SLK320 issues - Mercedes Benz SLK Forum
 5Likes
#1 Old 03-04-2013
mta
Vehicle: SLK 320 2001
SLK320 issues
Hi, I'm a bit worried about my car and hoping for a little advice before I take it to the garage
Last week my car developed a horrible rattle. It just so happened it was going to the garage for another problem with the boot and I asked the mechanic to check it out while I was there, he told me the catalytic converter had blown, but he said don't worry about it, just get it sorted before the next MOT which is 9 months away.
Today the CEL came on and the acceleration is a bit jumpy, like hesitant so suspect that the cat blowing was caused by something else? or would a blown cat cause this?
TO be honest I'm worried about taking it to a garage and they're going to rip me off. I'm thinking I should get the sparks and all the filters replaced too, and would like to buy the catalytic converter and paying for the labour to fit it, but there's more than one cat right? Or are they all the same?
mta is offline
#2 Old 03-04-2013
Quoted: 6558 Post(s)
Please update your vehicle (model and year) in your profile as it helps the members answer your questions which usually are based on that information.
‘Usercp’ at the top left of page, then ‘edit your details’ on the left side, ‘additional information’ near the bottom, edit your ‘vehicle’. And it only takes about 30 seconds to do!
Moderator/Founding Member
#3 Old 03-05-2013
mta
I suspect the CEL light is the O2 sensor. The lag I experienced has stopped and the car seems to be running smoothly
I've ordered an OBDII scanner and my plan is to get a major service and get the cat part identified, order it and get it fitted. Seems like there's two parts, a nearside and offside - the latter being a lot cheaper. The noise does appear to be coming from offside so fingers crossed.
mta is offline
#4 Old 03-05-2013
Firm's Avatar
Yeah, get yourself an OBDII coder reader and start with that. The Cats are known to 'blow' and develop rattles in these cars, and it a Cat isn't functioning properly, it is likely to throw a "check engine light". So I'd suspect that you just need a new Cat.
The Cat on my truck developed a similar rattle, so to test I slid underneath with a rubber mallet and gave the Cat a few good whacks, listening for the rattle. Sure enough, when I hit the Cat I could hear the rattle inside. This truck only had one Cat, but that might be a good method for you to determine which one is rattling.
Firm is offline
#5 Old 03-06-2013
Naffdave's Avatar
Vehicle: Looking used to own a 2005 SLK 280 and a 1999 230K
Other Toys: NSM Sattilite Jukebox
Quoted: 23 Post(s)
Send a message via Yahoo to Naffdave
The Cat on my truck developed a similar rattle, so to test I slid underneath with a rubber mallet and gave the Cat a few good whacks, listening for the rattle. Sure enough, when I hit the Cat I could hear the rattle inside. This truck only had one Cat, but that might be a good method for you to determine which one is rattling.[/QUOTE]
Good idea but far easier to to slid underneath a truck than a SLK with a rubber mallet you need to be very small Ha Ha
Naffdave is offline
#6 Old 03-06-2013
Firm's Avatar
, true. My truck is lowered, so it doesn't sit much higher than the SLK, but I usually just park them over the shallow ditch along the bottom of my driveway which gives me enough room to slide under without jacking them up.
Firm is offline
#7 Old 03-06-2013
I thought only Southerners in the US used the "ditch method". "Don't need no stinkin lift".
MrG and rhartson like this.
CarolinaBluetec is offline
#8 Old 03-06-2013
Firm's Avatar
I've got a feeling us MG owners learn to work with whatever is available
Firm is offline
#9 Old 03-07-2013
So true, So true.
#10 Old 03-07-2013
mta
P0100 - Powertrain. Mass or volume air flow circuit
P0301 - Powertrain. Cylinder 1 Misfire Detected
So not the o2 sensor. I don't know if these are related to the cat blowing, the Cel came on about 500 miles after. It's gone out now.
mta is offline
#11 Old 03-07-2013
mta
BTW I don't have enought posts to answer the PM's, just to say my plan is to get the garage to clean the MAF and then get some advice on the cat
The rattling is really annoying and causing the car to shake a bit too
mta is offline
#12 Old 03-07-2013
Firm's Avatar
Based on the codes I'd say cleaning and/or replacing the MAF should take care of the CELs.
I agree that I'd find the rattling cat very annoying too. Keep us posted with what you find.
Firm is offline
#13 Old 03-08-2013
mta
Both cats need to be replaced
Parts and Labour £400
mta is offline
#14 Old 03-08-2013
Der Flieger's Avatar
Vehicle: silver/red 06 350
Quoted: 123 Post(s)
Is that from an independent shop?? Perhaps some of our UK members know a good shop - but you need to update your profile with a more specific area...
FUN 4 2
Der Flieger is offline
#15 Old 03-09-2013
mta
Yes it's independant - All the fittings were corroded and both cats were rattling. That's for BM catalyst complete exhaust. offside and nearside, he said it was 3 hours work but quoted for 2.
mta is offline
#16 Old 03-13-2013
mta
Just to say the job has been done - cost me all together £293 for the offside, nearside and gaskets which all came from BM catalysts
+ £180 for the work after the garage wangled some extra labour out of me for various problems like "seized bolts".
SO far no O2 failure
They said the p0100 and p0301 errors were cause by the cat so hopefully that's the end of it.
rhartson likes this.
mta is offline
#17 Old 03-13-2013
I keep telling people how to get enuff posts! no one listens! This is like being married!
#18 Old 03-13-2013
REB_TN_06's Avatar
Vehicle: '06 SLK 280
Other Toys: Taylor 814ce
Then again, they may be listening, but choose not to do it.
Once again, like being married.
ken320 likes this.
Gene
REB_TN_06 is offline
#19 Old 03-13-2013
married with children
REB_TN_06 likes this.
#20 Old 04-18-2013
mta
Just un update to say that that after replacing the exhaust, I continued to have problems, the car would stall at idle throwing P0100 and P0355. I cleaned the MAF and replaced the crank position sensor (found a really good DIY on the crossfire forum) which solved the stall.
The car still shakes a little at idle, which I'd guess would be the mounts...
mta is offline
07 slk55 almost 50k miles, KNOWN ISSUES? esqdg AMGs 28 02-22-2013 12:16 AM
Issues with 2009 SLK300? michael5155 SLK R171 General Discussion 8 07-10-2011 03:12 AM
2005 SLK 200 Compressor Issues renier.dejongh SLK R171 General Discussion 4 04-24-2011 06:51 PM
Ongoing problems and dealer issues arosamond General Discussion 19 12-31-2008 09:14 PM
