SLK 200 (SRS + ESP Light) - Mercedes Benz SLK Forum
#1 Old 02-25-2013
Vehicle: SLK 200 2005
Other Toys: Bikes
Exclamation SLK 200 (SRS + ESP Light)
Hi everyone
My name is Raf, I'm new here in the forum.
I have a SLK 200 2005 here in Brazil with 19000 kms driven and about 2 months ago this 2 signs appeared on my dash.
SRS and Defective ESP -> drive to workshop.
I read some topics about it, but I didn't have a conclusion
As you see this car is "old" and have just 19000 kms driven. It stayed a long time without running and one day ran out of battery. When I changed the battery those lights came on.
Does somebody know anything about it?
Thanks,
Raf
rafael_nunes is offline
#2 Old 02-25-2013
Quoted: 6558 Post(s)
Raf,
Please update your location in your profile as it helps the members answer your questions which usually are based on that information.
‘Usercp’ at the top left of page, then ‘edit your details’ on the left side, ‘additional information’ near the bottom, edit your ‘location’. And it only takes about 30 seconds to do!
Moderator/Founding Member
#3 Old 02-25-2013
MrG
Vehicle: Black '02 SLK320
Mine comes on with a low battery or after a jump start. It resets itself usually on the next key cycle after the battery is charged.
MrG is offline
#4 Old 02-25-2013
Vehicle: slk 200k
Other Toys: suzuki a100
Send a message via Skype™ to paul symons
What is s.r.s.+e.s.p for the novice
Regards Paul
paul symons is offline
#5 Old 02-25-2013
leapyfish's Avatar
The SRS = Supplimental Restraint Systems
When you turn the ignition "on" all the vehicle management systems are checked out electronically........if the SRS indicator lamp is "off" after a few seconds the safety system is working OK, if the lamp stays "on" there is a malfunction with seatbelt tensioners or airbags. In this case you need to get the system checked in case your airbags trigger unexpectedly or maybe not at all in an accident.
ESP (electronic stabilty program) is part of the MB Stability Control System, it works together with the ABS and traction control system.
Vario roof
R170 & R171
SLK 230 320 32AMG
leapyfish is offline
#6 Old 02-25-2013
Wizard of ID
tcrankwa's Avatar
Quoted: 22 Post(s)
You can usually clear the ESP light by turning the front wheels lock to lock with the engine running.
Sportlich, Leicht und Kurz
Margie and Terry
tcrankwa is offline
#7 Old 02-26-2013
Other Toys: Bikes
Oh... really? I will try this... but why turning the front wheels would turn of the ESP light ? Wierd
Mercedes store charged me with 450 bucks to generate a budget, just to connect the computer and give me a diagnostic... they are crazy .
#8 Old 02-26-2013
Other Toys: Bikes
That's what I thought man, but it didn't....
The car is working normally I guess...
How can I test if the ESP is working normally? If I press the button on the panel, the yellow exclamation point appears in the dash, showing me that the ESP is OFF.
#9 Old 10-10-2013
Vehicle: 02 230
first thing is to go to a perts store and rea The codes. chances are it's a defective speed sensor on wheel spindle. to check the esp. drive down the highway and close your eyes and think of a destination and see it your slk gets you there. if it does, it's esp is good. kidding.
go down a empty highway with it off. rapidly , manically and continually (but not unsafely, ) change lanes repeatedly. then try it the same with the esp on. the car should boat less, and feel more flat and stable. i realize this is an old thread, but sometimes people check the archives for an answer.
wolf! is offline
SLK R171 Rear third Led brake light Delucas SLK Parts For Sale 8 09-06-2013 03:49 AM
