Brake Calipers - Mercedes Benz SLK Forum
 13Likes
#1 Old 03-01-2013
Vehicle: 2001 230K SLK
Brake Calipers
Is it sad to paint the brake calipers ? Was only thinking about painting them Back or Silver. What do you think?
WhitwellMike is offline
#2 Old 03-01-2013
rhartson's Avatar
Vehicle: 2013 SLK 55
Other Toys: Tesla Model X
Quoted: 19 Post(s)
nope...special paint is available for just that purpose-there are also co's that sell caliper covers that are colored that double as brake dust shields...
"You may all got to hell, and I will go to Texas" Davy Crockett
rhartson is offline
#3 Old 03-01-2013
Painted Calipers
My painted calipers
rhartson likes this.
JonB is offline
#4 Old 03-01-2013
AZ SLK's Avatar
Vehicle: 2007 MB SLK 280, Remus Exhaust, TSR 17" wheels, Pirelli PZero tires
Other Toys: '15 Z51 Corvette, '12 Cadillac Escalade EXT, '11 MB GLK350, '04 Honda GoldWing, '13 Craftsman VT4000
Quoted: 25 Post(s)
I chose to go with the MGP Brake Caliper Covers for both my SLK and Vette. All about personal preference.
Michael --
AZ SLK is offline
#5 Old 03-01-2013
Other Toys: BMW 135i (first year), Ford F-100
Quoted: 8 Post(s)
I'm getting my calipers painted red tomorrow.
sanurjim is offline
#6 Old 03-01-2013
MrG
Vehicle: Black '02 SLK320
I painted mine silver when I replaced the pads and rotors.
Der Flieger likes this.
MrG is offline
#7 Old 03-01-2013
MrG
Originally Posted by JonB View Post
My painted calipers
Why didn't you paint the rears? Just wondering.
MrG is offline
#8 Old 03-02-2013
I did paint the rears, but they are so small and pathetic in design you can hardly see them
JonB is offline
#9 Old 03-02-2013
I must say that green (body colour) looks fantastic.
The Following User Says Thank You to WhitwellMike For This Useful Post:
#10 Old 03-07-2013
tiledhouse's Avatar
Vehicle: SLK 55 AMG
Other Toys: Range Rover Sport,Nissan X trail.
Anyone found callipers covers in the UK that will fit a '55' ?
I found some on ebay (red). SLK is listed as a fit but not the SLK 55
tiledhouse is offline
#11 Old 03-13-2013
Bradley61496's Avatar
Other Toys: Cessna 140(dads)
These are mine that I did. Gm ppg red....6 hours of grinding the the cast marks out, sanding them, priming them, sanding them, scuff padding them, than paint. After that, throw them on, add the stainless steel lines, bleed brakes, add the custom made decals.
XxsirexX24 likes this.
Bradley61496 is offline
#12 Old 03-13-2013
My painted calipers
Drilled brakes are no good for daily driving Jon.
#13 Old 03-13-2013
Durkatlon's Avatar
Vehicle: 2009 SLK55
Quoted: 272 Post(s)
Nice job on the decals. Do you go over those again with clear after they are on?
Durkatlon is offline
#14 Old 03-13-2013
Nope, it's painted with dcc, single stage paint.
#15 Old 03-13-2013
AZ SLK's Avatar
Quoted: 25 Post(s)
Looking good Bradley. Nice to see a young man take pride in his ride.
Michael --
AZ SLK is offline
#16 Old 03-13-2013
Thank you! I take so much pride in it! I have well over 600 hours in it. That's why she is locked in the garage for the winter. This is my new $700 winter truck. 1989 Dodge dakota 2wd....about 14mpg. I miss the slk so much.... 20 some mpg..power windows, great pick up! ahhhhh can't wait till it gets warmer and all that salt is off the roads!
Woolly and AZ SLK like this.
#17 Old 03-14-2013
Drilled brakes are standard on the 171 350. I think MB know what they are doing !!!!
JonB is offline
#18 Old 03-14-2013
Education time for the young
there are a few reasons drilled rotors make sense. The first is heat. When the brake pad grabs the rotor, it creates friction, which creates heat. If that heat can't escape, it leads to brake fade, which reduces the brakes' stopping power. The second reason is gas build up. This actually isn't much of a problem any more; however, the materials used in some older types of brake pads caused gas to build up between the rotors and pads. That gas also limited stopping power. The last reason is water. If a car drives through a puddle, a carwash or even a rainstorm, the brake rotors can get wet. A wet brake rotor is slippery and difficult for the brake pads to grab. Having drilled holes on a brake rotor makes it easy for heat, gas and water to be quickly moved away from the rotor surface, keeping the brake performance strong.
Slotted brake rotors aren't perfect. They tend to wear down brake pads very quickly. Because of this, the most common type of performance brake rotors found on production performance cars are of the drilled variety. While that type of construction is seen as too weak for racing applications, most everyday drivers should have no trouble with drilled rotors on their street cars and can save the slotted rotors for cars that are racetrack-bound.
tcrankwa and Der Flieger like this.
JonB is offline
#19 Old 03-14-2013
Durkatlon's Avatar
Vehicle: 2009 SLK55
Quoted: 272 Post(s)
Nice...
Drilled and/or slotted rotors are purely cosmetic in today's cars, and have inferior braking performance. The holes were anyways never for heat transfer. Brake rotor metal transfers heat a lot better than a hole to the sky.
http://www.g20.net/forum/showthread....ty-a-good-read
#20 Old 03-15-2013
Just to wind a few up I think these will be my next buy when I replace my discs
rhartson and Algebal like this.
JonB is offline
SLK 200 UK Rear Brake Strip and Rebuild johnnyg SLK R171 Class DIY 3 04-17-2017 03:37 AM
