Can the roof be opened manually with the boot locked? - Mercedes Benz SLK Forum
 13Likes
#1 Old 02-26-2013
Vehicle: 1998 SLK 230 Kompressor Auto
I posted a question earlier regarding my 1998 SLK 230 Kompressor which may be too confusing. Anyway, can the roof be opened manually with the boot locked? I cannot open the boot to access the pull out vinyl cover inside the boot as there is something wrong with the boot lock which is preventing me from opening the boot. I'm assuming the roof won't open electrically due to the boot cover not being in position for it to operate. It could also be that the roof won't open due to the rod in the boot lock being dislodged or something. So can the roof be opened manually, bearing in mind that the boot cannot be unlocked or opened until I open the roof to gain access to the boot lock to fix it from inside the boot? During the opening process of the roof the boot has to move I think but it's locked due to whatever problem there is with the lock. Thanks in advance for any replies.
4johng likes this.
miurasv is offline
#2 Old 02-26-2013
I dont think there is anyway you can lower the roof even manually without the boot lid moving. They are linked. If its the same as the 171 the hook that the boot lock ataches to is part of a rotating bar that in turn is linked to the roof. If the boot lock has failed you have a serious problem Have you tried unlocking the boot with the metal key ???
JonB is offline
#3 Old 02-26-2013
Sadly Woolly has passed away
Vehicle: SLK350 MT
Chats: 1297
Quoted: 120 Post(s)
On the R170 and the R171, the boot lid catch never actually undoes while the roof cycles. The boot lid opens from the front and pivots round catch.
However, I think if you are operating the roof manually on the R170, you have to do some 'stuff' inside the boot space, along with winding the handle through the hole at the front of the headlining.
There are some posts on here (from years ago) showing how you can get in the boot when it seems to stop working.
The obvious first step is to 'jiggle' the key in the lock whilst flooding it with WD40 (other spray on water dispersants/lubricants are available!! ) - this works about 90% of the time.
Woolly is offline
#4 Old 02-26-2013
Thanks for your reply. Yes, I've tried opening the boot with the key. I think this rotating bar that you're talking about may have disconnected itself or a clip on it may have broken that holds it in place. At the weekend, with the vinyl boot cover in its extended position, which allows the roof operation, I couldn't open the boot but the roof worked electrically so I could access the rotating bar by half opening the roof and reconnect it but it may have come out again. A friend was looking at the car and I think he may have closed the boot with the vinyl boot cover in its closed position which now makes the roof unopenable and now I can't open the boot of course.
miurasv is offline
#5 Old 02-26-2013
Thanks for your reply. Do you know where I can find these posts showing how to access the boot when it stops working or post a link to them?
miurasv is offline
#6 Old 02-26-2013
Hmm something has gone seriously wrong with the boot locking mecanism.
If you cant open the boot at all I am at a loss to know what to suggest short of removing the number plate and cutting an access hole behind it. But that is a bit drastic and a totally last resort.
I dont see how you can get into the boot unless someone else does. Is there any access through the bulkhead behind the seats I wonder ??? Anyone ??
JonB is offline
#7 Old 02-26-2013
Gbarringer100's Avatar
Vehicle: 2013 SLK250
Other Toys: 2016 GLA250
Quoted: 100 Post(s)
I do not see where you said you tried the unlock button on the dash or used the key remote. I do take it you tried them. Without the window shade pulled in place the boot will not open for the roof to go down. I think you are locked out, other than cutting the boot open.
Gbarringer100 is offline
#8 Old 02-26-2013
If the connection between the lock itself and the actual hook that holds it onto the rotating bar is broken I dont see anyway of releasing it without some damage and to my mind behind the number plate is the least on show once its repaired or buy a used boot lid from a scrapper
JonB is offline
#9 Old 02-26-2013
boot lids on ebay from about 40 pounds
JonB is offline
#10 Old 02-26-2013
curro101's Avatar
Vehicle: Slk 200K 2004 r171
Quoted: 528 Post(s)
I did that once on a friends BMW E39 !!
curro101 is offline
#11 Old 02-26-2013
probably cheaper than a Stealerships labour charges
curro101 likes this.
JonB is offline
#12 Old 02-26-2013
I've tried the key remote. Where's the boot unlock button on the dash?
miurasv is offline
#13 Old 02-26-2013
If it wont open with the remote or the metal key I doubt it will by the dash unlock button
JonB is offline
#14 Old 02-26-2013
I totally agree with you but it's worth a try. In 5 years of driving this car I don't know where the boot unlock button is. Where is it?
miurasv is offline
#15 Old 02-26-2013
as far as i know and this is from a 171 its the button on the dash that locks and unlocks the doors. I dont know of any other button unless the 170 hs one. But think about replacing the boot lid. MB dealers round here charge over 100 per hour labour and there is no saying they can get into it. If it was me as a last resort I would cut a hole behind the number plate. Get a body shop to uses a nibbler so as not to do any damage to the inside. If you know what it is thats come off then recoonect it and open the boot. Then Tape the microswitch down that the divider activates. That way you can operate the roof. Then either put a patch over the hole and put the plate back or buy a secondhand boot. after you have replaced whatever has failed
JonB is offline
#16 Old 02-26-2013
Quoted: 6540 Post(s)
http://www.mbusa.com/vcm/MB/DigitalA...230_slk320.pdf
page 30 of 2000 manual says:
the central locking switch is located in the center console.
page 30 has a picture
#17 Old 02-26-2013
Quoted: 100 Post(s)
The same button for unlocking the doors. it is called a central locking switch. It is to the right of the red hazard button. It lock/unlocks doors, gas door, glove compartment, boot, and console and turns the alarm on when depressed to lock.
Like others said if key remote does not work have this most likely will not work.
#18 Old 02-26-2013
Just had an idea If you know someoe who has knowledge about the electrics maybe they know a way to override the microswitch via a star diag and open the roof ??
JonB is offline
#19 Old 02-26-2013
Must be someway the microswitch makes a circuit to the roof switch of the motors. I am way out of my megre depth but trying to think out of the box If that can be intercepted or overridden somehow
JonB is offline
#20 Old 02-26-2013
Good thinking. This seems like my only hope now. Thanks for your replies, guys and the pdf for the manual which enabled me to find the central locking switch which as we suspected did not make any difference. I'll call an ex Mercedes tech tomorrow to see if he can over ride the microswitch or do whatever is necessary to get that roof to open. If not it's the cutters for the boot, .
Thanks again, all. Your help is much appreciated.
miurasv is offline
Help - Roof stuck down...with boot now open Blackcatz SLK R170 General Discussion 13 06-15-2016 11:48 AM
Boot/trunk won't open. Can't access the pull out flap to use roof. Any way of opening it or the roof manually???? miurasv SLK R170 General Discussion 21 09-08-2015 05:09 PM
Vario roof opened halfway, sank and can't get back up! dauntless3 SLK R171 General Discussion 40 03-13-2013 12:41 AM
