponder located in the key and sends it further to the immobilizer. That's why you have a wire - it connects to the immobilizer.
What I would do is disconnected the battery, replace this ring and try to start the car. In the worst case it can show you "Start Error" on the dash board". Then disconnect the battery and replace it with the old one.
Let me give you an example. I had an ignition lock fully changed couple months ago and tried to start the car with the key provided with the lock. (Apparently this key is used to configure the lock pins and not for starting the car, since it doesn't have any transponder). The car didn't start and I saw "Start Error" on the dashboard where mileage is. I simply disconnected the battery, removed the key, reconnected it and normally started it with my OEM key fob.
Hope I gave you the overall idea. That's how understand it, and I think it shouldn't be a problem when replacing it since this part acts as "Intermediary" between the transponder in your key fob and the immobilizer.
#6 Old 03-14-2013
LRC
LRC's Avatar
Thanks JaysonM! I will report back shortly.
LRC is offline
Ignition issue...plz help curiousx54 SLK R171 General Discussion 8 01-22-2015 12:24 PM
Ignition #1 &#2 Wire location foxtrotcrc SLK R170 General Discussion 0 11-18-2012 08:07 AM
Honey I lost my wedding ring washing the car (I swear it's true) Theregans General Discussion 7 04-18-2011 05:19 PM
Ignition switch connections..? kole301 SLK R170 General Discussion 2 03-23-2010 06:40 AM
Whats that thing called? NPC3 Where to get R171 SLK Items 6 02-04-2009 08:00 AM
