Keyfobs R So DEAD I think, Please help! - Mercedes Benz SLK Forum
#1 Old 01-26-2013
onixxf's Avatar
Vehicle: 2001 SLK 320
Other Toys: 2005 Toyota X-Runner, 99 Pontiac Trans LS1
Quoted: 7 Post(s)
Please help me!!! Neither of my key fobs work; changed batteries too many times, lost cash on batteries as a matter of fact. Pulled the PSE out, dry as a bone!!! All locks work if I use the key to unlock doors, interior light comes on when I manually unlock doors. Button inside car works if I want to lock myself in the car with no problem; key fobs will no longer activate the panic alarm nor have the siren gone off anymore. Everything worked fine at one time, both fobs but all of a sudden nothing! There is no light indicating battery strength even with new batteries. My car is a 2000 model with 130K on it; do I simply need new fobs? I have a KEYLESS ENTRY SYSTEM lying around but I donít know if I can integrate it into the factory system. Anyone added an aftermarket entry system to the existing system with no issues? Right now all I want is to lock and unlock without inserting the key, I donít feel I should have to do this on such a notable car. I really like my little machine but this one problem is really becoming annoying. Any assistance would be greatly appreciated.
onixxf is offline
#2 Old 01-26-2013
Did you do a search on how to re program the fobs?
#3 Old 01-27-2013
Durkatlon's Avatar
Vehicle: 2009 SLK55
Quoted: 271 Post(s)
If both fobs worked, and then suddenly stopped working, wouldn't that imply that the receiver inside the car is dead?
Durkatlon is offline
#4 Old 01-27-2013
Could be, most of the time the batteries are in wrong or the fob has to be re programed.
#5 Old 01-27-2013
onixxf's Avatar
Quoted: 7 Post(s)
Yes Sir, I searched and was successful in reprogramming at one time; and yes Sir, logic would tell me to consider some other element other than the fobs such as the receiver/PSE; and Sir, I was certain the batteries were in correctly. Upon acquiring the car the previous owner told me the batteries needed to be replaced. I purchased new batteries at a local Walgreens and had the fobs working in the parking lot immediately. Iíve had the car since February 2012 till current, been working out the minor bugs and I thought I had this one licked. Fobs worked well and as I said they simply quit! As far as the receiver in the car is questionable now Iím not sure; what I mean is I donít think I know what or where the receiver is located nor how to determine if itís the culprit or not. When you say, ďreceiverĒ do you mean the PSE in the trunk? If not where is it, how to I check it if itís possible, and what causes it to stop working if you know? Mind you, all locks in the car work fine, if I lock the trunk with the key all locks will lock, if I unlock trunk or door with key all locks respond and interior light will illuminate. The red light flashes on the dash but only if I press it upon exiting the car for the evening. It may flash at other times but I donít remember paying attention during the course of a normal day of going and coming. There was a time I had to replace the carís battery but even then when I installed the new battery the alarm went off but I was able to silence it with the remote. I purchased new batteries at the local AutoZone, replaced them in the store and checked it against their remote checker for signal but no signal was indicated coming from either of my fobs. I will purchase two new sets of batteries, but Iím not going to install them until I receive advice on what I should do or look for regarding the receiver in my car. I use the instructions in my manual to reprogram the remotes and I know that procedure works because it worked upon taking ownership of the car and reanimating the remotes with new batteries! I also ensured I put the batteries in the correct way, I think the manual show the correct direction the batteries should be inserted. I really want to thank you all for your support in this matter, I surely believe itís something minor that Iím not doing or I just may need new fobs but that would be odd if thatís the case. Iíve had old Chevyís with keyless entry and those things seemed to always work, even found one at a local junk yard for my past 98 camaro and were able to reprogram it to work with that car. My SLK fobs are in pretty good shape at a glance, Iíve even disassembled them and cleaned them but even then they look really good inside but I know looks can be deceiving as well. In my frustration Iím seriously considering aftermarket but I just donít know what that would do to the ECU since all components work with each other. I did install an aftermarket radio but even after doing that Fobs worked. Thanks again and I look forward to some possible solutions from those of you who know.
onixxf is offline
#6 Old 01-27-2013
curro101's Avatar
Vehicle: Slk 200K 2004 r171
Quoted: 528 Post(s)
I would check , and re check the batteries , sometimes we get fixed on a certain idea that we're doing something right even though we're not and it's staring us in the face !
By any chance have you been boot near the aerial amplifier , possibly disconnecting something ??
curro101 is offline
SLK 230K-99 is dead on the starter slk620 SLK R170 General Discussion 6 03-11-2012 01:46 PM
dead battery and replacement in less than an hour! jbanks15 SLK R171 General Discussion 17 04-27-2011 10:38 AM
R171 Dead Pedal atebit SLK R171 General Discussion 17 03-30-2011 12:04 AM
Keyfobs Keyfobs Keyfobs danieleik SLK R171 General Discussion 11 01-27-2010 07:37 AM
Dead battery, locked in PARK? Henryhank SLK R171 General Discussion 9 10-06-2009 11:25 AM
