No Remote lock/unlock, No interior/trunk light - Mercedes Benz SLK Forum
 4Likes
  • 1 Post By Tolak
  • 1 Post By Tolak
  • 2 Post By CarolinaBluetec
#1 Old 03-01-2013
Neither remote would work on my shiny new (to me) 2001 SLK320. The door lock/unlock would work on console with engine running.
1)Ok, tested batteries in remotes (hold down lock/unlock buttons at same time, will blink if battery ok) batteries ok
2)Sync remotes ( briefly press lock or unlock twice, then within 30 seconds turn ignition to position 2) Remotes synchronized, lights blink when lock or unlock is pressed but doors, trunk, etc do not lock- Semi-Fail
3) Decided to come to the source=SLK World. Ok most likely PSE with barnacles or Fuse 9 or both.
4) Path of least resistance=Fuse 9- yes, it was blown. Did not have 10 amp, but since Volvo is kind enough to put spares in the fuse box, I walked over and got one-Everything now works!
5) Now have plenty of fuses after a trip to Advance.
6) Next step, wait and see. Then troubleshoot down the line if it blows again.
I am going to take a peek at the PSE regardless when the weather warms up a little in the next few weeks.
Thanks for all the threads and postings on this issue
CarolinaBluetec is offline
#2 Old 04-18-2013
Vehicle: Black 2002 SLK320
Pse
When my PSE went bad, it was so annoying. The doors would lock and unlock at random, and the alarm would spontaneously go off in the middle of the night. After years of having it disconnected, I finally bought a PSE on eBay that didn't have any of the corrosion that mine had. My mechanic, NOW tells me I need a harness to turn the unit upside down...I spent $500 on the pump, and now another several hundred for this harness? I called Mercedes, and they wanted $2400 to do the entire job. Ya right....I just installed the new pump in the original position...hoping for the best. Good luck!
AlohaGirl is offline
#3 Old 04-19-2013
nimbusgb's Avatar
Quoted: 253 Post(s)
Aloha you shouldn't need a harness to turn it upside down, just a foot or two of vacuum hose. $2400 dollars is laughable!
http://www.benzworld.org/forums/r170...fit-check.html
nimbusgb is offline
#4 Old 05-13-2013
Per ardua ad cineris.
Tolak's Avatar
Vehicle: SLK230 '99 R170
Other Toys: Clio Williams
Bad PSE
And strangely enough, you now have an unused failed PSE; are you interested in selling it so someone can save some pennies?
I would like to be considered as a purchaser, please.
stinger608 likes this.
Tolak is offline
#5 Old 06-20-2013
Tolak's Avatar
As alternatives to myself, Woolly (UK) and stinger608 (USA) are also interested in your dead PSE, with intent to working out how to repair/rebuild them.
Donations in the benefit of the SLK forum!
Tolak is offline
#6 Old 06-20-2013
Hopeless *** owner
stinger608's Avatar
Vehicle: 1999 SLK 230 AMG
Absolutely!! I would have no problem paying shipping to get it here at all. It would give us a chance to see if we could start "refurbishing" these units on the cheap!!
@CarolinaBlue: If you would like to work something out shoot me a PM please.
stinger608 is offline
#7 Old 06-21-2013
After I replaced F9 beginning of March, everything has worked perfectly since. So, I am playing the waiting game to see what happens with the PSE. Thanks.
stinger608 and Tolak like this.
#8 Old 08-06-2013
Vehicle: none
Other Toys: none
what is "F9"
Not understanding what F9 means, please help.
me2flsunfish is offline
#9 Old 08-06-2013
Quoted: 6572 Post(s)
Fuse number 9
#10 Old 10-28-2015
Quoted: 914 Post(s)
I know this is an old thread, but I saw asks for donations... I have two PSE's i can provide you for the cost of shipping from Atlanta, one is certainly not salvagable (it was floating in the spare tire well when I found it), the other is not quite as bad but still has excessive corrosion. I decided to buy new rather than try to salvage.
I see these PSE's can be bought rebuilt now from Pelican Auto Parts, any experience with those?
efair is online now
Batteries Good - No Light on Remote - Remote Dead eze_nc SLK R171 General Discussion 5 05-18-2012 11:35 AM
SLK230 Remote SLKman General Modifications R170 26 02-23-2010 03:31 PM
Remote Lock/Unlock dscott12 SLK R170 General Discussion 2 05-18-2007 06:10 AM
