limp mode and dash lights - Mercedes Benz SLK Forum
  • 2 Post By Vballaz
#1 Old 03-08-2013
Vehicle: 2003 SLK230
Hi all,
looking for some help here with my 03 slk230. I've had my abs bas and esp lights on for a while now trying to trace down the problem. It ran fine, just lights on the dash. Today I tried disconnecting/reconnected the abs pump antilock module harness (the one by the master cylinder) to see if that would do anything. Now the car is in limp mode and I have the following codes:
P0500 speed sensor "A"
P0600 serial communication link
Po720 output seed sensor circuit
as well as the brake lining light on
as well as the red parking brake light on (without parking brake pulled)
I clear the codes and they come right back.
Can anyone give any input on this? I really don't want to tow it down to Mercedes.
Thanks!
Vballaz is offline
#2 Old 03-08-2013
curro101's Avatar
Vehicle: Slk 200K 2004 r171
Quoted: 528 Post(s)
Try taking the battery of for an hour and then putting it ack on ! You'll need to move the steering wheel all the way to the right and then all the way to the left ( or vice versa) afterwards to reset the BAS lights if this works ..
curro101 is offline
#3 Old 03-08-2013
Thanks Curro. I tried disconnecting the positive terminal overnight with out any luck.
Any other ideas?
Vballaz is offline
#4 Old 03-08-2013
curro101's Avatar
Quoted: 528 Post(s)
Did you try the battery reset before or after pulling the anti lock module harness ?
curro101 is offline
#5 Old 03-08-2013
I tired the battery reset after pulling the harness.
The code that worries me is the "P0600 serial communication link malfunction"
Does anyone know what this is?
Which speed sensor is speed sensor "A"?
Vballaz is offline
#6 Old 03-08-2013
curro101's Avatar
Quoted: 528 Post(s)
Can't help I'm afraid , keep bumping the thread , hopefully someone will be more helpfull !
curro101 is offline
#7 Old 03-08-2013
Quoted: 1138 Post(s)
Any other ideas?
Never disconnect positive terminal first !!
negative first then positve .
Delucas is online now
#8 Old 03-09-2013
Ok, I think I may be getting somewhere on this. I verified the abs/esp pump runs when I hard jump it with 12v.... the pump is good. I checked the resistance thru the esp module (the black one bolted on to the pump) power supply going to the pump and the resistance was high (possibly a blown circuit?) The pump does not run when the car is running.
Can someone do me a huge favor and check to see if their pump runs when the car runs in idle? If so, it looks as though I need a new esp module.
Thanks!
Vballaz is offline
#9 Old 03-09-2013
Got it!! I pulled the esp controller off the pump, broke open the case to expose the circuit board (literally broke the cover in half because it was stuck) I noticed one of the transistors solder looked very bad. I re-soldered and bam... no more lights, all gone, car shifts great.
This must have been what was keeping my abs bas and esp lights on for a long time and finally the connection got bad enough to cause the car to go in limp mode.
I hope this helps someone else.
efair and curro101 like this.
Vballaz is offline
The Following 2 Users Say Thank You to Vballaz For This Useful Post:
#10 Old 03-06-2017
johne's Avatar
Vehicle: 2000 SLK230 (facelift)
Other Toys: Subaru Outback wagon 4wd
Quoted: 18 Post(s)
A bit of an old thread but you may have helped me, I've gone from a car with spongy pedal to one stuck in a low gear no speedo ABS lights etc on and even worse brakes,
I bought a new m/cyl which hasn't helped, so thought I'd remove ABS pump and wouldn't you know the bearing came out with it so pulled of ABS unit to reinsert, Gave pump a clean and bench test and reinstalled everything and bled brakes. I had the battery neg terminal off the whole time.
Reconnected battery and ran car to find brakes easily as bad and ABS light plus a couple more.. Took for a drive down the street, brakes are effective but feel awful.
I did nothing else to cause loss of speedo and gear changing, Aaaaaaargh
johne is offline
lights stay on, key remote not working, code on radio jvbutter SLK R171 General Discussion 0 01-15-2011 11:24 PM
SLK 2003 ASB/ESP and Limp Home Mode davidwmjones SLK R170 General Discussion 3 11-24-2010 06:52 PM
