Power loss - Mercedes Benz SLK Forum
  • 1 Post By Livefreeordie
#1 Old 01-26-2013
Franky1966's Avatar
Vehicle: Slk200 mod 1997
Other Toys: Harley-Davidson
Talking Power loss
Since a couple of weeks my slk200 mod 1997 starts loosing power when I push on the gaspedal , the car will slow down actually and then shoots like a rocket forwards ,
I checked already K40 , airmass, changed fuelpump , and there is no code showing up ,
I m a bit frustrated with this and dont know what to do anymore apart of changing the complete engine
So any advice from you guys is welcome
Franky1966 is offline
#2 Old 01-26-2013
How old are the spark plugs? Also do a search on how to clean the MAF. Are you using a good fuel?
wgben22 likes this.
#3 Old 01-27-2013
Franky1966's Avatar
Hi ,
I just cleaned AMF and its maybe a little better , so how do you know if its really broke after a clean , because in the garage nothing shows up on the computer , is it possible its broke anyway ? Sparkplugs are replaced 2 months ago,
Thx
#4 Old 01-27-2013
curro101's Avatar
Vehicle: Slk 200K 2004 r171
Quoted: 528 Post(s)
Have you checked for oil leakage to the cables from the camshaft sensor , if oil is leaking throgh here it can get as far as the ECU causing any number of problems and if it does get that far the repair can be very expensive .
Even if it hasn't got that far it can cause problems in the MAF etc .
https://www.slkworld.com/slk-r170-gen...ft-sensor.html
curro101 is offline
#5 Old 01-27-2013
Franky1966's Avatar
Hi ,
Yes I have a leak there!!! I cleaned a max with wd40 , but its still running bumpy...grrrrr.... Thanks for your reply and link
#6 Old 01-27-2013
Vehicle: 2003 SLK 230. Speer pulley kit. Depo euro headlights with led. Led taillights
Quoted: 9 Post(s)
If all the basic items (oil, air filter, plugs, etc) are checked, try this: Remove negative cable from battery for 30 minutes, then reconnect and do a throttle position reset.
Mantist is offline
#7 Old 01-27-2013
Franky1966's Avatar
Cable of battery no problem , but how to do a trottle reset?
Thx
#8 Old 01-27-2013
Franky1966's Avatar
Ok , find a link how to reset !! Will try tomorow !!
#9 Old 01-27-2013
curro101's Avatar
Quoted: 528 Post(s)
Originally Posted by Franky1966 View Post
Hi ,
If you have an oil leak from the crankshaft sensor , you need to get the cables cleaned or replaced and the sensor changed , and a safety cable sold by Mercedes installed to prevent re-occurance , otherwise if the oil reaches it , you can ruin the ECU which is a very expensive repair in the thousands !!
The parts are relatively cheap and easy to replace , well worth it for peace of mind .
Check your engine type is M111 and if it is the references for the parts needed are as follws :
M111
1 x 271 -150-27-33 Cable
1 x 111 -051-01-77 Sensor
1 x 111- 997-01-86 Sensor centre cover
It is also advisable for owners of the M271 engine to put two of the cables in place before the crankshaft sensor , as according to the forum MBFaq , where I got these references from , cases of the same problem have occured in this engine also , although the M111 engine is more prone to the fault !
curro101 is offline
#10 Old 01-29-2013
Franky1966's Avatar
thanks for your input , will try that ,
Frank
Power Loss latest. spannerchucker SLK R170 General Discussion 10 01-31-2013 10:37 AM
SLK200 Power Loss spannerchucker SLK R170 General Discussion 1 01-08-2013 04:02 PM
Loss of power Jerminator General Discussion 10 10-16-2010 09:45 AM
