Door Sill and Door Questions - Mercedes Benz SLK Forum
 7Likes
  • 1 Post By MrG
  • 1 Post By sactnato
  • 1 Post By curro101
  • 1 Post By MrG
  • 1 Post By Anders S SLK02
  • 1 Post By Mn car guy
#1 Old 03-08-2013
Vehicle: 2002 SLK32 AMG
I have a 2002 SLK32 AMG and the aluminum sill/scuff plate has a indentation in it that I would like to attempt to straighten out. If someone can tell me how to remove it without causing any damage to anything else. I wasn't sure if I could gently pry up on it, or do I have to remove the plastic piece it's attached to and get to it from underneath. Also, when opening and closing the doors there is a slight bump, or resistance in the motion. I tried to lift up and down on the door to see if maybe a bushing was bad but that's not it. I didn't know if this was normal or not. Thanks in advance.
sactnato is offline
#2 Old 03-08-2013
Hang on in here one of the 170 experts will know. The 171 come off easily but not sure about 170;s
JonB is offline
#3 Old 03-08-2013
MrG
Vehicle: Black '02 SLK320
The entire plastic piece comes off. It's attached with clips and can be gently pried loose. I stress 'gently' because I got impatient with mine and cracked it. Take your time and make sure you're prying close to each clip.
JonB likes this.
MrG is offline
The Following User Says Thank You to MrG For This Useful Post:
#4 Old 03-08-2013
So once I remove the plastic piece, am I to assume there different attachments underneath to remove the aluminum sill plate?
JonB likes this.
sactnato is offline
#5 Old 03-08-2013
curro101's Avatar
Vehicle: Slk 200K 2004 r171
Quoted: 528 Post(s)
I've just checked on some old r170 ones I have in the garage and the metal strip is stuck on with double sided tape . A hot air gun or hairdryer should help you get it off without bending it further !!
The doors have two positions on opening , perhaps this is what you are experiencing ??
JonB likes this.
curro101 is offline
#6 Old 03-08-2013
Thanks I appreciate it. I would have expected double sided tape on a cheap car, not one that cost around $55K when it was new.
JonB likes this.
sactnato is offline
#7 Old 03-08-2013
You would be surprised how cheap some parts can be
JonB is offline
#8 Old 03-08-2013
MrG
You might also be surprised at how expensive a good quality industrial grade double-sided tape is!
MrG is offline
#9 Old 03-08-2013
About 9 dollars for 50 meters for 3m double sided Thats about 36 cents per car
JonB is offline
#10 Old 03-08-2013
Sadly Woolly has passed away
Vehicle: SLK350 MT
Chats: 1297
Quoted: 120 Post(s)
Why?? There is no reason not to use a suitable 'modern' material for a particular job. If you look at the chassis of a Lotus Elise, it is all glued, not welded. Just because of the price, would you expect it to use an inferior (on aluminium ) bonding technique?
Woolly is offline
#11 Old 03-08-2013
Nothing wrong with a bit of 3m My spoiler hasnt blown off yet
JonB is offline
#12 Old 03-19-2013
MrG
Here is a pic of the clips. There are four of them.
JaysonM likes this.
MrG is offline
#13 Old 12-14-2017
Vehicle: 1999 slk230, my wifes car which I clean and polish!! Owned it for 4 years and we absolutely love it.
Other Toys: BMW 330d M Sport
Hi all,
Hope these pics help with the question re the sill plate.
Best wishes
Wiggy47 is offline
#14 Old 12-14-2017
Quoted: 6544 Post(s)
Originally Posted by Wiggy47 View Post
Hi all,
Best wishes
fyi, this thread is almost 4 years old
https://www.slkworld.com/new-members-...d-how-fix.html
#15 Old 12-14-2017
Quoted: 52 Post(s)
And yet, the expensive car avoid holes in the sills...
(Dang, I didn't see the date on this thread. Lets hope the designated Mod-Troika doesnt go after me for this.)
Idiot101 likes this.
Anders S SLK02 is offline
#16 Old 12-14-2017
Quoted: 133 Post(s)
Mn car guy is offline
